^ +2, what is that light?
Looks like a Tiablo light or a copycat (jacob and others), The tail and knurling is their style, I remember a 2x18650 tiablo with MC-E led
Well said. It’s only too late for changes to be made in the first release of the L6. That doesn’t mean some of these ideas won’t be implemented in the next version. Simon is open to suggested improvements and it’s always good to keep the ideas flowing. Ideas for improvement are welcome. As we’ve seen many times, some wonderful lights are born in the ideas tossed around here. That’s part of what makes BLF such a great place.
That flashlight is a Brinyte/OdePro S18… And now back to focusing on L6
I’m waiting for a bit more info but I have asked if the L6 host can have both a smooth and OP reflector option. It’s just a request with no promises yet but I am hopeful. Simon did tell me he would make extra OP reflectors with the first run of the L6. Even more exciting is that it looks like we might have a clear anodized option for the L6 as well. Simon sent me a picture of the double tube for the L2 before anodizing and needless to say it lit a fire that I haven’t been able to shut up about. I’m pushing for bare versions (actually clear ano) for both the L2 and L6. :heart_eyes:
I would deffinetly buy a clear ano L6.
It would look awesome!
I would also. Clear is retro.
And S2+, too! I guess it should cheaper to make clear bodies with one step less in the proces, no dyeing
I guess I’m probably just ignorant about this stuff but “clear ano” seems like an oxymoron to me. Anodization is a chemical process that creates a layer of aluminum oxide, which isn’t clear. Undyed ano is a common thing, but it isn’t clear. It’s a grayish/olive-ish color like Zebralights. So are we talking and a true clear anodizing that I’ve never heard of before, or is this some other clear coating that isn’t really anodizing?
Not really. Any coating adds costs. Black anodizing is just the cheapest coating available.
Usually when they anodize without dying they bead blast, which causes a matte surface and that grey appearance. Like the Manker Godmes T01 in clear, it’s grey silver.
Anodizing a polished product should result in a “clear” ano, I’ve got some parts that I polished and sent off to have anodized purple, they’re quite shiny. I know, this is dyed, but it started out polished and is still almost that shiny, adding dye to the open pores of the metal won’t make it shinier.
Should come out really nice, in most cases (from other things I’ve seen done) it will look untreated for the most part. Definitely be a lot tougher than bare aluminum, for sure!
Not sure what causes that green tinge in the ZL, might be 7075 Aluminum instead of 6061, don’t know, but that’s not a normal result for sure. I like my little SC52 for that, because it’s different.
Hmm you’r right.
I actually want that look from that picture. So a clear coating is what we want. (or at least me )
Huh, okay then. Sounds reasonable to me. I’ve also got a few Zebra’s and I guess my opinion of what undyed ano looks like comes from them. And I’d never really considered the surface treatment before anodizing and its effects. Maybe armytek hits theirs with 80-grit before ano to get their matte finish. :bigsmile: Thanks Dale.
So yeah, something that basically looks like bare aluminum but has the strength of anodized sounds perfect. I’m in!
Looky here… http://www.bowers-mfg.com/ano-clear.html and here… http://www.alphametal.com/…. want color? Color Anodizing - Alpha Metal Finishing
Thanks for the links KB. That should help add some understanding. It helped me to see what’s possible. I don’t have experience working with metals but Simon has confirmed that it would be clear anodizing, not just a coating so it should be pretty tough. I’ve posted pics of my 501B several times and that has a clear anodizing with a slight grey-blue hue but it is definitely clear as you can “clearly” see all the machining marks through the anodizing. When metal is well machined that can be a good thing. It’s always been a favorite of mine in the looks department and it’s held up very well. Because the holidays are upon us we will not see clear anodized lights from Convoy until early next year but I’ve expressed how much talk there is about new finishes like this and I think there is a very good chance the clear (bare) look may be extended to other models.
I may have mentioned it already but extra OP reflectors will be made along with the first run if the L6. Simon says he will make a batch of SMO reflectors after the initial run.
When will these be ready to order?
I don’t have a date yet. All I know at this point is that we are getting pretty close. I would guess within a month but I can’t make any promises. The last thing Simon told me on the status of the L6 is that he would take extra time to try to get better tints in the XHP70 as the only tint available through the Cree rep at the time was cool white. When I do know I will post the info here.
Thanks
FlashPilot: At 4-5 amps, the current L6 will be another light that overheats very quickly in high mode while providing far less lumens and throw than its larger competitors.
Me: Maybe, but most of the larger competitors you mentioned (that share the same problems) are 3-5 times the cost of this light which puts them way out of my league. I think there are others that will also want this light because of its budget friendliness. Those that could not afford a XHP70 light will now be able to and look darn good doing it!
Me: I like some of what Trustfire does too but in my opinion the TR-J20 is hideous. I can respect it for raw power but dang it’s ugly.
So…this uses xhp70 outputting 3500 lumen…at bout $60…and thrower
*Use 2x 26650 (Me only can afford TF 26650) :Sp
How long will it last when using 2 x 26650?
*When it is on the brightest mode?
Or , it have the programm that will auto drop the brightness?
How far *Estimated it will throw?
Me should be getting some… :bigsmile:
And yeah… i do agree that J20’s head is ugly…Ermm not that ugly, jus that i do not like it base on personal preference…
You've got vestures attention.
