I don’t doubt your information, but when I looked at this GB, I also wanted to know the max input voltage, went to the store and found another driver with a very similar name that stated among its features:
Low-voltage protection for 1S, 2S, 3S, or 4S cell configurations -
Input voltage must closely match output voltage; this is NOT a buck or boost driver
I think you two are saying the same thing. If you feed it with 3s 18650 you need to have a series triple on the output. That’s what I thought and I think you two have confirmed it. Thanks guys.
So another question, which is better: 3s cells and noctigon or 3p cells and noctigon?
An SRK has the batteries in parallel, 4.2v max. This driver can also be zener modded though, meaning it is still linear, but can be used in other custom projects to use 2S or 3S batteries to power 6v led’s or other emitters in Serial.
This version actually has an LDO option on the battery side so it can be used with 2S configurations as well, with very low parasitic drain. I don't recommend using this with any 3S setups. I just updated the OP with this information.
@OldLumens: Justin, it is good to see you here! I missed having you around. I'm subbed to your YouTube channel and still watch all of your uploads.
I usually modify the existing driver on the M6, but this will also fit once you file down the tabs (all lights will need these filed) and work to give you a regulated ~4A per LED and low moonlight.
EDIT1: I forgot, that’s a ‘clone’ so it’s possible that a different clone/original/whatever might have a different diameter driver. I’d be a little surprised.
EDIT2: As an alternative it might be worth considering the 9-amp driver shown off by Old-Lumens in this thread: Maglite Twins - Build thread. Beam Shots are up The stock driver would need to remain in place as a contact board. I think that the 24x7135 driver might be able to be installed directly against the back of the LED shelf if care was taken with the wiring. New wiring holes might be required. In any case the heat from those 7135s must go somewhere.
About that measurement, that is the PCB which is soldered to a brass ring. The brass ring could be tossed aside and the driver itself be used as the primary contact between the retaining ring and the head. I haven't done the measurements yet, but I suspect it wouldn't be too difficult to accomplish.
I'm also not sure if the UF-T90 is set up this same way in the driver area. Been a while since I researched that one.
Ah, I’ve looked more closely at your pictures now. :zipper_mouth_face: I see now that the brass ring is adding quite a bit to the diameter of the driver. If I understand the pictures correctly the retaining ring is a separate piece - so even without the brass ring in place the driver could be tightly secured. Does that sound correct?
Yep, well mostly. The retaining ring is separate, but going based off the pics (been a long while since I had it apart), the threads may run out before the retaining ring can snug down onto the larger diameter PCB by itself. Might have to get a little creative here.
The quad xml2 handle is actually the light I mentioned earlier 'quad' that I was contemplating putting this fantastic driver in.
