I’ve read some of your posts around the forum and I think you’re a magician in what you do. Crazy good work! And I’d love beeing able to reflash my drivers directly in the light. When I said it hasn’t been doen before I meant three channels on a tiny13A. At least I don’t know of anything like that. In your other post, I think you confused PilotPTK with Bocian. Bocian was the guy that made that 105C-based tiny25V driver, he’s also admin of a polish flashlight forum, AFAIK. Threads of his can be found here and here.
Thanks for the help! I’m the opposite of a wizard at this stuff.
Minor point, but it would be better to use something like 245 for turbo instead of 255, so that 255 is still open to be used as a pwm value on the larger bank of 7135’s
Yes, I missed that subtlety as the original BLF A6 firmware mixes FET PWM values and mode IDs in the same array. So there turbo needs to be 255 as it is used both as an ID and as a PWM value. This new version with TURBO in the array is definitely clearer (should be used in MODESNx2 too, I think). You may not be a wizard but you’re not half bad either if you can pick this up.
Sooo with this driver it should be possible to do the following modes
Moon, Low, 0.35A, 2.1A, Turbo
where the last three modes are non pwm?
If you use 350ma 7135’s, yes. (380ma would give 0.38A and 2.28A). Or if you want the ‘high’ mode to be lower (like I do) you can just leave off some of the 7135’s on the back.
edit: and you can have the top 7135 on at the same time as the other 6, so technically your ‘high’ mode could be up to 2.66A
Ok, great!
I think you confused PilotPTK with Bocian. Bocian was the guy that made that 105C-based tiny25V driver, he’s also admin of a polish flashlight forum, AFAIK. Threads of his can be found here Polish project: Extended version of Nanjg 105C driver based on Attiny25V and here Extended ver. 2.0 of Nanjg 105C driver based on Attiny25V.
Oh yeah, the baby face avatar. Yep, sure got ’em confused up, just as I suspected Thanks to you and pilotdog68 for sorting it out… and for the nice comments, but I’ll stop hijacking this thread now I think.
…but I’ll stop hijacking this thread now I think.
I usually don’t mind it actually. Even off-topic chatter keeps the thread on the the main page and gets more attention. I like when people test/use something I’ve made.
Hmm every link from the first page to oshpark brings me to their 404 page.
Edit: Is it possible to add a pass-through for an LED+ wire like in your DoubleDown driver?
Yeah sorry, I took down the links to make the upgrades I mentioned in post #47, but I haven’t had a chance to put them back up. Hopefully tonight I’ll have the links updated.
Sorry, I just don’t think there is any way to fit a big hole in this mess. The 20mm Rev1.1z does have the hole though.
Ok, post 1 is updated with new links to some boards and all links are active again.
PD I’ve tweaked the firmware you linked now compiles ok.
HERE
Good news, Gents! I just did a brief test this and I could only find one issue: turbo timer/stepdown isn’t working. Once that is fixed, I think we will be set. Mode switching back and forth between channel 1/2 and toggling FET on/off works perfectly.
That’s all the time I have tonight, more tests tomorrow.
Thanks for working on this Pyro, I really appreciate it.
No worries glad it works I’ll try look at the turbo timer later
With the kind help of pyro1son and DEL we now have a working firmware. It is essentially BLF-A6 modified to work with the output configuration of this driver. It has not been extensively tested, but appears to work great so far. As uploaded, it is configured for testing correct driver function. You will want to change mode, turbo, and LVP settings before installing in a light. Here is the link.
Can I use this driver`s hardware (with some modifications in software) to implement a locator function with blinking secondary red LED?
Can I use this driver`s hardware to implement a locator function with blinking secondary red LED?
Yes
May be I don`t understand smth, but where I can get full components list? Is it standart and needs only pcb, some parts kit like 17/20/22/30mm FET+7135 Driver DIY Parts Kit - Single-Sided LFPAK and several extra parts with MCU re-programming?
Yes, that parts kit is most of it. It’s just missing the extra 7135’s and you will need to reprogram the mcu like you said
Is there someone subscribed to this thread who could help me on a driver mod? I plan on doing some testing today, but would really like some more input before I do. I am attempting to use the battery indicator circuit from one driver and connect it to another.
The details are here: Nanjg 105c + Lumodrv + voltage indicator on switch Help Updated?
Sorry to poke my nose into this thread. If this is not appropriate, I appologize and please delete or disregard my post.
Thank you all…
