Does anyone have a Xiaomi USB LED light?
62 posts / 0 new
LightsCastle
LightsCastle's picture
Last seen: 4 years 6 months ago
Richie086 wrote:
LightsCastle wrote:
May be you can go to lightscastle.com There are origainal xioami USB light. Hope it will help you.
Thank you LightsCastle. Just ordered 4 pieces from your website.
Order LC1505289SF0W has been paid successfully
Thanks for your order.We will dispatch the items ASAP.
A professional website selling flashlights, wrist watches, lasers, chargers, batteries and other intersrting outdoor sport products
atbglenn
atbglenn's picture
Last seen: 2 years 5 months ago
Got mine today. For the price I paid ($2.09), how can you not like it ?. It's fairly bright and built well..
Boycott Nike
Rolz
Got one a couple of months ago. Haven’t found a use for it yet, but it is very well made and quite bright too.
atbglenn
atbglenn's picture
Rolz wrote:
Got one a couple of months ago. Haven't found a use for it yet, but it is very well made and quite bright too.
I haven't found a use for it yet myself. It was cheap enough. I couldn't pass up the great deal GearBest had. Call me an impulse shopper, I get it....Guilty as charged...
Boycott Nike
UDO
Last seen: 6 months 1 week ago
Geekbuying had them for 1.09$, verified originals…also bought (too) many. I use them for:
- gifts
- work light (soldering, car repair stuff,…)
- macro photos (several of them from diferent angles, well difused light)
- behind laptop and lcd monitor (running 24/7) for ambient lightening – these ones have added aluminium foil+thermal paste
Richie086
Richie086's picture
Last seen: 12 min 58 sec ago
Wow, you’re not kidding. Just received my USB lights today. Was not expecting them to arrive this quickly to New York this fast. Arrived very well packaged and all in perfect working order.
Thank you LightCastle. Next flashlight order goes to your company!
Richie
L4M4
L4M4's picture
Last seen: 7 min 33 sec ago
I finally got my 10400 Powerbank today (Actually it’s my second one – but this time it’s an original one that I don’t have to throw away…) – with green silicone-sleeve and fitting grteen LED Light.
If they only made that little ventilator also in green…
I like that light – the CRI isn’t great, but it’s bright and looks nice (and it’s cheap).
joevik
Hi, i received mine yesterday. Turned it on and after about 2 minutes, there was a burn smell coming from it. Is that normal?
CrashOne
Last seen: 1 day 6 hours ago
No, mine doesn't smell.
Ran min on a genuine 10400. Don't know how long the total run time was, but it was running for at least 24 hours. I wish there was a moonlight mode or a version that was less bright and could run much longer. Just as a backup or for longer trips.
joevik
Its probable that i got a defective item as there is quite a strong smell. I’ll avoid using it as i would not want for my power bank to get damaged. I will contact the seller and hopefully he/she sorts it out.
joevik
UPDATE: I received a replacement light and it does not have the burnt smell.
I have also remove the diffuser and the light is very very bright.
sixty545
If anyone is interested I measured the Tint and the output from two of these handy little lamps (org. Xiaomi, one blue and one red).
They measured very close to each other although I could see a slight difference in tint.
The blue one: xc,yc= (0.414 , 0.422) = 3514K , 82 lm
The red one:   xc,yc= (0.414 , 0.419) = 3498K , 78 lm
The color point corresponds to a bit greener than BIN 6B3, one could call it 6S, if this was defined in the BIN chart.
I intent to experiment with adding some red paper or a rosa filter underneath the diffuser to get rid of some of the green, but it is usable as is.
Beware, there are (unknown) tolerances on these measurements although I am more confident with the color measurements than the lumen measurements (Used instruments: Color Analyzer and Integrating Sphere).
power911
power911's picture
Last seen: 3 weeks 13 hours ago
is it just me or I can’t differentiate the quality of real and fakes?
I know I got a fake one with less components (as I only see couple of resistors and brown square blocks which i assume capacitors? I see no 3 legged components)
but it seems like the fakes I got has a brighter output and draws less amps compared to the real deal. (about 0.15A)
They both get warm after 20 minutes of use though
Nevertheless they are very cheap for something so bright
“Have you forgotten about all those who called you a Bringer of Woe and hunted you like an animal?”
“Normal humans don’t go around killing people and burning towns!”
“Don’t worry. I’ll go with you! So you just follow me and no arguing, okay?”
