oops, I forgot there was already an L6 thread. That explains why there isn’t much info in the L2 OP!
Do we know how heavy the OP will be on the reflector? Was there another reflector he was using to model his OP after?
You and Dale are killing me!
Keepin ya awake, that’s all, making sure you’re crossing your t’s and dotting your i’s and minding your p’s and q’s. (you DO know don’t you that minding your p’s and q’s comes from bartending in the old days in Europe? You have to take good care of your pints and quarts, bottoms up!)
Hey! - I’ll Drink to that!
Only 20 more, Dale… Keep talking!
-Chuck
I’ll take a Pint to Go
A pint sounds great right now but I think I’ll have to settle for going to bed. Keep on spewing your alphabet soup Dale! You could get there tonight pretty easily. How about a couple poems off the top of your head?
Here? :bigsmile: You know I want the slightly bigger (L6) smooth reflectors please!! Small emitter hole will work for me too! I like fitting them to the die of the XHP70. Since I want (2) L6’s, I’ll need (4) smooth reflectors. Thanks “J” :bigsmile:
This will be a JAX X6 Hunter killer, and I'd think at a lower cost .
That’s the plan man!
Money is ready, just say when J-Dub74. J)
+1! Any idea on a time line for the L6?
Hopefully Simon added a few exterior cooling fins below the emitter shelf? It was the main thermal bottle neck when running a XHP70 on 1.5mm of added copper, in the L2, at 10.4 amps, the Lumens were dropping like a rock at 15-20 seconds. at 1 minute it was seriously uncomfortably hot! Killer of hard driven XHP70 emitters and batteries maybe? This was discussed in the L2 thread. My X6 XHP70 pulling over 11 amps on 2 26700 Imrens gets hot fast too, but outside comfortably warm at the 180 second turbo timer- no problem. I just keep popping back to turbo.
Oh boy, but in shear size, the X6 is bigger than an L2, but the L6 will be darn close to the X6 in size. But from the pics of the L6 in the OP if they match what will ship, there's lots of metal there but not as much finning as the X6 in the reflector base area, critical LED area.
Correct! Actually the X6 is massive in the head area, way heavier than the L2 and possibly the L6? I’ll find out? But lack of cooling fins not in the X6 more would be better but I can make this work. It also has the small area between head and reflector. I made pressed fit copper pills bored out the threads,.001” press. for more area and contact with the host. The new Maxtoch 32mm XHP70 boards are just kick ass too. It’s all about the design really,when all my X6’s are where I want them, I plan on potting the inside between head and reflector, with what Randy Brogden (PFlexPro) use’s Stycast Thermal Epoxy potting compound. I will try it out on one light first. It’s quite expensive but worth it to me if it makes and it should, a difference. It’s not all about light box readings and amp pulls with me, I actually use my lights and let other fellow hunters and trappers use my lights for real world testing, will it live? Randy Brogden,Dale and FP opened my eyes to a whole other avenue of modding. Making it LIVE! :bigsmile:
I’m just going to throw this out there again just in case there is any confusion. It’s too late for design changes for the first release of the L6. To the best of my knowledge it is being built based on the CAD models I have posted in the OP. That’s not to say that I am in any way trying to discourage talk of design improvements I just don’t want people thinking they can be incorporated into the first release. I’m still waiting for a release date. There were far more complexities with this build than the L2 including Simon working with his Cree representative to try and source some tint options in the neutral range. I’m hoping to have some news to report soon.
Damn it, I said I was done buying lights… And the odds of me actually using this thing with any regularity are pretty slim. As evidence that I only use my convoy x3 when I’m trying to find my cat when he’s starting shit with a raccoon. Lol!
BUT, if Simon makes that light with “clear anodization”, it will look like a fricken light saber! I mean, how can you not buy one?
Only suggestion I have is does he have the ability to flash toykeepers firmware on the driver? I LOVE the ability to go forward and backwards on modes. The fx30 driver is regulated, right? So it could do a decent moon mode?
It's an e-switch, so my Narsil would work perfectly for fwd, bwd, programmable UI, etc. - quick click to lo, click/hold to hi, click/long hold to strobe, etc...
Do you maybe have a link to the product? Just want to make sure which you’re talking about
Stycast® Epoxy 2850-FT, Catalyst 9 Epoxy and Henkel Loctite STYCAST 2850FT Thermally Conductive Encapsulant Black 1 gal Pail
