I bought it from FastTech, along with some 10, 25 and 45 degrees ones.
I’ve tested them in multiple lights and found that 45° is really useful indoor !
can you direct link those?
60 degree
45 degree
25 degree
10 degree
Oh, just for the info you have to slightly grind the outside of the optic to make it fit the HC30 bezel
Is it just plug and play?
Like I said, you just have to slightly grind the outside (less than a mm on the diameter)
Congratulations, you can make a review of how you did with pictures and some beanshots?
thanks
greeting
Yeah I may do that this week-end…I’ll make an update
thanks
So, you just unscrew the bezel, then drop the o-ting, glass and reflector :
Stock reflector vs TIR :
You have to slightly areduce the TIR diamter by filing it :
You then just drop the TIR and put the o-ring, then the bezel :
Stock beam at 15cm and 1m :
Now we are talking!! Thank you!!!
Ordered 45 degree model thanks for the info
Thank you
the higher degrees more open?
the spot fades with more or less degree?
Yes, the higher degree provides the more spill (more opened beam).
The spot is quite inexistent with those type of optic
anyone knows a 100 degrees TIR optic mod for the HC30?
Shop?
thanks.
I don’t think you can physically get a 100 degree TIR, the specs are for HALF the angle of spread (ie a 20 degree optic will give you a 40 degree cone).
I switch the led for a warmer last year, change it for a XM-L2 4D. This is how it looked inside. Maybe you have fixed it by now. There is more pics if some one needs.
Thanks for the review!
how you did unscrew the bezel? i can’t get any grip on it.
I used the rubberized side of my mouse pad, pressed down across the top of the bezel with my thumb and twisted. I had to replace the driver in my HC30 already. :~
It worked thanks.
Only problem is that this is no longer waterproof.
. . . Ya, with the bezel and lens removed it would not be waterproof.