Ormbett
Ormbett's picture
Last seen: 3 weeks 5 days ago
The genuine one are often heavily discounted so no need to buy fakes for that reason. If you have the genuine light you can turn it on and off with the “power button” on Xiomi Power banks. That feature also applies to the Xiaomi USB propeller(fan). I just wish there was a easy way to adjust the brightness Smile
Mitko
Mitko's picture
Last seen: 11 months 3 weeks ago
I got several of those, they are good quality ones EXEPT for the emitters, they all do have a terrible CRI- under 50: and i am talkinf of original MI ones ( bought from Bangood)….the emitter can be easy swapped with a quality 3014 or 2835 one, dont swap it with 3528 ot 5050- those dont have a coooling pad underneath, any 3014 or even 5630-5730( swapping here will be tricky) will do, Samsung has very good cri 80+ emitters out there- they costs cents too
travis
Last seen: 2 days 16 hours ago
FWIW—I live in SoCal ( Costa Mesa, Ca)
and my local “99 cents only” store has these
USB lights in stock now—for 99 cents!
Not sure if they are Xiaomi-but they have
them in white, black, pink & purple.
Its brighter than I thought it would be Smile
“"A free people ought not only be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government.””
-George Washington
L4M4
L4M4's picture
Surely not Xiaomi, more likely to be this: m.aliexpress.com/item/32584076179.html
But still a very nice price
polygon
Last seen: 4 years 5 months ago
and Xiaomi has this too, on/off switch and output adjust.
http://www.gearbest.com/electronics-gadgets/pp_280338.html
sixty545
polygon wrote:
and Xiaomi has this too, on/off switch and output adjust. http://www.gearbest.com/electronics-gadgets/pp_280338.html[/quote]
[Edited: Added memory and current draw]
I have one of those new ones. It is very nice and with 10 LEDs (old one 6).
The greenish tint is gone and it cycles through 5 levels (with a push button) with memory:
(OFF) - 0.5 - 8.1 - 39 - 107 - 169 lumen (against the old ones 87 lumen) measured in my integrating sphere (a little difficult with the long head, so I put it partly into the sphere). The color temperature was 3700K (The old one 3560K).
Current draw was 0.09 - 0.11 - 0.18 - 0.24 - 0.46 A
Now the price needs to come down.
L4M4
L4M4's picture
Nice information!
Seems like I need 2 of those Silly
I have one old Xiaomi and one fake light. Both are well made but the light colour of the xiaomi was never the best.
I will give it a try.
I love Xiaomi so much Big Smile
Smartphone, Controller, 3 Powerbanks, lights, InEars – all made very good and cheap.
Milan
Last seen: 1 week 1 day ago
Are you sure about this? As it would make it terribly inefficient in the low settings.
You might forgot to watch the scale.
bugsy
Last seen: 5 years 3 months ago
I have the xiaomi light and fan. They are fine – some extra garbage to sit in the drawer and never get used.
sixty545
Milan wrote:
sixty545 wrote:
Current draw was 0.09 – 0.11 – 0.18 – 0.24 – 0.46 A
You are right, it is inefficient at low level.
Vladimir
Vladimir's picture
I’m extremely satisfied with Xiaomi usb fan.
I used it last summer for 3 whole days of nonstop working without any problems-my laptop fan died and I took off the
bottom cover of laptop and used the Xiaomi to cool it down while waiting for the replacement fan to arrive.
Milan
That’s a bummer. In that case I’ll pass and stick with the classic – powered with just 2 half depleted primary cells, it makes nice dining lamp, and lasts for days.
joechina
I am verry satisfied with this lamp. Nice tint, no PWM and on the 2th level bright enough to light my keybord. In connection with the windows software f.lux I could get rid of all blueish light of my notebook.
samgalax
Last seen: 15 hours 43 min ago
Video showing the different level outputs… not HD video but… it helps to see (more or less) how it “shines” at the different outputs… (I think the lowest one is useless unless you want it for preverving night vision…)
https://www.youtube.com/watch?v=VXMLzCarNEA
If the info is correct… the 4th mode draws the same current than the old one…
Interesting
Please SUBSCRIBE to my youtube channel (flashlights, electronic gadgets and various stuff..)
https://www.youtube.com/channel/UCCF3RcoQ3Ff05Cr4-Gg5qAw
I am a beginner. So please help me to make the channel "grow up"
Thanks!!
joechina
The first mode is useful for reading a book, laying on your back. Lay the power bank on your belly, the head of the lamp right under your nose.
Lennart
Lennart's picture
Saw someone who made a decoration lamp of one of those usb chargers with five or six outlets filled with these xiaomi lights.
Lennart
Lennart
Lennart's picture
Use one in the usb outlet on the back of my TV. Got the idea here: http://bgr.com/2018/01/03/tv-led-backlight-kit-eveshine-amazon-sale/
Lennart
