This is tiny and under half the price it is elsewhere. Note that the Manafont spec is probably wrong. Its almost certainly an XP-E R2 so should be quite throwy for a keychain light.
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
Piers said " ....but who wants enough light, when you have the option for far too much "
At the rate we all spend around here it will soon be called the Bankruptcy Light Forum. Just think of yourself as the advance guard..............lol
It was a 1-mode when i ordered it last week, now it is a 3 mode.
I wonder what they have sent to me today?
The 3-mode H/M/L without strobe or SOS would be even better for me, but i will have to wait till it gets here...
www.barthuysmans.smugmug.com
Well well, is this a new one or has this been around for longer?
Looks very budget.
I just ordered this Tank007 at DX for about $9 with a clicky.
http://www.dealextreme.com/p/tank007-tk-701-ssc-42180-u-90-lumen-led-fla...
I can't tell...is the one from Manafont a clicky or twisty?
That are two different lights.
The Tank007 tk701 from DX is a clicky
The Tank007 E09 from MF is a twisty
AAA: UF-T1, ITP A3 EOS, Tank007 E09
AA/14500: Xeno E03 XM-L T6 NW, Solarstorm SC01, Astrolux S3 (BLF X5), nameless EA41 copy, Ultrafire C3 XR-E Q5
18650: Ultrafire WF-502B XM-L, Ultrafire WF-504B P7, Ultrafire C8, SkyRay King 3x XM-L (gold)
How come every light on MF looks like a warm one??
I've got it today.
Compared to the Fenix LD01 SS version Q5 it is a little brighter on high, mid is about the same, low is much lower than the Fenix (the Fenix is 80/27/10 lumens, i used nimh AAA batteries). The Tank007 E09 has mode memory, the Fenix always starts in mid-mode.
It is shorter than the Fenix, diameter is the same. The threads on the head are very long (almost 8 turns), that way the head does not fall off when the flashlight is in your pocket.
Build quality is very good, it is a Tank007 with Fenix quality and a much lower price than a LD01. It comes in a nice plastic box with a lanyard and 2 spare O-rings.
That sounds like a glowing recommendation.....
Runtime on high with 800mAh nimh = 23 minutes (capacity tested with Maha MH-C9000 charger). After that it stays on but it is not very bright.
Thanks for the comparison to the LD01, Ive always wanted an LD01 but its like $40, this one is only $15 so it looks like a good deal after reading your comments.
I can't wait until I receive mine after hearing what you have to say about the E09. My order from Manafont shipped out on October 31st, when did you order yours?
Also, I ordered a protected 10440 to test with this light as well. Have you had a chance to try yours out with anything else besides the Nimh?
Kris
I ordered mine on october 21 st and it arrived yesterday. Honk Kong Post seems to be very slow lately (orders from Manafont usually ship the next day, i have an order at DX that is in packaging for 16 days, and another order is still "order recieved" after 18 days...).
I have only tried it with nimh batteries, i don't have 10440 lithium-ion batteries. It gets very warm on high with a nimh battery, but not too hot to destroy the led. With lithium-ion batteries you will have to be carefull not to use it too long because there is not that much thermal mass (maybe you can put it in a glass of water to keep it cool...).
How is the PWM flicker?
