I made this specifically for my Sf-348/BLF-348 and figured I’d share it with the community in case anyone else was interested. It is very very similar to the BLF “Tiny10” driver that came out some time ago. I just re-did the layout a little more to my liking and removed the RVP diode to fit pads for an OTC. That’s right, no reverse-polarity protection with this driver. The MCU will go to the battery side and it will be your batt+ contact. You will need to attach a piece of copper sheet/wire/braid over the mcu connected to the larger rectangle pads. It shouldn’t be any problem to stack an extra 7135 as long as the pill allows the extra height. This will make your light li-ion only.
And nice to see work happen for small lights.
Phil
Very cool. Thanks pd
thanks for the kind words
