Sold out! - GBGB: BLF-348 - Classy and Small 1xAAA Stainless Steel light, with Nichia NVSW219B-V1 R9050
My second BLF-348 finally arrived after almost a month. This one has a different beam color. My first example has more of a nice white or cooler beam. Being that I prefer CW in my lights, I really like it. This second example has a warmer almost yellowish tint. Seems to me that it has a different emitter. Oh well, it was cheap and it’s still bright using a 10440.
That’s exactly what I’ve been doing with these types of lights for awhile now. You can buy tiny stainless split rings at Walmart that fit into that loop in the clip and then just add a larger split ring of your choice to the small one. Thanks for showing that.
Hopefully it's an honest mistake...
Gebe, it may be ok with you...but not me...I'll squeal shrilly should they send me one of those.
I’m working on a review for this light. I just finished a video runtime test with both my lights, with a 10440 and eneloop. The 10440 lasts about 25 minutes or so. It seems to have thermal regulation because it gets brighter and dimmer- something that doesn’t happen with an eneloop. The eneloop lasts about an hour and 10 minutes before becoming unusable. No low voltage protection from the 10440 either. At least it seems there is none.
Very interesting that it survived 25min on a 10440, but the big question is did you use an IMR10440 like Efest? Or a lesser ICR 10440 like the ultrafire or soshine for example?
Do you mean by “gets brighter and dimmer” that it slowly moves up and down in output that seems to be regulated by the heat? And did you test in the hand or tailstanding with no extra heatsinking than itself?
I just laid it on the ground like I do with all my runtime tests. No fan, and no extra heatsinking. Yes exactly, it gets brighter and dimmer, brighter and dimmer like thermal regulation often behaves. Yes, I used the eFest 10440. I tried measuring the light’s temperature, but since the surface is polished, my laser thermometer will not get a reading off the light.
Update: Received the light. It’s a beauty.
Tracking still says it is in Germany. I’m sure it will stay there forever, now that the package is with me and there’s nothing to scan. For what it’s worth it seems that the shipper is the problem, not Gearbest.
Anyhow I love the light. Really good, smooth and beautiful tint. I must say thanks to the and Gearbest for making this deal. :slight_smile:
If the output is a 7135, then it has built-in thermal protection.
Somewhere I remember seeing a 7135 on a tiny board…
Interesting, thanks for the added detail.
If you stick a little bit of black electrical tape on the light you can get a decent reading from an IR thermometer :wink: And remember it is hottest right where the pill are.
I have received my second order of this GB light from gearbest, first one is still missing.
Here is the photo with my previous 348’s, middle one is nichia.
Great pic!
Let me guess. On the left is the original SingFire 348. In the middle is the current BLF 348 Nichia 219B, and on the right is the BLF 348 Warm White that was part of the first group buy.
All of the lights are from group buys.
I do not know if the left one differs from the stock version.
The true test of the visual quality of the Nichia emitters is how they render colors, not how “white” they appear on a wall.
Like you, I wasn’t particularly happy with the tint when I first tried it and looked at it on a white wall. But when using it for practical applications, I have to admit that it does do a better job of bringing out the natural colors of areas lit by it. :slight_smile:
As a signmaker that has to match colors...that is more important
I only regret that I did not get more of these. I got them just to toss as gifts and after I tried one changed my mind but I still ended up only one that sits in shirt pocket all the time or it would probably be gone too.
Ditto.
I ordered four more in the 2nd Group Buy: 3rd batch produced!! GBGB: 2nd batch of BLF-348 (Classy and Small 1xAAA Stainless Steel light, with Nichia NVSW219B-V1 R9050)!
But that has got a long way to go to meet the 800 order minimum.
That is ok. This buy took a while to get to where it needed to be. Sometimes it just needs a bit to soak in and I think that because we have had what seems to many buys that people do not notice them as they used to.
The Nichia and the AAA/10440 makes this a very useful light.
I made a custom driver pcb for my 348. If anyone else is interested, you can check it out here.
Anyone care to test a protected 10440 for me? I don’t own a battery and someone wanted to know if they fit. I would think so, but I don’t want to give someone the wrong info.
The difference would be 2-3mm max for the protection circuit. I’d bet my left nut that between 2 springs it could accommodate for that few mm extra.
But we appreciate your attention to detail.
ReManG confirmed a protected cell doesn’t fit in another thread. It isn’t a length thing though, it’s a diameter thing. So the extra mm in diameter do matter. I’m glad I asked.
I would like to add also , that AAA tronic eco 950mah (rechargeable) doesn’t fit ! But i have some eneloop :bigsmile:
