Serious problem with XML2 current. Is this happening to you???
65 posts / 0 new
vestureofblood
vestureofblood's picture
Last seen: 4 weeks 18 hours ago
The main reason I ask this is to see if anyone else is getting similar results.
Ever since XML2 was first released I have been able to get around 4 amps of current (or more) from nearly every emitter.   I've had the occasional delinquent VF like everyone but mostly results were consistent.
Then along came U3 bin.   Almost every one of these I ever got had disastrous VF.    Using exactly the same setup (26650 in my shorty mags) I would get as low as 2 amps often, up to maybe 3.5 or 3.7A max on fresh cells.
With the introduction of U4 bin things went back the  way they should be.  4- 4.5amps on a single cell no problem.   When RMM bought his first reel of them I picked up a large amount of them and never had any problem.
Recently I order a couple more batches from another source I find to be very reputable and all of them test nearly identical to what the U3s did.    I did a controlled test of about 15 emitters to try and week out any anomalies, but sadly they all tested within .1V of each other.   Even the very lowest VF ones in the batch were 4.1V @ only 4 amps Sad
Is anyone else having this issue?
Just to be clear.   Yes I have considered ambient temp and done additional testing inside at 70 deg.  Yes, multiple identical setups in flashlights etc.
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
Edited by: vestureofblood on 01/22/2016 - 19:17
dchomak
Last seen: 4 years 3 months ago
How about hitting one of them with 5-6A for a short time. Won’t that permanently lower the Vf of that emitter a little?
vinhnguyen54
Last seen: 1 month 4 weeks ago
I bought a big batch of U4s before and I am still on it. I have not tried the newest U4s so I am not quite sure. Mines pull 4A+ no problem with a VTC5
Bort
Bort's picture
Last seen: 15 min 23 sec ago
Might they have sent you U3s or got a mislabeled batch from Cree?
The Journal of Alternative Facts
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
Ouchyfoot
Ouchyfoot's picture
You never did mention what cells you generally use.
RMM
RMM's picture
Last seen: 2 years 7 months ago
dchomak wrote:
How about hitting one of them with 5-6A for a short time. Won't that permanently lower the Vf of that emitter a little?
Unless you're really lucky if you do that to a newer XM-L2 or even a bunch of the XP-L HIs you will raise the vF to at least 200-1000 volts, which is about how much I think it will take to jump the spark gap between the now vaporized bond wires.  Cool
Mountain Electronics : batteries, Noctigon, and much more! What's new?
RMM
RMM's picture
Matt, 4.1V at 4A is crazy high for an XM-L2.  I don't recall ever seeing one that high before.  I check the vF before and after every single LED I dedome, so I see them several times a week and I don't think I've ever seen a batch of XM-L2 LEDs like that.  The only 3V LEDs I have here that will go up to a true 4.1V without poofing are some of the newer XP-G2s which need that much voltage to hit 5A-6A.
onetrickpony
onetrickpony's picture
Somebody design a driver that pushes amps no matter what the forward voltage. Threshold voltage? Pfffff! I’m a driver not a designer! Direct drive? Do you think I’m building it?
Laugh all you want, most of what we do is science fiction from a very short time ago. I hope it keeps happening Wink
bmwsancho
bmwsancho's picture
Last seen: 1 year 3 months ago
I ordered a few U3 1A from LED DNA, different months, batches and shipping dates – they are all fine.
on Samsung 25R, 30Q and other cells.
vestureofblood
dchomak,
I hear you about the burn in.   That is something we used to do with SST-90 emitters and it actually worked.    I have attempted it with XML2s and it has no effect.
What RMM was saying about the spark gap thing is just because the new (U4 bin XML2s can only handle about 4.5A.   Once it a while you will get all the way to 5, but I've not had any live beyond that.
RMM,
What is the typical VF your getting with XML2s ( for example at 4 amp)?    What change do you typically get after a de-dome?
Same question about XP-L and XPL-HI in top bins if you have tested any of these?
Thanks also to everyone else who has commented.  Your input is valuable to me.
Lightgecko
Lightgecko's picture
Last seen: 3 years 11 months ago
At least with my basic understanding of electronics, that constitutes a boost driver, and some sort of feedback to measure the Vf. Not exactly the easiest thing to get to work, much less at high currents.
Curiosity killed the cat……But I’m not a cat…..
bugsy36
bugsy36's picture
Last seen: 1 year 1 month ago
VOB...
Not trying to go off topic. What about total lumens and total wattage (VxA)?
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
vestureofblood
bugsy36 wrote:
VOB...
Not off topic at all.     Just now I did a test of the output as well.    Last year I performed a series of controlled tests in order to calibrate my sphere and to determine the usefulness of the XHP-35.   I happened to have a control test of one of RMMs original U4s which I had reflowed to a 1"x10" copper rod.
Lights used for calibration 8/10/15  Measured FCmultiplier from FC
Shorty mag as tested by Ti-force 875 lumen  27100.322
4sevens X10 640 lumen  20000.32
4sevens Quark AA2 280 lumen  9140.306
Test #2 Shorty mag 875 lumen  27100.322
Multiplier used for testing below .32  All emitters were reflowed to copper MCPCB and to solid round stock.
