This has been ordered, but not received or built yet…
Courui D01 Contact Board V3
Matt
Autocad is not for pcb design.
So there is not going to be any automated way to convert autocad to gerber.
Let me rephrase it then. Can someone recreate the autocad into a gerber?
Did you post your DXF/whatever somewhere? A straightforward conversion would be to export bitmaps and then use Eagle or KiCad to import the bitmaps into layers. From there you can export a set of gerbers.
This process can generate rough edges. In the past for my own purposes I’ve exported high resolution bitmaps at 4x my desired size. I would then import them into KiCad and save that. At that point I’d use a web service to reduce them to 25%. (the web service is intended to help fix stuff like putting logos on silkscreen art). Once they were reduced they were the correct size of course and I’d reopen the files in KiCad and export gerbers. It’s a lengthy process because you must do it for every layer. Good luck!
I got a batch of boards with empty ring on the edge, but i thought it was a fault because the LED+ was not exposed and in the second batch were copper to the edge.
Seeing the second board i didn’t know why OSHpark recommends at least 15 mil (0.4mm) clearances from traces to the edge of the board, but now i know there are variation between different fabs, it makes sense .
Great tip, i’ll put into practice.
Yeah, that kind of change is a bummer. I have about 500 17mm boards with no exposed copper behind the FET. Same exact file I had already ordered dozens of times, but the time I went to order the most look what happened!
If you look at the silkscreen and milling/drill hits you can often tell which Oshpark fab they were from. I can distinctly tell the differences between them, but you never know which one you're going to get.
It has been a lot of time since i posted v004 (I have been a bit busy due to exams), but today i’ve finished a new version.
Theese are the changes from v004:
–0603 diode pads (for zener mod)
-More exposed copper on top GND ring
-Added copper pour under MCU for temp sensoring
-Wider bottom GND ring near FET vias
https://oshpark.com/shared_projects/tjm3DzQH
As always, any suggestion will be welcome.
Nice, one question is it “only” a design change to wights A17DD-L or is there any extra functionality?
Is it possible to drill through that LED+ pad and push a cable through? Could you already make a hole there? This way you can use the same cable to bypass the spring and to get to the LED.
Hi finges,
there is an extra funcionaltiy, pads for a pull down resistor (PDR) to avoid "turbo to moon" blink.
I doubt a hole could be drilled, but i can make it in the design.
Stay tuned.
This version has been replaced by v006: Oshpark Projects - #1686 by Pablo_E
Done!
Hole (actually is a via) is 2mm/0.0787inch in diameter.
https://oshpark.com/shared_projects/rVrw8a4J
Very nice Pablo! Thank you very much for sharing. Only thing I’d like to see changed is the 0603 cap, I would prefer 0805 for an OTC.
+1
I think if you moved the FET pull-down resistor to right above the FET, you would have room for 0805 pads right at the top of the board.
Or rotate R1 90 degrees, then you can fit all three resistors side by side closer to the center, leaving plenty of room for a 0805 OTC pad.
But myself, I wouldn’t bother. I use 0603 on all my boards.
Don’t you consider soldering a 0805 cap on the 0603 pads?, I don´t know how difficult it is, but it fits (like in the right diagram)
Do you prefer the 0805 option?, if so it could be done performing both of your suggestion, i see some potential clearance problems but i think they could be solved.
Yet another untested monstrosity… This implements what is intended to be a snubber for 1s applications, plus a bleeder for pilotdog68’s tailcap LED system, plus an OTC pulldown, plus a gate pulldown, plus a 3mm via for the BAT+ wire. There was no space for a BAT+ pad on top, so it’s bypass or go home. At first I thought that I was going to be forced to increase my normal 1mm physical keepout, but somehow I got away with it.
This version has been replaced by v007: Oshpark Projects - #1686 by Pablo_E
This board is really dense populated! you made a great job!
I have already changed OTC pads size to 0805, i have had to remove some vias, and voltage resistors may not be easy accesible, placed that way between tall components, but i think it is done.
https://oshpark.com/shared_projects/0NAo2EmQ
Thanks.
Your board is clearly improving, but here are a few things (in no particular order):
Thank you too! it is improving thanks to all of your help.
I going to reply in the same order:
where did you get your clip Pablo?
Is a chinese no branded one you can find on ebay, aliexpress and many other sites.
I got it from this seller: Henny Liu’s store , but i don’t recommend him/her as i got different clip from which is shown on advert images, so random version could be sent.
Here is a pic of the clip i have:
