Do you leave your Chargers plugged in?
Raw chicken does not agree with me, especially when left on the counter for a few days before consumption. :bigsmile:
:smiley:
You’re supposed to take the feathers off, Bort :bigsmile: They don’t digest as well as the chicken lips do.
Phil
They are automatically removed and stuffed in the walls and attic for extra free insulation 8)
Sounds right. Things that get warm to the touch are using power, but not a lot unless they have a fan or burn your hand. Things that have no certification or testing are hazardous in the event of power surges. Anything plugged in may increase the risk or damage in case of a nearby lightning strike.
My internet router + modem take 60w. If you are reading this it’s likely the same for you. That’s a lot… 525600 watts a year, or 526 kWh. That could be reduced 67% by using a timer to shut it off while sleeping or at work.
No, never.
My router takes 3W and modem take 12W
Hmm. That’s not good news for me.
It is, you should be able to replace yours and save lots of energy
I was looking at the kill-a-watt device. Good to hear the phone chargers are really that low in consumption.
You can always check my reviews of usb chargers, I do include a couple of the phone brands and they are often very good.
Thanks HKJ, that’s a good idea.
I have the Xtar SP1 charger and looked through your review for standby current for just the Xtar walwart (don’t know the correct name to call it) while plugged into wall but not plugged into charger (12V input) and I see you don’t test that.
It could be a nice addition to your reviews to add this info if you wish.
I’ve plugged the Xtar walwart back in when not in use as it was a slight hassle to plug/unplug into wall when wanting to charge. I do however unplug the charger end (12V input)
After I got a stationary power meter I do often include standby/idle power in my charger tests, but it is usual with the charger connected, but idle.
That’s some router :money_mouth_face:
Every charger model is different so you have to check yours. There has been government pressure and some regulation to cut phantom power usage because as it rises it increases societal electricity consumption for little benefit, but there is still a long way to go, some items like cable boxes typically use a great deal of power when idle.
This type of devices can usual not measure low power consumption, but sometimes it is possible to modify the device.
I noticed that, 1W is the lowest it can register
Nope, my Kill-a-watt P3 P4400 does tenths watts. Check out the vampire draw from the XStar SP1:
Although I think you are right that the older ones didn’t do tenths.
PS - if you unplug the XStar at the dock, it’s wall wart draws nothing.
laptop and phone chargers are always plugged in,
I rarely use ni-mh and lithium chargers, so they are unplugged after use.