Cree XM-L2 U4 Measured Lumens Cree Chart
1000ma 432 459
1500ma 620 629
2000ma 793 824
2500ma 900
3000ma 1100 1122
3500ma 1238 -----------------------
4000ma 1369 -----------------------
4500ma 1478 -----------------------
Just now I re-calibrated my sphere to be sure,  which as it turns out was within .0011 of where it was at before.
Cree XML2 U4 in question for VF and output 1/27/16   reflowed to copper rod as before
Calibration. Shorty mag .347 47s X10 .324 Quark AA2 .311 Average .327, multiplier used .33
1000ma415 3.2v
2000ma739 3.6v
3000ma1032 3.9v
4000ma1267 4.1v
Its impossible to  tell for sure since I had only one test of the previous emiter, but it appears that the ones I have now track almost exactly one bin lower.
Original.............New
1a  432.............415
2a  793.............739
3a  1100...........1032
4a  1369...........1267
At this point I think more info is still needed to be sure this is the problem though since even emitters in the same bin can gap about that.    RMM is going to send me some results from his testing later.
RMM
RMM's picture
I am going to do some tests later tonight when I dedome some emitters and post the vF findings here of some of the XM-L2 U4 1C I have.
@vestureofblood:  What are you using to measure current and vF?
Mitko
Mitko's picture
Last seen: 1 year 9 months ago
Well thats strange, so far i have never ever met a single xml2 emitter that aint capable of running at least 4.5 amps easy,those u3 0d that i do love so much lately are running at 4.7-5amps on a fresh HE2 battery yet they are as good as U4 1C considering the lumen output, but the tint when dedomed is good
The best of those that i have found so far are both KD ans IOS V6 1A: easy hitting 6amps with a good 26650, a localy picked V6 2c-2d( same as above, IOS one aint that good ) , ofc V6 0D from IOS and FT V6 0D-yet the tint here aint that good, prolly nto a true 0D but kinda 0C more or less
The one thing that is strange to me about V6 bins in thay they dont dedome that easy as the old ones
vestureofblood
My bench power supply.    I just took a short piece of heavy lamp cord (about 2ft) and wired it to the supply.
Is this the right way?
Beyond this I have been coming up short on current/lumens else where with these.
One example is an 18650 pocket light.  Original tested at 1080 lumen @ 1 min.   With this latest batch of emitters I was only able to get a very best of 960.  And the 960 was after I over sized the wire, copper braided the tail spring, and progolded the clickie switch.   All 3 of which I did not have to to in the roll out.
MRsDNF
MRsDNF's picture
I do my testing with a similar branded bench supply. I dont use the readouts on the power supply itself but measre at the led as there is a slight difference between readings. The readings on my power supply are as accurate as my DMM's.
RMM
RMM's picture
Measure voltage across the emitter with a DMM and compare that to what you get at your PS.
Tom E
Tom E's picture
On a de-domed U4 1C in my modded Convoy L2, I measured 5.47A at the tail using my new clamp meter on a Basen 26650 4500 cell @4.22v, and DD FET driver.
On a modded BLF Lucky Sun D80 on a 30Q @4.21v: 5.15A tail (DMM), 5.36A tail (clamp), lumens: 1812 @start, 1744 @30 secs, 52.5 kcd (taken at 5m)
Don't have the exact #'s but on a XM-L2 T6 4C FET+1 driver Warsun X60 mod, I measured bout 6.5A tail on a DMM, and over 7A at the tail on a clamp meter. This is with an EFEST 4200 26650 or the new Basen 4500 26650, both at about 4.21v or 4.22v..
You should be getting between 5.0A and 5.5A on a U4 1C with a decent DD FET driver using a clamp meter (the UT-210E). As shown above, a clamp meter will always get a higher reading on a DD driver. On the high Vf U3's, I get in the range of 4.0A to 4.3A with a similar setup.
Your amps measured are consistently lower, so I'd suspect either the measuring method or higher resistances in the circuit (driver, host, wires, possibly MCPCB/LED, etc.).
vestureofblood
RMM,
Just now I did as you suggested and measured the VF with my DMM using the same test emitter as before.   I got 3.99 @ 4 amps.   The PS reads 4.1v so I am getting a slight variance there.
TomE,
Thanks for chiming in.
Where you said
"You should be getting between 5.0A and 5.5A on a U4 1C with a decent DD FET driver using a clamp meter (the UT-210E). As shown above, a clamp meter will always get a higher reading on a DD driver. On the high Vf U3's, I get in the range of 4.0A to 4.3A with a similar setup."
That is fairly close to what I was getting wtih the U4s until recently.   I dont have a clamp meter but I use heavy custom leads for my DMM.    On a 26650 light I was averaging 4.4-4.8A on 26650 lights and just a little under that with 18650 lights.
These new ones wont squeak out anything above 3.8.
light-wolff
Last seen: 6 months 3 days ago
Measured directly at the emitter solder points?
