I also prefer fixed blades. They are much more substantial. It seems Folders are more popular, but I always feel like eating a Whimpy burger after I open one up. I’m pretty sure Popeye carried a Ka-Bar.
Has anyone ordered a fixed blade from Gearbest and actually received the knife? I noticed a few people posting they were not receiving their knives from Gearbest. I ordered a Cima knife over a month ago: nuttin so far
They are loosing a lot of fixed and folder knives if you did not pay the tracking number. My g720 was lost but resended after. The problem is the post, each time is more difficult to send knives.
Yes i know popeye, but from i was a kid. “Wimpy” was “Pilón” in Spain. Still i do not know very well the burger and the feel using a folder but, it does not matter xD
The only Cima folder I’ve used wasn’t good. The fixed blades they have are good… But there are sheath sheath QC problems for some. Finding a good fixed blade under $20 with a good sheath is nearly impossible.
The standard Mora Companion, yes, has a thin blade. Look at anything in the Mora Robust, HD or Craftsman line… not so thin at all. The Mora Bushcraft Black, as well as the Mora 2000, issued to Swedish military ground forces, all have thicker blades, up to 3.2mm
Mora of Sweden makes more than just one style of knife blade.
I know it. But some of them are much more expensive than 20$, like the mora black. Others are thicker and cheap but only the carbon steel ones (i do not buy carbon steel because i hate maintenance).
In all way, you can find 4mm to 5mm blades down to 20$ from chinese market.
I purchased one of these Schrade SCHF36 and ended up sending it back twice because the blades were curved. I didn't expect a whole lot from a $30 knife but I couldn't live with a bent blade.They get great reviews but my experience wasn't good.
It seems like it would be less expensive and easier to make a fixed blade knife than these Axis folders with all of the different materials and assemblage .
I don't even need a sheath or handles just a few holes for paracord will do.
That’s true. You can get thicker blades in that price range. The quality may or may not match a Mora. But sometimes thicker blades are less useful. It depends on the intended purpose. Thicker blades will not cut all materials as well. The difference can be seen in the Mora Companion vs Companion HD.
Going from a 2.0mm blade thickness to 3.2mm puts a good amount more metal behind each cut.
And both balde thicknesses are available in Sandvik stainless. No need to buy only the carbon steel if you don’t want to.
But, if you happen to need or want a thick 4 or 5mm wide blade, go for it. Those will lend themselves well to chopping tree limbs and the like. But 5mm is almost a solid 1/4” wide. That’s a hell of a thick blade. Thems’ be Becker BKx territory!
Looks like a lot of clone stuff, using what used to be good brand names out there, just like everything else, but as far as quality, you probably will not know till you get into the real knife forums more, or try buying some stuff. I see some stuff in those searches, that I would try for $10-$15, if I were into fixed blade, but folders have come so far, I don't think I would ever bother with a fixed blade any more, where I couldn't conceal it easily.
The objetive of the thread is to share experiences with chines fixed knives good, if it is possible, true bargain gems. Knives that we have buy and were a great surprise, or simply were good for the price.
In my case:
Buck 480: for the price is ok, if the steel is really 8cr13mov. Good sheath (for you can expect), full tang, beautiful wood handle. But finish so so, scratches on blade, and top of the blade bad finished, a bit like a home made knife… But it is ine of the most popular cheap knife with a lot of reviews, in fasttech. Sharpness is so so. Less than 9$.
The colt in 8cr13mov, too from fasttech is well done, well fit and finish except for the screws that are crashed, but well sharpened. The sheath is horrible. About 9.50$ or so.
The buck 2008 usa design: almost 15 cm of blade is very good, 440 steel, bad finish on the blood lines (i do not know how i can say in english), the wood of the handle does not fit perfectly on the blade but for 11$ are great, good design but finish is not the best. Sheath is soft, like leather but it can not be it.
