Groupbuy for UNI-T UT210e clamp meter for tailcap current readings
260 posts / 0 new
pilotdog68
pilotdog68's picture
Last seen: 1 month 1 week ago
Edit: See further down for groupbuy on Ut210e. Comment in Freeme’s thread to join the groupbuy list
Original OP:
I’ve now blown two DMM’s with too high of current, and my newest one doesn’t seem accurate at all. I’m interested in going to a clamp meter. Has anyone used any of the cheap chinese models? I’m looking around $25-35. I’m looking at the UNI-T UT204A or UT203 possibly.
Edited by: pilotdog68 on 01/04/2016 - 13:19
SawMaster
Last seen: 3 years 2 months ago
My “Radio Shack” cheapo didn’t seem to be reading correctly. On reading the manual the clamp section works only on AC. Might be something in particular to check for with these.
Phil
pilotdog68
Phil
Yeah, the cheapest ones (~$10) only do AC with the clamp, but around $25 you start to see DC on the clamp
Ouchyfoot
Ouchyfoot's picture
Last seen: 1 year 9 months ago
How do you blow a DMM. Don’t they have fuses? I’ve overloaded mine, but just had to replace a fuse. I think they all pretty much have the same standard 10amp fuse,
pilotdog68
Hmm that’s probably what happened then, but they were Klein brand so I took them back to Home Depot and they swapped for new one.
Dimbo The Blinky
Dimbo The Blinky's picture
Last seen: 13 hours 41 min ago
I have a clamp meter which I think detects DC, but it’s buried since it’s too big for anything I might need it for.
If you’d go by the local auto parts store or junk yard, you could pick up a Ballast Resistor from an old point-style ignition system. You could wire it in series, measure V across it, then compute your I to see if your meter can handle it. That would ultimately be faster than going back to HD…
Replacing the fuses & batteries isn’t hard, but I’ve seen meters that use weird proprietary screw heads. Fortunately I have all those bits, so…
“There is no darkness but ignorance.”
mattheww
mattheww's picture
Last seen: 5 years 1 week ago
Fuses actually offer suprisingly limited protection. Even the best fast blow fuses take milliseconds to open up, you can fry electronics in microseconds. Exceed the
maximum rating on the input by an order of magnitude (factor of 10), and odds are both the meter and the fuse will be toast.
pilotdog68
Either way my meter can’t measure over 10 amps, and it’s always affecting my readings by adding resistance. I don’t want to open up my meter to mod it because I use it for other things too.
So I’m pretty set on getting a clamp meter, just looking for tips on a good deal.
Ouchyfoot
Ouchyfoot's picture
I've blown four since I've owned my DMM and nothing was harmed. That's the point of having a fuse. I just popped it out and dropped In a new one. I guess there's no knowing what kind of fuses they're using in some of the budget meters, but "Limitron KTK-10" are pretty standard fuses in DMMs. Mine is a Brymen, but I know that the Flukes have standard "Limitron" fuses too. They're pretty standard. I'm pretty sure it would be a waste of money if the fuse couldn't protect your $450.00 Fluke.
kronological
kronological's picture
Last seen: 4 years 12 months ago
Dale uses a clamp meter. Not sure what kind. He might know something.
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
ImA4Wheelr
Build one of these and you won't look back:
http://budgetlightforum.com/node/30693
pilotdog68
Can, what’s the model# on that Mastercraft?
Krono: I think I knew Dale had one, but I’m sure he has a more pricey model.
ReManG
I have an Amprobe clamp on at work that I use, but way out of the range for me to buy off the shelf. I use one piece of 12 Ga multistrand copper that I cut at 5” long to maintain consistency during measurements. I will be interested to see what pops up here for budget options.
pilotdog68
ImA4Wheelr wrote:
Build one of these and you won’t look back:
I swear I’ve read that thread 20 times over the last couple years, and I just don’t get it. Also it’s clear I need a reliable meter to tune in the new shunt, which I do not have.
Can: I’ve seen ones similar to that one in my desired price range, glad it’s working for you.
pilotdog68
I sent a rather low-ball offer on this model, we’ll see what he says.
http://pages.ebay.com/link/?nav=item.view&id=331686413279&alt=web
ImA4Wheelr
I used a bench top variable power supply to make mine.   I don't know how accurate the meters on it are, but it's all I have to go by.  I just cut a 6" 14ga wire with an inch of insulation stripped from each end.  I then put the wire in the power supply and then ran 10amps of current through the wire.  I then probed for the spots that gave me 10mV.  I then soldered wires to spots just a tad wider than those spots because the solder reduces resistance a tad.  You can then tune the wire be either notching the wire or adding solder.  You have to let the wire cool from soldering before testing it for accuracy.
DEL
DEL's picture
Last seen: 4 years 9 months ago
My version, banana sockets are to plug a multi-meter (set to mV range):
22 AWG wire for shunt, about 8” gives 10 mohm (so 10 mV/A). Trim exact length by using an amp meter in series with the shunt and a voltage source. Going over 10A you should probably use thicker wire and lower resistance for the shunt, as per the linked thread above.
