Not only that TOm, i got 3 of those drivers, they lose modes on a random base, they have a moon mode issues that i mentioned early in the BLF A6 topic yet since i do respect TK efforts and the others that worked hard about A6 project i only mentioned it, and yes, they have kinda high resistance too
WHy the hell they changed the design i dont know…whatever
Any reliable source of U4 1A? I have never tested that emitter though
I got U4 1A's from Cutter - blew out the first one in the BOSS1 (believe the bind wires failed) when running off of 4 EFEST 4200's, it survived on one EFEST 4200. I got two left of the U4 1A's - not many, haven't tested.
For the BLF A6 drivers, I'd think the FTE is suspect, and definitely the caps must be high quality and think they skimped on costs with them.
Probably I got lucky, 5+ A on an XP-L HI V3 without much effort. The MCU seems stable as well (not using the stock firmware).
But I suspect the assembly quality of the A6 drivers vary wildly.
As much as I hate to skew off topic I will have to chime in on the BG FET drivers as well.
I really thought this was going to be what we had all been waiting for. A ready made mosfet driver. Not so much. Certainly better than anything that was available before, but I too noticed the higher resistance vs ones made using OSH park boards and BLF suggested components. In a setup that would typically draw around 3.2A I got only 2.6 ish IIRC.
I have not even tried them with the stock firmware (not why I bought them). The only UI issue I have had that I know of after flashing with a version of star firmware was a very long amount of time it takes for the memory function to take hold. Like 10-15 seconds.
Using said firmware the moonlight and other low modes run through the 7135 were great. All in all still a good driver, just not nearly the ready made unicorn we have all been dreaming of.
OSH is now offering 2oz traces and I will have those in hand in a few days, if all goes well asflashlights will be selling mosfet drivers by next week :)
Funny, I held off buying them but finally just ordered 2 this past week, just to have some spares around. Forgot bout some of the issues, specially with the caps. It might be a crap shoot - the resistance won't be noticeable by many, but think the caps have been both good and bad.
Sure, I've replaced then before - pretty simple. Think you should first try out the drivers though to see if it has the mode switching problems. My two BLF A6's I believe switch modes fwd/back pretty good - didn't have problems like many described. Lot of reports they worked fine as well.
Back in the XR-E days, flat regulation was something people looked for, there were drivers which would initially regulate and then go into boost mode. The driver I put into my SmartFire V-68C pulls 2A out of the battery whether it’s at 3.0v or 4.2v, I’ve got no idea what it’s efficiency is like but I’d expect 2A to kill an XR-E so I don’t think it will be wonderful.
Question: I cooked a BLF 17 DD FET driver (original double sided version) by soldering the zener on backwards (also used an R100 resistor instead of R200) and running it at 8V. Can this be rehabilitated? Is it the MCU that got cooked, and could I swap a new one in from a q-lite?
Today killed a dedomed XP-G2 S4 2B from IntO, a dedomed XM-L2 U3 0R from Kaidomain and previously a U4 1C. Next tried XP-L V6 1D from IntO dome intact survived the HX –1175B1 running on 4 Tenergy D cell NiMH hot of the charger. Tail cap reading was close to 6A. This is in a Maglite 4D voltage @ cells 4.8V+ with my machined custom head with a SR90 reflector and UCLp lens. Would really like to run a dedomed emitter but as-is handily spanks my Y3 U4 1C dedomed resistor modded light and Sniper M24 BLF edition.
I'm not sure I understand the Maglite/SR90 custom light setup (never modded a Maglite myself), but if the 6A tail means about 6A to the LED, and you measured on a DMM and not a clamp meter, then it makes sense you killed/popped those other LED's. 6A on a DMM could mean 6.5A actual (clamp meter), and that's way too high to expect a U3, U4 or XP-G2 S4 to survive at.
For sure the Fasttech 'carobronze' spring has lower electrical resistance than the stock Convoy steel springs. They are not better than the spring on the Banggood A6 driver that I tested. Not sure how either compares mechanically.
Both will not heat up below 7-8 A, but a wire bypass is still a good improvement on both if you are chasing amps.
I did some measurements at 5 A over the weekend. My numbers are slightly higher than djozz, but I did not solder to the springs and I measured spring tip-to-tip. The M1 should come with the same springs as the S2/S2+:
Hi, thanks for the info and the image. Very valuable info.
So, i only change the tail spring for the fasttech carobronce spring. BTW great spring have the BLF A6 of bangood.
Thanks.
Alberto
Edited:
Anyone have a picture for compare tint Xm-l2 u3 1a and Xm-l2 u4 1c ?
Time ago i have an Xm-l2 u2 1c and the tint was green so i decided to not buy u4 1c but i don´t know if this cahnge. Anyone can help me?
Why? If Cree changed production process for XP-G2 emitters they could also change it for XM-L2 emitters.
So if anyone has lower or he is unsatisfied with performance of lets say XML2 U4 bin emitters thing could be that Cree changed production process for them.
I recently got a XM-L2 U4 1C from IOS and all I could get was 3.6A at the tail with a 30Q. The previous XM-L2 U4 1C I got from IOS and RMM when they first came out did 4.4 - 4.6A.
