i ordered one of the: NITECORE MH27 CREE XP-L HI V3 1000LM
thank you!
thank you!
Add me to x and b3
Please add me to the UNI-T UT210E interest list.
B6 Group buy - UT210E is online. All PM sent. 80pcs of UT210E are in warehouse now.
UT210E ordered. Thank you!
If it’s still possible, please add me to the UT210E list. Thanks!
2pcs. of UT210E ordered, Many Thanks to Freeme
Ordered; B6) UNI-T UT210E.
Cheers :beer:
UT210E ordered. Thank you freeme!
Hope it gets shipped before Chinese Newyear. Waiting to compare the readings of this one to those of my old DMM.
UT210 ordered thanks Freeme !
1 UT210E ordered.
Considering another, will let you know. Thanks!
Please add me to UT210E.
Thanks!
1 UNI-T UT210E ordered. Thank you.
Same here. Thank you freeme :)
Ordered one UNI-T UT210E
Thanks.
Ordered using your link.
Thank you freeme and PD!
(Already posted early this morning, not sure where the post went…)
UT210E ordered. Thank you freeme!!
Just a pointer, to help remind people of what to expect. If your light is pulling low amperage the clamp meter and any old DMM are going to be quite similar on the reading. The higher the amperage, the more difference there will be. If you have a seriously high amp light like a triple or quad, the DMM will be WAY below correct, might even be damaged. The clamp meter keeps on ticking, mine (Mastech MS2108A) reads up to 40A. I’ve seen low 30’s, but not quite high enough to start worrying about the 40A limit… yet.
5-6A lights will commonly have a .5-.7A difference with the DMM being the lower, possibly even 2A or more lower if you’re using stock leads. Lights of 8-9A are pushing the envelope on most DMMs as 10A is generally the top end, although there are those out there that claim to read 20A they typically don’t show an accurate reading with the small long stock leads.
I bent the bare ends of 12 ga household Romex over to fit in the meter and found my old cheap Velleman to read pretty close to accurate (with these 12ga solid copper “leads” about 6” long), but the clamp meter still shows a little higher. This Velleman is nowhere close with stock leads, and this is around 5A I’m talking about.
The clamp meter comes with normal leads for reading voltage and testing continuity, that kind of thing, so the clamp meter still has normal DMM capabilities. Those leads will plug in to the bottom of this meter, I generally remove em when using the clamp, seems I read somewhere that they shouldn’t be left plugged in to the meter when using the clamp but I could be wrong about that.
Those high amp readings are exactly why I wanted this meter. I have totally fried one DMM with too high of current, and at least blown the fuse on a second.
Question: with a clamp meter, will going over the “range” rating actually damage the meter, or will it just give an inaccurate reading? For instance if I accidentally measure 12amps with the “2amp” range setting, will I damage anything, or just have a wrong reading?
