You are not referring to this right?
Sorry for the edit. Link in post 18.
Nice host, let me know when you have this deal available
But most designs are a compromise between one thing and another, even an F1 car.
It only becomes a problem if a part fails.
Side switch task group at it again though - better with a body mounted side e-switch. Please, would love to have a better quality Y3 in host form.
SS bezel of course would be sweet too, and also agree with FlashPilot on the heat conductance.
I do understand the compromises of course, and practical issues of dealing with the other side.
For the AR lens, to me there's no sense to providing one because they are very hit and miss from China (wasted a lot of time/effort/$$$ on them in the past), and nothing seems to come close to the UCL and UCLp's - just not worth a couple extra bucks in cost. Bigger brands have provided quality AR lens, but anything generic or no-name will be a disappointment most likely.
I heard host plus packaging will be 600+g. After looking at the initial quote, it is only 50/50 chance for group buy to happen.
This is definitely one of the best looking single 26650 flashlight in market.
It’s very nice looking, I just wish the head was 15mm bigger…
dang… I just bought 3 lights from a group buy! I should just do my wallet a favor and delete my account right now……
any beamshots?
Dang this is gorgeous! It's along the lines of the JAX Z1 and Convoy L2 - two of the best look'n lights around. I would definitely be in on these - look at all that gorgeous finning. Also like the squared off machining - anti-roll feature. Agree with PD68 though - would be nice with a bigger head, but I'll still take 1-2 as-is.
That one looks very similar to an hd2010, with a bit different machining in the head.
Looks like a mix of the HD2012 and the new L2. The metal around the driver pocket is very thick, reminds me of the Convoy X3
For the sand/ desert tan lovers.
That looks great
Woah! That sand color looks nice. Do you have a link?
THIS is well known arround here but not at that LOL price, i do hope it would be at least as good as those i bought several years ago
Bought one for evaluation ofc, will keep you updated
Search Moon Lake brand for product.
Product Features
• Using one CREE XHP70(cold white)LED, life time up to 100000 hours.
• Max luminous fulx is 1600LM.
• Two modes (1) high mode 1600LM (2) Low mode 800LM.
• Light range 500M.
• PC plastic lens.
• Orange lamp cup
• CNC processed aircraft aluminum shell.
• Military standard Ⅲ grade hard anodize oxidation and wear-resistant treatment.
• Magnetic control rotary switch.
• Power indicator function.(When low battery, the main LED will flash one time per second, After five times, the working lumen will be low to 320LM).
• Batteries: 4*18650 3.7V rechargeable lithium batteries.
• Dimension: 166mm(L)*68mm (Head diameter)
• Weight: 550g( exclude batteries).
Parameter
ANSI/NEMA FL 1 High Mode Low mode
LUMINOUS FLUX 1600LM 800LM
RUNNING TIME(HIGH MODE) 140minutes
MAXIMUM BEAM RANGE 500M
MAXIMUM LIGHT INTENSITY 11000cd
ANTI-ROLLING HEIGHT 1M
WATERPROOF GRADE IPX8(underwater 50 meters)
Are any of these host available for purchase? Love the tan F8 host and that 26650 light.
