You can definitely get them down low. I helped Dale with resistor values to adjust his special editions. He got them down to 0.14ma draw. I recommend the 50k pots. On my board you can use just one pot, but it’s a little useless without the mini slide switches.
But I admit, I’ve no clue how to code it, too. Something like Battcheck maybe…
As for the stacked board, you think the LEDs would go right under the boot? It’s the thing that presses the tailcap boot against the housing to make a sealing, right?
yes, this ring replaces the washer, putting pressure on the bottom of the boot to seal it up. I measured the tailcap area to make sure there were clearances for everything set up for 16mm boot. On that note, I might recommend ordering these in the normal OSH thickness, instead of the thinner type they just announced.
I’ll try to draw up a board with an attiny tonight, then we can have some leverage to convince the firmware people to write something for us
14mm would be tight. Right now everything on that pcb is inside of a 14mm invisible circle around the center. However, 14mm is the outside diameter of those boots, so inside the button is probably more like 12mm. I could do a simple one to fit that size, but not one of the more complicated ones I’m going to work on tonight.
[/quote]
Why is it useless without the switches? I would not mind a low draw all the time… Has not hurt me yet.
I meant on the Rev4 and Rev5b boards. They need the switch populated to complete the circuit and work at all. I still have lights with Rev3 boards too and they work great.
I finally got mine working for the most part. It was the 100k pots. The 10k pots are working great. After the light gets heated up really good at the end of a turbo run, It will jump low-hi-low-hi-strobe-bike flasher-beacon-... But if I drop to a lower mode or shut the light off for 30-45 seconds it cools down and everything goes back to normal. I'm using 200 ohm bleeder resistors still so maybe bumping that back up to 4-600 will help?
I measured parasitic drain at .06mA, then the lowest I could get the LEDs to light up the amp draw was .16mA, then with the LEDs as bright as I could get them the meter read 1.9. I set it to around a .5 mA draw and it seems about perfect. Not too bright at night and very faint in the daytime.
Presuming the attiny works ok in the tail then you’re likely to see a beacon option. It would save power to keep the attiny asleep most of the time, only wake to check voltage and pulse the led.
Leds are controlled all as one from looking at the board. So no Knight Rider just yet. But if the attiny can run stable in the tail then it’s an option.
Each led has it’s own resistor. So you could do something like having many different colors. The brightness of each would be dialed in by it’s own resistor so that they could be adjusted to all be the same visual brightness. No one color overpowering the others. Would take some patience to adjust the vaules.
