Test/Review of Ikea Koppla
11 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 4 days ago
Ikea Koppla
DSC_2497
Official specifications:
  • USB ports: 3
  • Total current output: 3400mA
  • Port current output: 2400mA
I got it from Ikea
DSC_2493 DSC_2494
DSC_2498 DSC_2499
DSC_2500
DSC_2502
DSC_2503
DSC_2504
Measurements
  • Power consumption when idle is about 0.03 watt
  • Port ports has automatic coding up to Apple 2.5A
Ikea%20Koppla%20top%20load%20sweep
Ikea%20Koppla%20bottom%20load%20sweep
The top and bottom ports looks nearly the same, the bottom port has higher voltage when loaded.
There is no individual port protection and 4A in a usb port is a bit much.
Ikea%20Koppla%20load%20sweep
Running all port in parallel I found out the common protection trips just above 4A.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp2693
M1: 40,1°C, M2: 40,0°C, HS1: 54,1°C
The transformer is the hottest part in the charger.
Temp2694
M1: 42,6°C, HS1: 53,9°C
Temp2695
M1: 33,1°C, HS1: 41,7°C
Temp2696
M1: 39,2°C, M2: 39,6°C, HS1: 52,1°C
10ohm
The noise level is fairly low 12mV rms and 278mVpp.
5ohm
Increasing current, do increase it slightly: 16mV rms and 309mVpp.
2.5ohm
And again: 22mV rms and 313mVpp.
1.5ohm
At full power the noise level is still reasonable: 30mV rms and 348mVpp.
Tear down
DSC_2613
A good squeeze with a vice and a screwdriver could break it open.
DSC_2614
There is a common mode coil on the input and a inductor between the two capacitors. It uses a mains switcher transistor and has a safety capacitor to the low volt side.
The rectifier diode uses the aluminium behind the usb connectors as heatsink.
DSC_2615
On the bottom side is the input fuse (red part marked F1), a bridge rectifier (BD1), the switcher controller (U1). Notice a part marked NTC2, it is probably a over temperature shutdown.
On the low volt side is the 3 auto coding chips (U2, U3 and U4).
DSC_2616
The black part between the two capacitors is a inductor.
DSC_2617 DSC_2619
DSC_2618
The low voltage winding on the transformer comes out at the top and goes to the other side of the slit in the circuit board. This is a way to keep good isolation distance.
DSC_2620
DSC_2621
DSC_2622
Both with a without slit there is a good safety distance.
Testing with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
It looks like a very clean design, no parts on top of each other or squeezed together, there is space for everything, including a good isolation distance. The performance is good.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
Ormbett
Ormbett's picture
Last seen: 2 weeks 5 days ago
Thanks HKJ! I have used mine a couple of months now and are very happy with it. Watt per SEK ratio is very good too :bigsmile:
Kind regards
fyesilova
fyesilova's picture
Last seen: 6 months 3 weeks ago
Thanks for the review, I have noticed this unit a few months ago at ikea.
there were wiresless chargers also, but I do not have any phone that supports wireless charging.
Istanbul New YSM Bridge
Istanbul’s new bridge at night
Manx
Last seen: 3 weeks 2 days ago
Thank you very much for the review, now I can be sure that is a good tool Smile
www.youtube.com/channel/UCeDhMPm0L1yvr3LpygDPgMw my flashlights/knives/gear video reviews
www.absoluteblack.net my dark comics
Manx
Well, maybe it is a very stupid question, but before buy it… don’t you think 2400mA for a single port it is too much? Well, I understand it will be very fast :bigsmile: but again for example, can I use it for recharge a battery sit in a power bank, that can handle just 1A?
Excuse me for this stupid question, I know….
But before pay it 10 euro…Just because I can spend 10 euro in another better tool.
Thank you very much.
HKJ
HKJ's picture
Manx wrote:
Well, maybe it is a very stupid question, but before buy it... don't you think 2400mA for a single port it is too much? Well, I understand it will be very fast :bigsmile: but again for example, can I use it for recharge a battery sit in a power bank, that can handle just 1A? Excuse me for this stupid question, I know.... :8) But before pay it 10 euro...Just because I can spend 10 euro in another better tool. Thank you very much.
It is a bit like asking if your mains outlet that can deliver 2000 Watt (or more) is a bit to powerful to plug your 5 watt phone charger into.
In both cases the connected device will only use the power/current it needs, any extra is not used and the phone will not charge faster (Except if it know how to use some extra current).
Manx
Quote:
It is a bit like asking if your mains outlet that can deliver 2000 Watt (or more) is a bit to powerful to plug your 5 watt phone charger into.In both cases the connected device will only use the power/current it needs, any extra is not used and the phone will not charge faster (Except if it know how to use some extra current).
You are right, thank you.
Shame on me Wink
HKJ
HKJ's picture
Manx wrote:
You are right, thank you. Shame on me ;)
The killer is voltage, if that do not match you might fry something. That is usual not a problem with usb, but with barrel connectors it can be.
piasca
Last seen: 10 months 6 days ago
For 10€ I think is very good. Considering other offers from china its not that expensive.
dodge_911
dodge_911's picture
Last seen: 2 years 3 months ago
My standard operating procedure is asking people if they have 2000 watt bulbs all over the house when they ask about that kind of thing :)g
:: YouTube ::
http://bit.ly/dodgereviewsyt
:: Discord ::
http://discord.gg/fqJEDyy
:: Join the Discord ::
we need more BLF'ers!
dodge_911
dodge_911's picture
bigclivedotcom did a nice teardown video on this :
:: YouTube ::
:: Discord ::
