Not physically stacked that I am aware of but with more 7135's. The single 7135 was basically a method to achieve a regulated "Lo" that many complained was either "to the moon Hi" or a "subterranean Lo".
Wight and PilotDog68 both have drivers with more than one 7135
I dunno. With 4 or 5 nice well spaced modes, only 1 mode (32%-40%) uses PWM's on the FET typically. The lowest 3 including moon use the single 7135. One full 7135 mode does like 120-170 lumens roughly with a good NW or CW LED, good AR lens, so that's like 10% typically.
4-5 modes are my favorite settings. Adding another 7135 has no advantage that I can see for a 4-5 mode set.
Am I missing it, but is a FET+1 OSHPark driver available anywhere, from anybody in 20 mm size? Anyone have an interest in making one if it's not around?
I really miss this wight FET+1 driver in a 20 mm size...
Oh thanks PD68! I just looked at my OSHPark order history - did order these boards back on Nov 7th(silly me ).... I ordered 22's, 20's, and 17's. K, I know I need the 20's for a couple of projects, gotta get organized better..
One of these drivers, loaded with the BLF A6 firmware, acts like it has next mode memory. Anytime I cut power, it moves forward. Does not appears to be related to time spent off.
So, in moon mode, click off for 10 seconds. Turn on, it is in mode 2. Click it off for a few minutes, click on, mode 3.
etc………
Suggestions on what to change? I have a stack of these that work. This one I reflashed, and replaced the OTC.
I have the same problem in one of my drivers. I think I need to run offtime-cap on his driver and adjust the settings in the firmware. Hopefully this solves the problem.
Usually that indicates a hardware problem, but the offtime-cap.hex firmware can at least help diagnose things.
I measure the OTC a few times at 0.5s, 1.0s, 1.5s, 2.0s, and 3.0s. This provides a good estimate of the discharge curve, and the values can be plugged into code to select whatever timing you like. Here’s a graph of three different drivers measured this way:
The blue line is close to ideal.
Of course, if you get 255 every time, the OTC isn’t working at all.
I didn’t read all 286 posts… but perhaps this can be useful:
The stencil for Attiny:
actually, when I was starting with attiny85 I learned that the legs can very easily be bent downwards, it takes probably less than 1 minute
That means that the actual footprint for the attiny13/attiny85 can be smaller than official contact pads spread - if you bend the legs downward - the contact pads can almost all be under the MCU itself, not extending so wide around it.
If you test with TK’s firmware and find that it’s simply discharging extremely slowly for some reason you could add a pulldown resistor from the MCU (ATtiny) side of the OTC to GND. High value, maybe 100k or something (I don’t know).
v014 was never published, here it is. Untested (would you expect any different? ;-)). ” 17mm DD + single 7135 v014”:OSH Park ~These updates are actually very old of course; I still haven’t done any updates to this board since I came back to the forum.
It’s got a star on the bottom which is hard to see due to OSH Park’s rendering. IIRC my star is barely within the OSH Park design rules. This is the same star I used on the A6 version, but apparently the Chinese fab wasn’t confident about producing it so they changed it to a more conventional / larger one.
I’ll note that the star is a potential dead-short hazard if you use a spring >11mm. If your spring is 11mm OD and you install it w/in the provided area you should see no problem. 12-13mm OD might fit but could easily short and a lot of care should be taken. What would anyone be doing with such a large spring anyway!?
I didn’t want to be left out. Here’s a simple expansion of the v014 17mm board to 20mm. ” [untested] 20mm DD + single 7135 v001”:OSH Park ~
