Maybe they were not the 40V string trimmers. They cleared out in the stores in RI, MA and CT that I was in and they were cleared out at some MO stores that a friend checked. All at $40 for the 40V version. I also saw 20V Black and Decker string trimmers on clearance for $75.06. If those last this round of clearance, they will be priced again at around $25.03
That flashlight you bought is good just the way it is. I wouldnāt try to mod it.
I didnāt mention this, but when that girl in gardening pulled that tub out from under the shelf, I spied another 40V pack in there. There was also a 56V pack for another brand. Those 2 packs could someday end up in the recycle bin.
[/quote]
[/quote]
You could well be right I didnāt look too close just happened to notice them.
Not only that one but this 56V string trimmer is on clearance at $55.03
It comes with the battery and charger and the battery is a monster
The store I was in had 3, new in the box. I grabbed 2, not for myself but for others.
In other news :bigsmile:
I found the big can of WD40 for a penny, it was $2.02 as I posted a couple of days ago
And I came across this.
Eight of the automatic light control units. Last month I got some at the ā3ā price. That was a good deal, but by now I knew they should be a penny.
These were squeezed in between some light fixtures, a place they wouldnāt normally be and the got missed when it was time for an employee to pull them. I was in that isle gathering some electrical parts when I spotted them. I wasnāt going to be piggy about it so I only grabbed 5. After I self checked out and went outside I realized that I forgot to get cable staples so I went back in, got the staples and picked up the other 3
Damn, you've been on a terror as of late. I've been hitting my closest HD playing weed wacker-a-mole with no success.
I have some items in my sights that should hit a penny soon, but I bet they will disappear just before they should hit a penny. I did find one of those 12v Rigid Li-ion packs you alerted us to (An awesome find). Someone must have hid it and then forgot about. It, unfortunately, rang up for $42.
Tomorrow is Saturday. You should hit the nearest store in morning. There are at least 3 string trimmers on clearance now, the 40V Ryobi, 20V Black and Decker and the big 56V EGO
EDIT:
The 15ā EGO string trimmer is on clearance, NOT the 12ā
Interestingā¦ I wonder what Dave is up to :bigsmile:
I would recommend using plastic NM staples . I donāt like metal staples; they hurt the wire more, you have to worry about how far youāre hammering it, and they are hard to remove.
Staples are used to hold the wire in place, you do not need to pound them in like a nailā¦ā¦ā¦the top of the staple does not even have to be in contact with the wire.
Well, according to The Hitch hike rās Guide to the Galaxy , 42 is the Answer to the Ultimate Question of Life, the Universe and Everything. The Universe is calling, What more do you need?
Get your butt over to HD!
BTW, that 40V Ryobi pack contains 10 pairs of 18650 cells in series. When fully charged, 10 * 4.2V = 42 Volts.
The newer Electrical codes require insulated staples only- canāt legally use the others but I still do with minor un-inspected work on old houses where they are already everywhere else. I think they change codes just to have something to do sometimes.
