Any idea yet if the driver might be the same as the Trustfire 3T6? Any relative strengths/weaknesses of the driver compared to other triple XM-Ls?
Thanks!
Thanks!
Don't really know if the drivers are the same. The PWM freq and output are like the same though. I don't have a stock Sky Ray to measure the PWM freq also.
When I have time i'll try to measure the current with the same batteries and see if they are the same.
2100 so do you think this will soak up the heat as well as the TR-3T6 for long constant runs, im not sure a few alloy threads into stainless will soak up the heat well and the TR-3T6 has about an inch of threads on the middle and 3 contact points of the head for heat soak.
I think this is a nice looking, i like it and priced well but im not conviced it will handle the heat for long night time bush walks as well as the TR-3T6 due to less contact area with the screw in, its the same as my TR-1200 in the way the 3900 screw-in contacts the head but the TR-1200 bezel is alloy not stainless steel so one would thing the alloy bezel would soak the heat up quicker and thats why alloy is used in electrical items not stainless.
the TR-1200 screw-in at 1.7 amps gets hotter then my TR-3T6 screw-in at 2.7 amps when you run them for the same amount of time, since this 3900 is the same style of scew in it makes my wonder if it would handle the heat for long runs, remember i live in australia not ice country.
nice torch nice review as always, please dont take my question the wrong way.
I did a measurement run, with the drop-in wrapped with foil and so lends a helping hand to the threads. It just lags a wee bit behind my TF-3T6 which is also aided by thermal compound on the threads. The results are in the first thread. (its 4.7% drop in out[ut versus 3.4% for the TF-3T6)
The run was only 6 mins though. But i am already past those full 1hr runs, coz i killed my SR3800 that way. Dead short in the mostfet, if i were using unprotected cells it would have vented or rather exploded, no doubt about that. Well maybe not, coz i was using the NCR18650 2900s, maybe still stand a chance of not venting. The NCR18650CH (Callie Kustoms 2100s) can do dead shorts and not vent and so would the NCR18650A 3100s.
i would be intrested in the same test around 30 mins i think the TR-3T6 would hold up better with or with out thermal past as i dont use thermal past on mine, i do have artic silver past for my cpu,s and gpu,s but ive been testing the torch in stock forum, i think your test would of been better with out the foil to give an true idea of how it runs out of the box.
you can realy compare the fry ray to the TR-3T6 as the sky rays where poorly driven and scaled way to high with use hence the burn out,s, ive proven the TR-3T6 will not do this and will stay with in its regulation till it drops out and dimm,s once the batteries are to low, so i dont think there is a problem with venting or death if you use the TR-3T6 past 6 mins to 60 mins.
maybe i think diffrent to you about torches as i use mine for bush walking and camping and so on they need to be able to run so i think it is improtant to be able to run for extented use as to me its a waste of money if i cant actualy use it, this is why i have not brought a dry, its like having a 6 speed transmision in your car but never getting out of 3rd gear to me.
the reason behind this thoughts and questions is my usage of the torches my location australia its a hot place for people who do not know and my old man wants me to buy another 3 x xm-l for him, i see all the cheaper copies and i like the look of this one but i think the best option is the TR-3T6 imo.
Well, I just received Uniquefire 3900 in the mail from Manafont in RECORD time, just barely over 10 days, and that was with a week long suspension of postal service for a national holiday.
Here's what I can say for initial observations and testing with two freshly charged XTAR 18700 cells:
Pros:
Cons
I would be very interested to compare this with the Trustfire 3T6, but I can't stand the aesthetics of the Trustfire... :p Yes, I know it doesn't matter, but then again, these lights aren't cheap. Overall, I am fairly satisfied with the purchase, but I am rather irritated by the finishing nightmare.
Complete review in upcoming weeks.
Hmm...that's funny....my copy's finishing is not 100% flawless of course like a Jetbeam/Fenix but there are no major pits/nicks. Maybe lightmall hand picked them. LOL! In fact i purchased this light solely for aesthetics/shelf queen coz it's SS and grey gunmetal. My pictures are a bit small but i'll see if i can update with some detailed pix soon.
sb, you are supposed to wrap it up....it's supposed to be a drop-in. LOL! The few threads help, but aided with foil there really is no problem, i'll see if i can do longer for 20 mins as benckie requested. Anyway if i have time i shall sand down the anodising on the SS bezel - body thread, it will help.
BTW it's always 30 deg C here in the early part of the night. Longer runs i shall need to try in air-conditioned room to match your guys' avg summer temperature nights of about 20-24 deg C.
Hey 2100, would you be so kind as to show me how you wrap it in foil? I'm a bit of a doofus with my hands... :Sp
I don't mind the fact that the bezel gets hot, I wouldn't normally touch it. In fact the rest of the body is admirably cool. I just don't know how much heat those emitters can handle and I didn't want to fry it straight out of the package.
