Not sure how to answer this. At a guess I'd say processor since the stepdowns are sudden, defined steps rather than a slow gradual drop. I first noticed it happening in visual steps when using the light on a low level in complete darkness. It was then I got out the multimeter to investigate. If plotted graphically it would be a staircase rather than a curve if you know what I mean.
Definitely not a tailcap issue as one possibility suggested for the previous poster. Neither does mine shut itself off completely (yet). Certainly not in 5 minutes.
Sometimes the thermal step down is set to act too quickly. I don’t know that the protected cells would let you get to the configuration menu, but I’d try setting the thermal regulation and see if that helps.
I can get into the config menu with the Coolooks. I did the factory reset that way. I'll need to dig around to find out what to do and how, when I get into the thermal regulation menu. I'm assuming this is the correct link: http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/blf-x6v2/view/head:/ToyKeeper/bistro/bistro.txt
I'm not quite sure how I'm going to achieve much in the thermal menu really. It is displaying this behaviour at drive currents of less than 200mA, way too low to get any kind of heat into the head. Unless you are suggesting I just try disabling it?
Way too late here now - nearly 2.30AM. I might have a fiddle with it tomorrow.
This isn’t the same driver as the A6, this one uses the ATTiny25 which allows for thermal regulation, so the light doesn’t step down like the A6 but instead it ramps down with 64 levels of stops.
Enter the config mode, at the 7th blink break connection during the stutter… it’ll come on in about a med mode, turn it off… this disables it. If you want to set it, wait a couple of seconds after the med mode and it will shift to Turbo where you can run it til the heat is as much or as little as you dare, turn it off at that point and this will be memorized.
I got my ss/cu with box set today. I am beyond happy! Wife thinks I’m insane because I called her into the room for the unboxing. She just shakes her head and searches for the number to a cheap psychiatrist.
My lights were perfect no issues whatsoever. The box had one little ding on one corner that I never would have seen if not for reading about that issue here. For me, no issue at all. Completely satisfied. Ecstatic.
I would like to express my thanks to all involved with this venture. I can never you repay for all your work and efforts. THANK YOU!! I look forward to being able to participate in more of these customs lights.
Cant wait to show these off!
Steve
Sorry, I can’t figure out whether you’re joking, or describing what you actually did in a way I don’t understand.
Sounds like sticking the pliers inside the bend and hammering on the outside, which would not open up the bend, it’d make it narrower.
Would you add a picture of how you fixed your clip, if you actually did what you’re describing there?
The problem is the old familiar one, the 180 bend is so tight that folded cloth won’t fit into it.
Thanks Dale. I think I disabled it as it now seems to be running steadily in modes 3 and 4. Looks like something weird going on in there.
I'm guessing the same process (break at 7th stutter, then off at Medium) would toggle the thermal protection back ON again? I tried this but it seemed to make no difference. I can't push the light hard enough to heat up properly on the 3.2V LiFePo4 so I can't memorise a setting ATM.
Sorry to be a pain but do you have a link to the firmware instructions for this light. The diagram in the first post is helpful but lacks detail. I know it's probably buried somewhere among the nearly 5000 posts in this thread.
Thanks myhken. Ok, so that is the same link I posted in #4983 which means I am looking at the correct instructions. (I mistook Dale's comment about it not being the same as the A6 to mean I was looking at the wrong file.)
This doesn't mention toggling thermal regulation on and off, only turning off or seting manually. If that's the case I guess I'll need to wait until I get some IMR cells to be able to turn it back on when the light gets hot?
The X5 is eating up battery power. Just played a little with it yesterday, set the thermal settings and today, I tested the thermal setting, and noticed that the lights was less brighter then yesterday from the start. Pulled the battery, and it was down to 3.3V
And that’s a protected Keeppower 840mAh. So it’s not using the full power of the light.
So not much runtime with the X5.
Not tested the X6 yet, but there I have 30Q, HG2, MJ1, GA batteries I can use.
My Keepowers are protected 800mAh - maybe 3 years old but with little use. I can't run turbo without tripping the protection. Yours must have a better circuit. Even so, you wouldn't expect "full power" on a protected cell. With such little capacity in a 14500 and this awesome driver, eating batteries will be inevitable in the higher modes.
Yep, the full sized FET driver on a small 700mAh cell gobbles it right up. (non protected high discharge cells in the 14500 class are ~650mAh)
When you are able to pull 5000mA (5 Amps), a 650mAh cell is being slammed!
But it sure is nice to have big flashlight output in a palm sized little beastie that fits in a pocket easily.
So, now imagine going up to 11.5A on that little cell with a Quad. :bigsmile: I stepped outside night before last to go to the shop for a quick mod (put a tail clicky in a SupFire M6 for lockout) and was wearing my Nitecore HC50 Headlamp. The dog was acting like there was something he wanted to go after and the headlamp wasn’t showing me the far end of the yard (200’ deep) So I pulled out my little Cu X5 Quad and BAM! lit up the whole backyard ( I wear the Quad X5 in a horizontal open top Kydex holster on my belt, have had it with me ever since it came).
Bunny rabbit, stupid Yellow Lab was all excited about a lil ol bunny rabbit! As you might can imagine, that little Efest Purple 14500 isn’t going to do 3000 lumens for long, but it sure is nice to have it if/when you need it! And of course, this is what 7 levels is all about, battery level control.
Got my Al set today and they look pretty nice. I’ll have to get some better cells to push these lights to their max potential. The only issue I have is with a cracked lens on my X5. It’s only towards the edge, but I wonder if it will become a bigger issue, especially if it’s ever dropped. You can see the cracks extending past the edge of the reflector or O-ring, not sure which it is, as I don’t want to open it up and risk the cracks getting worse.
