New Convoy Deep Carry clip
Thanks. I meant to comment earlier. That look great. Then again if you move it one groove higher you get the true deep carry position but that’s just my opinion. I like that the design gives you a couple mounting options. :beer:
I have them on the top groove after I took that pic lol I’ll take a pic and post later too. The design does give good options and the top grooved is still sturdy as well. I even reversed the clip and had it mounted on my hat the other day when I went night fishing so it does it job nicely.
It even works well in the reverse position? That is AWESOME! I didn’t think that was going to work well until the release of the next S2+ which BTW will have a groove near the head as well specifically for the hat mount. That should prove stellar in the 18350 version. :wink:
I have to say, that blue S2+ with the black clip looks awesome.
How accurate is the blue color that picture? Seems deeper than Simon’s pictures. I’m liking the deeper color a lot!
I have a blue S2+ and the color is more like the one you posted so quite deep yes
So how well do these work with heavy blue jean pockets? The bend looks like it might be wide enough and that is the problem I’ve had with every deep-carry clip I’ve had so far. I wear denim most of the time and always at work.The BLF A6 clip is awful in that regard but if this one is good I’ll order some.
Phil
It’s designed with a 1/8” (3.1mm) gap. It should fit all but the thickest of jeans. It will definitely be better than the BLF clip but I don’t have mine hand yet so I can’t give you a first hand report. The A6 clips on all of mine were too narrow to fit over jeans without re-bending.
Nice clip but looks a bit like it maybe a loose fit if used on thin material clothing…
LOL… See? You’ll never make everyone happy. :stuck_out_tongue:
Edit:
In case you are serious I don’t think that will be an issue. The tension that holds it in your pocket is at the point where the bend in the clip (see circled below) meets the body of the flashlight. This should work fine on thin materials as well as accommodating for the thickness of most standard jeans since the spacing in the upper portion of the clip allows for a bit thinker material to slide in up to the radius where it rests. :wink:
Hmmmm…. Richard needs to stock a supply of these. Of course, he may have a hard time unloading the 71 stainless steel old-style clips he has in inventory now…
:weary:
Good news and bad news…
The good news is Richard has a bunch of the new deep carry clips ordered.
The bad news is I didn’t think about his existing stock of the old clips when designing the new. There has to be some good use for those old clips. :~
Richard, we’re still friends right?
I think that there will still be plenty of people who like that look, material, or style, so no worries!
I'm excited to get try them out, they look pretty cool! It seems like whoever thought of that actually uses these lights...
It seems like every time I get a new Convoy shipment and there's something new in there I end up building a light to test out all of the new stuff, and I'm sure that this time will be no different with the L2 and new carry clips coming.
Don’t suppose there’s any codes getting around for these clips? I need 3 of them.
I have some, well five actually, of these coming. The BLF A6 clip does not slide well over my pocket even after bending it out a bit. Sure hope this is a solution!
You would know :slight_smile:
I think they look pretty cool too but that’s just one opinion…
I sure hope their performance is on par with their looks. I’m expecting a package with the new clips and both styles of the new L2 tubes any day and I can’t wait to try everything out!
My son has been bugging me about getting the clip since I started working on it. He received a blue S2+ for his 10th birthday this summer along with a high quality protected cell from some store in the mountains of Utah. :wink:
Now I’m just waiting for the RMM special edition build of the L2 to take that light to new heights!
They’re just over one dollar each. :expressionless:
I’m a major bargain hunter too but I’m not going to ask for a code on these.
If he offered the discount you could potentially save 82 cents on an order of 5 pieces…
Deep carry clip, the thing I’m looking for.
I like the screw on clips for some applications, so I am glad they are still going to be around as well… They screw on after all. That said, I have some of these on order as well…
Thanks J-Dub74, and of course big thanks to Simon for all his work!
Shows $5.48USD each for me
That’s not each. They’re sold as a 5-pack.