For me i just wrap a folded and very compressed alu foil, and then wrap the drop-in. You will feel quite a bit of resistance when putting the bezel + drop-in in.
Effect is that the aluminum host gets very nearly as hot as the bezel. That means you are doing things right.
Ok, 20 mins run results : All figures are directly comparable because they are ceiling bounce at the exact same spot. Cells voltage are the same, flashlights are fully current regulated.
Temperature : 30.8 deg C, 15 kph wind blowing at the flashlights.
Trustfire TF-3T6 (4.1% drop after 20 mins)
40 seconds - 57.7
2 mins - 56.9
13 mins - 55.5
20 min - 55.4
Uniquefire 3900 : (6.7% drop after 20 mins)
40s - 61.8
2 mins - 60.4
13 min - 58.0
20 min - 57.9
HI 2100
Was that test done with out foil added to the 3900 ?
Benckie, that’s done with foil added, though i just took like 3-4 minutes to fold and stuff it in, so not too good a job there but i guess it works. It’s somewhat tight though so i guess not too bad overall.
It was pretty warm last night (literally no wind!) so heat was like stuck in the room. 15 kph probably is equivalent to maybe 10-15 deg C without wind?
The fry rays are definitely warmer from my memory.
Thanks mate I was just wondering still unsure what 3 x Xm-l to get my old man I'm going to go with the good old faithful TR-3T6 I think
If you want something that still has reports with failures during operation, then go with the TF-3T6.
I use that one for day-to-day ops, coz it is not designated as a shelf queen.
Damn, one day really must find time to solder the 3-mode direct drive DRY driver into the Fry Ray 3800. LOL! It has only 1 mdoe now, ie Direct Drive. Then i really can play around with it and whack the living daylights out of it.....i have too many spare drivers. (I am using the Trustfire 1 x 18650 extension with it so that it does 3x18650)
Well the way I see it is the TR-3T6 is a proven light, the 3900 has a crap design drop in that's srewed into stainless steel that's just dumb, then you have to wrap in in foil to improve heat soak, with out the foil it is easy to see it would drop even more lumen's and quicker, then the proven TR-3T6 and since the dry need,s to be pack in ice (your words) to run for any lengtht of time in turbo mode the TR-3T6 with its buck + boost CC driver is the best choice in my opinion still, I would not even bother with the skyrays so yeah I'll buy my old man a TR-3T6 as my TR-3T6 is still going strong and it is easy to get parts like drivers, battery tubes, switches and bezel's not that I've needed any
Nice looking light! I don't care for the drop-in screwed to the bezel, however. Just personal preference.
Will be interesting to see if it holds-up.
One note about the FryRay 3800; if the tailcap switch is left on, and screwed into the body, intermittent contact while screwing it on will fry the driver pronto, from spikes/transients. Just ask me how I know this!
The resultant ZZZZTTTT!!! Will get your attention, as another forum member reported, as well.
Heat is its killer, as well.
FryRays; just say no...
r1derbike, yeah for any light, i always make it a point not to screw it on while switched on, you'll never know how's the quality of the driver with regards to input power control (esp those accepting multi voltages).
Benckie, the DRY needs to be packed in ice when gunning in the highest mode, in the ambient temperatures that i am experiencing at night over here. I tried it for 10 mins at -20 deg C with no wind, no issue it gets somewhat hot though. But for non-flashaholics technically without "self-control", that's a bad idea for the light as well as batteries. Just a simple matter of drive levels, ie turn it down man there is a level on the DRY that has equivalent output level as the UF 3900/3T6.
Not sure how the Uniquefire 3900 does without foil though....but seriously I don't think any P60 guys run their Solarforces and XM-L drop-ins w/o foil.... It's still better than an absolutely free floating drop-in.
I'll probably do a 15 mins 0kph wind @ 30 deg C acid test some time soon....to satisfy everybody. Even the massive TK70 got pretty warm at 10 mins, but the drive level is quite a bit higher of course.
Will try to get some sandpaper to expose the aluminum on the anodised threads, that'll help too. Fun hobby eh...
The TK70 would be the go, but for my old man the TR-3T6 would be the safe bet. Soon here we will the in the 40 + degrees C (105 F) days and warm/hot nights and if he takes it to work in the mill's at work at the power station it will be bloody hot. I tested the TR-3T6 for 60 mins on High in a stinking hot shed with a small desk fan goingswitch out no foil or thermal paste so it should handle it.
Wow...if it's in a warmer than usual kind of usage environment, then better don't even stress the TF-3T6 and run it on medium, which is about 700 lumens OTF.
To get 700L OTF with a regular single XM-L emitter flashlight like X9 or STL-V2, you will easily burn it up past 30 minutes in that kind of environment without airflow past the light.
