Though I mentioned that already but that was in the green S2+ thread. Too many posts… 8)
There is a minimum quantity of 5 if you’re just ordering the clip but If you’re ordering anything else from Simon you can always message him and ask him to add a single clip or two to your order. I added that note to the OP here now too.
I’m definitely gonna try them on my other tube lights n see how they fit. My green s2+ n clips shipped yesterday, so another week of anticipation. Great work jdub!
Looks great on a C8… I guess the main problem with these snap-on clips is that they come off if pulled hard enough, and repeatedly putting them on again will scratch the anodizing, will wait for a review, they look great and I would put one in each S2+
I’ve never cared for the bolt on clip either, unless I tightened the screws to the point that the nuts were gouging into the back side of the lanyard holes, the clip would move from side to side. I also had the same problem as Roadie, I bought two of the clips and on both the edges had sharp burs that I had to waste time knocking off with a stone.
These look like they might be a better answer, I’ll have to give them a try, now if I can just find something else I need to buy from Simon’s store.
If properly made they don’t pull off that easily in my experience but these are valid concerns. My EDC for the last several years has been the Olight I3S which has a snap-on reversable clip. I have snapped it on an off and reversed the clip position countless times without any scratches and you have to apply significant force to get it off. I’d take a picture right now but I lost it again… That’s the curse of ultra-small lights. The I3S is a much lighter flashlight but if properly made the same ruggedness should hold true with the new Convoy clip. As soon as mine arrive I will do some testing. I eagerly await their arrival.
Nice! I just ordered some. Been using the bolt on clips for some of my s2’s for a while now and have been wanting this for some time.
You could use the others on sharpies or other big fat markers….
Tactical hotdog or salami holder….
Tactical curling iron…
You get the point, usually you can find a use for extras…
But Simon is cool, he will usually sell just one or two if you are ordering other stuff…
I am looking forward to this clip.
For those that don’t want tactical hotdogs, buy a green S2+ and add a couple of clips, problem solved I just spoke to Neal, BG will be stocking these in the new year so that may be an alternate way to buy smaller quantities.
PS Tactical hotdogs made me LOL, just don’t do a google image search, there is one particular unpleasant image.
ah… this came out the moment I ordered my bolt and nut clip.
should’ve waited a while :weary:
holymolly
im a clip guy and this is awesome
taking them right away
I just found out Simon was referring to something else when he mentioned oxide coating.
I am waiting for confirmation on how this is coated.
It may be that I was correct and that it is indeed black oxide but I wanted to throw this note out until I know for sure.
I got a pm about posting this up here too. Enjoy
Thanks. I meant to comment earlier. That look great. Then again if you move it one groove higher you get the true deep carry position but that’s just my opinion. I like that the design gives you a couple mounting options.
I have them on the top groove after I took that pic lol I’ll take a pic and post later too. The design does give good options and the top grooved is still sturdy as well. I even reversed the clip and had it mounted on my hat the other day when I went night fishing so it does it job nicely.
It even works well in the reverse position? That is AWESOME! I didn’t think that was going to work well until the release of the next S2+ which BTW will have a groove near the head as well specifically for the hat mount. That should prove stellar in the 18350 version.
I have to say, that blue S2+ with the black clip looks awesome.
How accurate is the blue color that picture? Seems deeper than Simon’s pictures. I’m liking the deeper color a lot!
Clip on blue S2+ for good measure 8)
I have a blue S2+ and the color is more like the one you posted so quite deep yes
So how well do these work with heavy blue jean pockets? The bend looks like it might be wide enough and that is the problem I’ve had with every deep-carry clip I’ve had so far. I wear denim most of the time and always at work.The BLF A6 clip is awful in that regard but if this one is good I’ll order some.
Phil
Phil
It’s designed with a 1/8” (3.1mm) gap. It should fit all but the thickest of jeans. It will definitely be better than the BLF clip but I don’t have mine hand yet so I can’t give you a first hand report. The A6 clips on all of mine were too narrow to fit over jeans without re-bending.
Nice clip but looks a bit like it maybe a loose fit if used on thin material clothing…
