does any know about maintenance with these lights? what can i use to oil the threads is it the same as a normal light? or will a petroleum based lube cause problems with tarnishing? seeing its not alloy oil can east away at the flashlight?
Wow I just powered up my little x5. What a beast. I can’t believe how powerful this thing is. And great throw for a little light. How does it compare to the blf a6 beam wise?
Anything that is a limited production item, especially the first of its kind, is going to increase in value. Period. If you don’t like the economics, use them and enjoy them. If you don’t like it when people make money, think about your own profit and decide where to donate.
If those two statements don’t apply to you, welcome to the club that I’m in! We like amazing things, we like to use them, we understand basic economic principles, and we understand that sometimes you choose to keep something you were fortunate enough to get at the right time and place and sometimes you choose to profit from the situation based on need or desire.
Nothing is wrong with any of the options. We all choose to proceed as we see fit, no judgement is necessary.
Completely different of each other. The A6's sheer power really lights things up but this X5 has essentially the same power factor with the updated driver so it comes down to SMO reflector and XPL-hi vs OP reflector and XPL.
Doesn't matter....you need them both ;)
Yeah that’s what I am thinking now after getting this set. My first blf GB was a huge success. Thanks everyone
I’m actually shocked and insulted by the response to my knurling issue. I’ll keep following up to get a replacement. I normally wouldn’t mention anything but am pissed by the customer service so far.
I’m assuming you mean banggood, what did they say?
Nope, that only turns it off. Technically, it sets the heat ceiling to 255. Then after going up to full power it actually measures the temperature and stores that instead. It keeps reading and storing the temperature every couple seconds as long as it stays on in that mode. So, when you turn it off, the new ceiling is whatever it last saved while it was running in unlimited turbo mode.
To set a new ceiling, you actually have to get it hot… and a 3.2V cell isn’t going to get it hot.
At full power, the X5 run time is only like 10 minutes. Dale’s quad would run out of power at like 4 minutes.
Aren't they on holidays?
I’m not upset about the wait. It’s the response. Basically, no big deal, how about $3?
That is standard CS. Wait until Neal helps come up with a solution.
That was Neal.
The only solution to me is a replacement tailcap.
We (I) will see what we can do after CNY. That may have been Neal or an assistant .... not sure. This much I do know... Even though your knurling is fowled up they have been buried with the BS stuff and that is going to play a part in anything from here on...if anything from here on. Just because things are not being posted do not believe for a minute that people are not making attempts to get refunds, discounts etc etc and that is going to make it harder for the few that have issues.
I just tried it to be sure, and mine keeps its memory regardless of tailcap. It can’t even tell the difference between whether I use a tailcap or a paperclip to connect the power.
For my X6 I got #400
Congrats, I had thought that would be a cool number to get!
We (I) will see what we can do after CNY. That may have been Neal or an assistant …. not sure. This much I do know… Even though your knurling is fowled up they have been buried with the BS stuff and that is going to play a part in anything from here on…if anything from here on. Just because things are not being posted do not believe for a minute that people are not making attempts to get refunds, discounts etc etc and that is going to make it harder for the few that have issues.
OK. I do apologize for airing my dirty laundry. Was just upset because a fairly legitimate issue was met with a $3 offer. I just want a tailcap. Not a token.
They are beauties and they are HEAVY.
Box were not damage at all, but the X5 were out of its slot and riding on top of the X6 when I open the box.
Guess it was flinging inside the box during shipment and causes a scratch and ding on the X5.
Maybe in the next such GB it would be good to secure the lights in their slots.
Hey, really appreciate the time and effort that Team Kronos sacrificed for doing this. Thank you.
People have a variety of opinions on flashlight grease… I find that “Super Lube” (PTFE / Teflon grease) works well, and it has virtually no interaction with anything.
Note that the copper is coated to keep it shiny. I’m not sure what the coating is, but people will likely want to know how to preserve it and how to easily remove it. Dale stripped one of his, but it sounds like it was a lot of effort.
I hope you’ll be able to get a replacement part. The pics you posted showed a clearly botched piece. Keeps us posted, okay?
I’d pull one out of my hat, but unfortunately the only thing I can summon forth from the ether is code.
