They are very fun to build and tune. They will just work with the 105c driver. You will need a bleeder resistor on the FET drivers, you will also need some experimentation to make timings right on button presses. As to clear caps, they are great when you barely want the light to be visible. My nightstand light is a Convoy S2 triple XP-G2 with TK’s BLF firmware tuned to the lowest ML with an awesome high. I had troubles getting the medium press timing working on this one and I built it on one of PilotDogs wonderful FET + 3 (I think) drivers. This one got my only 16mm clear cap because I wanted the lowest light visible on the nightstand. I make most of mine bright enough to see thru the colored tailcaps, but not this one!
Good luck Z squared! Depending on your soldering skill level, this will either be challenging or fun!
My skill definitely went up a couple points after building about four of them. I have some watchmakers tools from classes I took previously, so I was already somewhat used to working with tiny objects.
Everything I’ve done so far was with solarforce tailcaps. I’ve got the parts in for a try on a sure fire tailcap.
I would like to mod a couple of lights with this.
As I understand, there is no complete switch assembly that I can buy?
I’ve never soldered those small components and looking at my solder skills I don’t think I can do it… (also dont have a good soldering iron for it)
What do I have to do with the driver? I have a MTN fet driver and a LD25 driver.
I can make you one or two, but not many (to keep this a hobby).
What needs to happen to the driver is that it must be slightly conductive from batt+ to batt-, even when the MCU and led are not powered. Some drivers show that stock, but most drivers need an extra component, a resistor from batt+ to batt-. The resistor value must be low enough to allow enough current for the tail led to light up, and high enough to not cause more than negligable parasitic current drain when the flaslight is switched on. A functional value is 560 Ohm, which causes just 7 mA current loss when the light is on. In my mods I position this 'bleeder' resistor on the battery side of the driver, between batt+ pad and ground ring, but it is probably nicer to find a spot on the component side.
Well over a month after I posted that, I have finally done a full test and it works great. I’m going to stretch it out to 19 or 20mm and update the OP with a lot of the new info we have, “soon”.
I still haven’t bought any pots, so I used resistors over the pot pads. I tested with a 4.7k and the other empty, and then another test with a 1k on the other pads. As you can see in the video below, it’s very easy to switch between on and off, or between 2 preset levels set with either resistors or potentiometers. (sorry for the portrait orientation of the video :Sp )
Ok guys I’ve updated the OP. I set out to simplify it, but it actually got longer. Hopefully the information is at least more clear and complete. I took the liberty of adding some pictures from others in this thread, if you want me to take your pic down then PM me.
If there are any other sources for anything you think I should add, let me know.
Ive got everything and built the pcb, but I've either burnt out the leds or they are backwards? I'm not really sure how to know which way they need oriented. I see a green dot on one side, I assumed was the + side?
Look on the bottom, there should be a sideways ‘T’ and the wider/flat side is the + side. If you bought from lighthouse led’s, I believe the green dot is the - side. If you go to the product listing on lighthouseleds it has a picture showing polarity. I always have to check their website when I build a new one.
Yea I had them backwards. I looked at djozzis pic and pyros' pics and they were both the same with the green dot being the - side. I flipped them around and still no go, so I swapped for a couple different identical leds. Still a no go, and I'm out of time for today :(
and the modes won't switch with an mtn17dd driver using a 560ohm resistor from the + spring to ground ring.
I'm wondering if I didn't fry a trace in the pcb during assembly. I attempted to test the leds and the aligator clips fizzed so there's a chance I fried something. Hopefully I'll have some time tomorrow to mess with it some more!
Hmm interesting. You could upload a pic if you can and we can look at the other stuff to make sure there isn’t anything obvious. What version of pcb are you using?
Well guys I had hoped that the Kronos groupbuy light would force a major retailer to source clear boot covers and we could all benefit, but it looks like they will only use the 14mm covers, not the elusive 16mm size. We need a new source. Maybe we could convince KD to source them since they already carry other colors and the clear 14mm?
this 100k pot has a start and stop position, it won't spin full circle, and it fit the pads perfect. I double sprung the spring, and I'll be adding a bypass after things start working, this sinner is running 12.3A at the tailcap with a triple xpl.
Here is a pic of the specs for the LeD's I'm using. They are rated way less MCD than the ones you are using, is there something about these that are keeping them from lighting up?
So I re-read djozzs' post, he actually used a 1k resistor and suggested a 15k would work better with his setup With the red LEDs and 680ohm bleeder.
I'm using a 560ohm bleeder and a 15k resistor. I'm thinking I'm holding back too much power? Even if I bypass the diode pads with wire/solder I still shouldn't be putting too much to my leds since it's 7.5mA (4.2/560) 15,560ohms=.2mA+/- the 100kohm pot.
i think that is where I will start my troubleshooting. I also want to order 680ohm resistors to use as a bleeder and see if it fixes my mode switching issues.
I have never been able to use that high of resistance. Usually the highest I can use in the tail is about 6.8k before I can’t see it though the tailcap anymore. I know Djozz does use higher resistance than me, but I think his spacers/washers let more light through than mine do. I would definitely try lower resistance.
Are you testing in a light or out of a light?
What driver are you using? Some drivers (specifically some of TK’s firmware) might require re-calibrating the firmware for the mode switching to work correctly, because it had to be designed pretty sensitive for the mode reversing to function at all.