Note that copper wire has a relatively high tempco re. resistance. There will be a 4% change in shunt resistance with every 10 C change in temperature. Proper shunt/resistance wire is manufactured from alloys with much lower tempcos.
SawMaster
These are made with Nichrome wire where the resistance increases as the wire heats so I wouldn’t go there. They will handle a lot of current though, just not accurately until the temperature settles down. These were used to compensate for lower battery voltage while the starter motor operated, then lowered current afterward to make the coil and contact points last longer.
Phil
TheBo
TheBo's picture
was undecided between that 210E (24-28 USD) (because of the 1mA resolution, I prefer precision for what i do than 500+ Amp capability), the Mastech MS21080-35 USD (the cheaper 2108A version has not TrueRMS and no Inrush current 27-30 USD) but in the end I opted for a 216C for no reason…. (as always), well the reason was mainly because it seemed a bigger discount even if i ended spending more of what i had planned…47 euros shipped tskk . Always speaking of DC current clamps
It was able to detect 8mA (the clamped displayed 0.01A) And testing various low currents with my linear variable PSU i got very very decent results
But somehow i was not able to measure the battery drain of my sister Toyota Yaris with headlights on, I whink they should absorbe near 9Amp, dunno why
Instead , don’t know if it was reliable for instantaneous DC current (because it calculates the inrush current doing the Fourier transfor of a variable current) i was able to measure 466 Amp from the same yaris D4D to start the engine (battery rated for 570Amp cold start, so it could well be)
If you need me to check something just ask, i’ll do what i can while i’m not at work
Rufusbduck wrote:
Getting discouraged is normal but doesn't finish the job.
freeme
freeme's picture
Last seen: 6 hours 37 min ago
I was also looking for one last year too. My budget is enough for Uni-T only. 210E seem to be a good choice for measuring Amp consumption for flashlight. 211 cost almost double of 210.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
pilotdog68
More precise resolution would be nice, but probably not necessary. I can always use my normal meter for the lower stuff.
I don’t think I’ll ever measure AC with it, so I’m probably ok without the TrueRMS feature?
pilotdog68
Can your wizardry get us a fantastic deal on the 210e?
TheBo
TheBo's picture
Well even if you need to measure AC.. Until it’s a standard sine wave like our common AC we have at home… You are really ok.
Truerms is something I probably never come to use since it’s used for different waveforms.
If you look at your dmm at home you will notice it will measure AC but it’s not trueRms…
I took the 216C mainly for the inrush function… The trueRms it’s a plus… If it is real lol
pilotdog68
I’m really not even sure what “inrush” is.
I’ve seen some discussions about “zeroing” vs “relative” but I’m not sure if that’s something I need to look out for
TheBo
TheBo's picture
Yes the zero function is something you have to look for. Because usually clamp do add some offset in the value because of environmental factors and other stuff. So, zeroing will put the displayed value to zero, before you take a measure. Some clamps do not have the zero button but once you go back to a different setting and forth to the AC they “self zero-ed” themselves… So just look for a YouTube video… Or even better search for a review in a competent site like eevblog or such.
The inrush is used for AC measurements (at least in mine) and in simple terms measured something similar to the peak current in its first 100ms(in mine model).
So for example you can set the clamp to inrush mode leave it there alone and go powering up a system, go back to where you left the clamp and see the absorption peak of the system while it started.
I think it differs from the simpler peak because after it has monitored something when firstly the current arrive it stores the data and not continues to monitor for a higher value.
Also the calculated current should be done by an integral and not just by looking for the highest value… This could be bull@hit from my imagination I’ve should have read them somewhere but I’m not sure… So if you want you have to research and scrutinize better
Hopefully I made myself understandable, sometimes I read what I wrote few minutes earlier and I can barely understand it myself… Lol
freeme
freeme's picture
We could definitely do that If we could all agree to one or two model?
Primary use of the clamp is for flashlight measurement and serve as a back up DMM at the same time? Which models are worth considering?
https://en.wikipedia.org/wiki/Inrush_current.
pilotdog68 wrote:
I'm really not even sure what "inrush" is. I've seen some discussions about "zeroing" vs "relative" but I'm not sure if that's something I need to look out for
TheBo
TheBo's picture
I think if you have to be on the 28-38 use budget and have DC current (for flashlights obviously) there are not many models and a lot are just rip off of the one I mentioned earlier
pilotdog68
The 210e has good reviews and a nice starting price point, but I’m open to others. I think the most important thing be that it is accurate and consistent in the 2-20 amp DC range. It would be sweet to do a small groupbuy on something, but I’m hoping to order something in the next week or two, to make sure it makes it out of China before new years
freeme
freeme's picture
Shouldn't be difficult to get 201E under $30. Cool Any more takers?
pilotdog68
TheBo do you agree the 210e would be good for our purposes? It has the 2amp range that some others don’t have. It gets 4.9 out of 5 on Amazon with 26 reviews, and it’s nice and compact.
Freeme: you think we can do a fast turnaround time on this one?
TheBo
TheBo's picture
Yes, it was my first choice, but remember, I’m a hobbyist so asking to me is like asking to a buddy.
Anyway I’m really curious to see the GB price if this will received the due attention. Too bad I already spent more than what I needed
