leds
edit 100 lot 100 $2.28
these are nice.i figured i have blown $12 on junk with no redeeming qualities before so why not.
surprise!
better color rendering than any 5mm i have seen.
they are rated 8000-10000 mcd and seem about 30 deg beamwidth.
around 4500k.
$12.79/1000 shipped.
the 100 lot shows same part number.
ignore the color of the lighted one in the auction thats NOT what these look like.
no angry blue no beam artifacts.
edit.a photo guy i service stuff for has lights that i put in yuji leds and the ones mentioned here.i didnt notice any difference by eye.too bad his panels needed all 100 he bought as i would have liked to compare spd.
he stated that the color rendering charts look identical under these.
so these really are sleepers!
budget yuji high cri 5mm leds confirmed
Wed, 12/30/2015 - 20:43
#1
Edited by: snakebite on 08/21/2016 - 15:16
υμεις εστε το φως του κοσμου ου δυναται πολις κρυβηναι επανω ορους κειμενη
Dc-fix diffuser film >… http://budgetlightforum.com/node/42208
i wont be back till monday but if you stop by i will set you up.
If you are up for shipping some, let me know…
Lithium Ion Battery Safety 101
Old Lumens Competition 2020 Modified Light Entry
too many things on my plate right now.
btw these are also sold in a 500 lot.
sub
I know this is a very ignorant question, but what do/can you use these for?
anything using 5mm white leds that you want improved color rendering.
btw these seem to be doing fine.i built 2 9 ledcheapies with 8 of these and a 1.5 ohm in the center.fresh 18500 runs at 320ma and settles to 250ma after a few hours.
i ran it all night and put in a fresh cell.identical output to the unused control.
so they are not aging early.
Happy to take up to 20 of these off your hands at any reasonable price when you’re ready.
Phil
like i stated earlier i have a lot going on now.
doesnt preclude me setting you up its one of those things that would have to be low priority.
seller does offer a 500 pack.
seems though that postage would kill the deal on small qty.
maybe another member has the setup to handle a deal like this properly.
Boaz is local so no big deal to hand him a baggie when he stops by…
Yeah sorry i was just making a joke ..And needed a reason to stop by and see my friend snake bit.. i assume these are better color / tint but not really anything close to the high cri 5 mm leds like djozz was playing with
reminds me of the 70’s !!!!
ROFLOL!
would have to test side by side to tell.
the yuji were good by all reports but the shipping killed the deal.
would be nice if that is what these are!the part number comes up only to this auction.
direct drive on an 18650 gets 110ma and no turning blue or dimming.
i simply formed the leds to plug into a converted versapak.
little or no heatsinking is offered by this setup.
no visible degradation after 8 hours.
these are sleepers!
well i now know what these are.
look at sellers other auctions.looks like they build photographic lights with these.
i installed 2000 of these in custom light strips in a friends home.not a single dud and very consistent in tint and brightness.
a quality product.what a nice surprise.
a huge upgrade from the early 5mm the strips were built with.
Exactly what I was looking for.
I have those cheap camera-lights with the nice tint in my wish-list since months – but I want the bare LEDs. only for custom projects.
500 for 8.79 – I guess I need 500 more LEDs
Interesting that they can be DD’d like that. Have to try it and measure Vf at that current. Must have a steep curve.
I did put a set in my favorite magnified visor. Nice smooth beam pattern and I agree tint is around 4500. CRI is decent. Not sure I would call it high CRI, but I’m not a good judge of that. Definitely, better CRI than any other 5mm I have ever used. Output was down a bit from the stock cold tinted LED’s in my favorite visor, but still quite usable. Expected that. I guess I’ll pull the resistors and let the 3S2P AAA’s drive these emitters direct. I’m using Ni-Mh’s, so voltage should be similar to a typical 18650.
Thanks for the alert. Heck of a deal and the price has dropped to under $7/500.
yes these seem to have a higher vf.they even do good in a super cheap dollar tree 3 led dd.
the – leads fold over the board edge giving a path to the thin tube.dd with a cheap 18500 gives output like many older luxeon lights at less current.
all in a package thats disposable/loanable.
as for cri its hard to determine that without proper test equipment.and eyeballs are too different.
Ebay store from OP can’t accept payment, so I have messaged seller and he sent me paypal invoice directly to email. Not exactly by ebay’s book, but I don’t have any doubts since invoice was for service, covered by paypal protection. Now the waiting starts, I just hope these can replace horrible blue led in Nitecore Tube.
btw these have a wider beam than most cheapies.spot intensity is lower but more light at the same current.
an unmodified hf freebie puts a tight blue spot on my white ceiling.same light with these at same current wash it out.floods a dark room nicely.
even better if you spray the 9 hole reflector and empty board white before you assemble it.real nice disposable work light.rolled up cereal box cardboard as a spacer takes an 18500.and still allows use of a 3aaa holder.
This item is no longer available
If someone finds a similar deal please post a link!
Overkill is just about enough!
keep that email handy.looks like they closed the ebay store.
if you dont mind send me the email via pm.
Dang, I missed out on these.
A quick goodle search of the part number JNL5254CHLGW5007-CA4 brings up a different ebay seller, and also an ali store that uses the same images as the store in the OP.
Good catch.will look again once I am not on a phone.
Even the note is awkward doing some things.
I hear ya, that’s why I didn’t post links. Ali links always seem to break when I post them from my phone.
How do you know it’s hi cri led?
The original seller claims ra75.
They have greatly improved color rendering over any other 5mm I have used.and they lack that cold blueish tint.
These were for high end photographic lights.
I built myself some little Modules for photography – they are extremely good.
I would say, the CRI is easily over 90 and they are perfect for lighting stuff for photos or in glass cabinets
Only link I could find to that part number was : http://www.ebay.com/itm/100Pcs-F5-5MM-White-Color-White-Light-Round-Supe...LED-Lamp-/181935336943?hash=item2a5c30edef:g:UCoAAOSwnGJWTDrq
Anyone know if these are the right thing? How do we know they are in fact high CRI, I didn’t see it mentioned in either the old ad or this one?
I would not mind having some neutral/warm white high CRI 5mm LED’s around. I figure I can rebuild some of the many 9 LED lights I have laying around if nothing else.
Texas Avenger Driver Series
My LED Test series - XP-L2 V5 - Nichia 219C 90+ CRI - Latticebright "XM-L" - XHP35 & PWM efficiency - XHP50 - XP-L V5 - XM-L2 U2 - XP-G3 S5 - XP-L HI V2 - Oslon Square & direct comparison to Djozz tests - Nichia 319A - Nichia 219B 9080 CRI - Nichia 219C D320 - Nichia 229AT - XHP70.2 P2 - XHP50.2 J4 - Samsung LH351D
Easy comparison tool for all my LED tests
if the part number shown in the listing is what they ship then yes they are the part i posted.
might want to ask seller if this is the case.
the bag shown is not what i bought.
