I can not show any graphs of discharge or any comparing results, I just wanted to share my result I got playing with my new charger in terms suitable to my purposes (I guess they are not that uncommon).
Discharging below 3,0V shortens the lifespan of batteries as far as I know, no matter what, in real life I will not get this far.
All I wanted to show is these batteries are not that bad.
I have some 2400 flames too, they will go thru the same test.
Hi Joerch, could you please put them to a discharge test of 1A? There are a lot of tests on 1A and I think this is the best way to compare them to the others. Thanks :)
Just finished and got 2494mAh @1A when discharging down to 3,0V, would have been more when discharging to lower voltage but I do not like that. This cell has been charged and discharged about 5 or 6 times before.
Posted in the sticky on the 2400 mah TF Flames above before seeing this thread. Thanks for the tests. Seems to agree with the tests others have run on these. I don't see it as a negative that they have a higher percentage less capacity as indicated, than the "2400 mah" Flames, as long as they have a higher capacity than "2400 mah" Flames. If these results are typical, then I believe that despite their being $1/pair more they are a good buy. So far (1 week) I am happy with mine, but I have no way of testing them to see what their capacities are.