Tom E
Tom E's picture
Yea, not sure, we could be splitting hairs. My heavy gauge DMM leads soldered direct into the banana plugs does fade over time. I found treating the banana plugs w/NO-OX-ID gave me a bump, refreshing the solder tips of the heavy gauge wires also gave me a bump, then NO-OX-ID on those solder blobs helps more.
I havent' seen a dramatic drop in U4 1C's, but can't be sure when the U4 1C's were bought, or what batch - got some from MtnE and maybe IOS, both fairly recent though. The U4 1A's from Cutter I believe perform in the same range - only tried one and blew it out in the BOSS1, but probably went over 5.5A.
vestureofblood
light-wolff,
Correct.  At the solder points on the MCPCB.
TomE,
I'm just glad others are chiming in.  Especially since you also have very similar results with the U3 bin and the higher VF.    The more and more tests I do, and the more information I get here the more I suspect that I was shipped U3s by mistake.
I think if RMM gets results from his stock that reflect my original test results I will just end up order new emitters from him.
Tom E
Tom E's picture
Think'n that could be correct - performs like U3's...
I've only found out very recent how low the U3's are compared to the U4's - had no idea. Really very disappointing for me because I just bought recently qty 10 of U3 3D's from IOS, and still have a bunch of U2 3D's thinking the U3's would be better. Like the tint but but being 1.0 to 1.2A lower than U4's is an additional penalty for that tint.
bdiddle
Slightly off topic, but ate you guys finding U4 bin to have a higher brightness than v6 when using a FET driver, all else equal?
Newb
pilotdog68
pilotdog68's picture
Barring the evidence we apparently have, why and how could there be such a significant difference in the U3’s? After all, isn’t the U3 just a bin they assign after manufacturing? Were the U3’s all from a single batch that somehow got messed up with a higher Vf and Cree just deemed them good enough for rated spec?
Tom E
Tom E's picture
Yes - I'm finding the U4's brighter than V6 XP-L's. Umm - diff in U3's? Well, newer T5's, U2's etc. are also low amps and high Vf like the U3's. U4's on the other hand seem to be different.
The bin assignment was theoretically that: pull the LED's off the line, test them, throw them into the appropriate output bin. But, we don't really see this - within a given time period, what we are allowed to buy, released to our somewhat gray market, is very specific tints in very specific bins. A bin though is a wide range, so maybe the CREE manufacturing process is so precise now, you don't get diverse bins spreads.
vestureofblood
pilotdog68 wrote:
Barring the evidence we apparently have, why and how could there be such a significant difference in the U3's? After all, isn't the U3 just a bin they assign after manufacturing? Were the U3's all from a single batch that somehow got messed up with a higher Vf and Cree just deemed them good enough for rated spec?
Cant really say why and how for sure.     I know that around the T6/U2  bin something was different with the bond wires.   Driving those bins to 6 amp was no problem.    When we hit U3 I not only noticed the spike in VF, I also found that the bond wires would fry at lower current.
This is just an observation.   I use about 400-600ish  XML2s per year so its hard to judge exactly what is going on for say a reel to reel basis and such.
Tom E
Tom E's picture
The bins are all bout efficiency - lumens/watt. I think CREE made a design change to get higher efficiency in the U4's and may explain why the Vf is lower.
wight
Last seen: 2 years 6 months ago
Any discussion of measurement methods here is a moot point in my opinion. As long as the results consistently relate to one another (apparently they do) all the questions like “did you take the readings from your DMM or the PSU” and “did you put the DMM right on the LED” become irrelevant. While in our hobby a difference of 0.1v due to measurement method can be very relevant, that’s not the case here. As long as the method remains consistent the results compare properly to one another. VOB’s measurements on one set of emitters are repeatably lower than on another set. At the end of the day it sure sounds like a bad batch for whatever reason since nobody else has chimed in to say “oh I had that problem too!”.
RE the binning vs manufacturing methods conversation… as mentioned above, the waters are really too murky from our perspective to draw strong conclusions but it stands to reason that a lot of what we see is based on how few LEDs actually flow through the grey market. When we notice something like “U3’s have a high Vf” what is possibly more accurate is that the U3 bin required a higher Vf when it was a new cool-white bin. That’s happened before with other LEDs, bins, and manufacturers too. After whatever advances led to the U4 dropped the Vf back down this probably also applied to any new U3 production. Without a date code on some modern U3’s it’s impossible to say. In other cases Cree has come up with a new technique and then applied it where they could. I could be way off base here, and I’m definitely not speaking based on personal experience with either bin (as many of you can guess, hehh).
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
scotlarock
Here’s my 2 cents. Built a Convoy C-8, with all the tweaks, FET driver, and VTC 5 cell. With a hot de-domed U3-1A (from Richard I believe) pulled around 4.3a. Removed the U3 and replaced with a hot de-domed U4-1C, from Richard, and amp draw went to 5.1-5.2a. Lux increased 20-25kcd. I did this a few weeks ago and forgot the exact numbers, but I’m close. Not overly thrilled with the 1C tint. Awaiting delivery of some U4-1A from James@ 3Tronics. If the 1A has the same output as the 1C without the yellow tint, I will be very happy! BTW my current measurements are done with my Fluke 336 clamp meter.
