Bummer on the increased price.
That thing looks like a jumbo ZY-T08
+2 . What are those connections on that light? Probably 63 mm head diam? 170 mm long?
Charging port, three LED power indicator and a mini warm white LED near the right edge.
62mm head, 170mm length and 650g (incl. batteries). Unfortunately, no OP reflector again.
Looks nice, but modding possibilities are limited I guess.
Looks rather interesting. Might be able to run on high for quite a while with the extra mass. But is that a switch at the tail cap? I hope not
With all the poor market activity and the shutting down of the market almost daily, I would imagine there's enough turmoil and fear right now, that prices would go crazy, so not too surprising. I am looking to see all the prices go up, after their new year.
Well it would be very bad for their econody cause noone can affort to rise prices with those insane low levels of rthe oil and the spendy dollar- yet their own currency devalves regulary compared to USD just to keep the price levels intact- so there is no reason for that- spoken globaly ofc
Yet , 2-3-5$ bigger price wont chill our modding needs anyway :bigsmile:
there will always be some problems. Are there any new updates on the modding of this monster?
No, sorry. The further mods I'm planning weren't probably gonna result in much increase in throw. If I could get a reliable 5+ amps out of a XP-G2, that would be great but all the ones I've reflowed/tested are much lower w/domes or de-domed - didn't matter. Still, I'm pretty pleased with the results of a de-domed XP-L from FastTech, no less... FT is certainly not known to be a reliable source for LED's.
If I had lots of time (I would need it) I'd try a 2S2P cell setup and go with a buck driver I could get 5-6A out of with a de-domed XP-G2.
The other path that Dale, O-L, and others would take is a big emitter and do the 2S2P cell mod. Probably no one could do any better than those two, and O-L has a BOSS1 on the way. Not sure if Dale decided on it yet.
As freeme said earlier, they gave us a big canvas to paint on with this host. It's not a beauty, but sets the bar high for reflector width and cell capacity in a budget level cost. It seems like GearBest is our best option for now, if you can get one of the remaining pieces as O-L mentioned.
I might order one, but after spending $250 on the SS/Cu and alum X6/X5 sets plus a few other buys as of late, I'm a bit tapped out for this month... or two .
I hear ya!!! GB’d out!! XP-G2 performance blues too!!!But I got a TM36 that I’m hesitant to mess with, because it’s just too beautiful, I absolutely love the big beam that throws as far as my modded Couruis’ and lights almost twice the area up? Beside I can’t see 900Kcd away any how? :bigsmile:
which buck driver do you have in mind?
Tom, I believe I have a couple of older XP-G2 in 1A tint if you’d like to try those, might get the power level up… don’t know if the output would be any more. Seems I’ve seen some 1100 lumens before from one.
I was hanging in there waiting on the group buy, almost got one from GearBest but went the opposite direction and have a tiny little MecArmy PT16 on the way.
For buck, probably Richard's - think it's compact enough to fit - didn't measure it out though, but there are options - lots of space - could even cut out a hole in that huge plate if more space is needed.
That PT16 is pretty nice - looked at it... No time right now though for the BOSS1 - other things goin on. Wish I could get some time off from work, but we are under a lot of pressure.
I have ordered one, cant wait to mod it!
I have some xml-2 U2 1A that have not been used. Will I see more light and throw from a dedomed xml-2 U2 1A on a direct drive than from a dedomed xml-2 U4 1C or is the resistance to high current at cost of throw and output so the kcd would be the same???
The U2 1A vs. U4 1C has a lot of variables. Yes - you can probably get ~7A from a U2 1A vs. 5.4A on a U4 1C but there's diminishing returns on the higher amps. I know Richard reported higher output from U4's vs. U2's for DD FET builds, but that was specifically on SupFire M6 lights (SRK style) with the 3 LED's in parallel.
Actually, for my recent Yezl Y3 mods using U4 1C's w/DD FET drivers, I hit 1900 lumens on 3 different lights which I don't think I ever hit on a U2 1A DD FET. 1700 was about the max, I'm pretty sure.
OK, I choose 18650 as powersources (makes the choice what to buy easier for starters :laughing: and like lights with 26650 size, since a triple AAA would work there as well (makes them good gifts)
This boss really look like a boss and is tempting, but i am not going to get 26650 cells.
With sleeves 18650s fit and 12 AAA as well. Would the output and user time be any good using decent 18650s?
What would be the consequence of using 12 AAAs?
Sure you can use 18650's or AAA triple carriers. AAA's would probably kill high output though, but never seen any attempts to use 4 of them in one light.
well IF it comes to ordering this big guy I will surely pop in 12 AAAs just to see how it works
I am still not certain which emitter is the best choice for this light for a DD without a driver. What should I get if I want to run it without a driver? A dedomed xm-l2 U4 1C or dedomed xp-l V6 2C?
