The tail current also drops steadily with cell voltage, so that extends the standby time too. It basically makes a straight line from 0 to 0.63mA as the voltage increases from 2.2V to 4.2V.
I’m surprised to hear that the voltage measurement is correct. Have you let it do the read-out more than once in a row? It’ll likely report 0.1V higher on the second (and later) readings, after the cell voltage has recovered a bit from the turbo and strobe accessed before battcheck.
In any case, people are reporting better battcheck results than I expected, so I think I’ll make the correction factor a little smaller… like maybe 0.07V instead of 0.11V.
You do realize I used the word “could” as a qualifier in that sentence, right? As in it was one of but many possibilities.
Anyway, I don’t generally disagree with anything you said.
To be clear, I don’t care if the people who host this or any GB get nothing or everything in return for doing it. For example, Krono could have decided to do this GB just to avoid spending time with his wife or he could have gotten a lifetime supply of IMR cells from BangGood or anything in-between.
It matters not to me.
Whatever deal he made for himself or the “team” is fine with me. I am truly thankful to be a member here and have expressed gratitude in every post or video I made concerning any light from a BG.
That said, some people sometimes almost make you feel like honest discussions about the results of all the hard work are somehow a personal attack on the hosts of the GB.
For instance. The D80’s shorter than expected tube. That was a problem for some people, myself include. I purchased cells that would work and longer tubes just in case. I wasn’t ticked off then nor am I now. But, saying it was a problem does not diminish a person’s gratitude for all the hard work that was done. Saying the sides of this box should have been better protected isn’t a personal attack on anyone.
When I tell my wife that a new recipe didn’t turn out so well, it doesn’t mean I love and appreciate all she does for me any less. Same thing on a different level, right?
Neal seems pretty good about resolving issues and I’m 99% sure that 99% of these issues will be resolved fairly. But there are things to learn from this GB which may make the next one better and the only way we are going to learn from what didn’t go so well is to talk about it.
It’s a forum, after all.
At the end of the day, I’m just not seeing the need for animosity amongst those that host GBs and those that buy GBs.
If you don’t mind me jumping in here, my understanding is that most o-rings on flashlights these days are made from silicone. Silicone grease will disolve silicone, so a petroleum based grease or synthetic is preferable to silicone grease in those instances. If you have a petroleum based o-ring, then silicone grease is preferable for the same reasons, petroleum disolves rubber. There is a whole university of science for flashlight lubrication, and there are stuffs optimized for different metals, and different o-rings, and its not always obvious. I recently switched from plain old Vasoline to Frog Lube on my current lights, but if I had a Titanium flashlight, I might consider the more expensive and highly praised Nano-Oil, which has different varieties for threads and optimizing o-rings.
SS can have a tendency to gall if not adequately lubed when both of the mating SS pieces are the same type of SS. As an example, on a SS pistol like a .45, the slide and frames are usually made from two different types of SS to prevent galling.
If silicone grease isn’t good for flashlight threads then why does mtnelectronics sell it as such? Im pretty sure Richard knows what he’s doing. That’s where I got mine and its served me well on all my lights. What am I missing?
Brett, those are the Red cells that Efest sells in almost every line of their offering, if I’m not mistaken the first Purple 14500’s were a light color with the Efest name being smallish. These new ones are dark purple, like the 3000mAh 18650 or the 4200mAh 26650, a new line of their cells that just recently came out.
On the lubricant story-line, I use Nyogel 760G or nothing at all. It’s worked the last 3 years and 135+ flashlights, from base aluminum el-cheapo’s to Type III hard anodize and Titanium and full copper.
I’m not understanding the galling comment either. You just got the lights, how many times could you possibly have taken the tail cap off? Surely there isn’t any issue between the Stainless and Cu, and I’ve been modifying this little full copper X5 for a while now, rebuilt it fully over and over, no issues with threads at all.
I’ve also got a mistake sample that’s all stainless. No galling there either and it’s been rebuilt several times as well, with drivers exchanged many times as we figured out what was ailing the birth of the brainchild. To this day, those threads are dry. I never put anything on it at all and it’s smooth as a con-artist at a widow’s ball.
Emarkd, on the orange tail LED’s, that’s sharp! I’d love to do that, can you tell me where to get (and what to get) those little LED’s? I’d strongly consider purple as well, just need to know what size and where to find options…
I thought the Alu X5 clip looked nice, but upon trying to use it, it is unusable as it is too tight. Has anyone been able to bend it so that it is usable?
PS: I suggest a mod thread be opened for all modding posts.
Verdigris ?
Really?
Why don’t you just say, may cause Green crap to develop on the copper?
$100 words.
Whatever
And heaven forbid, we use the wrong lube, a 3 cent o-ring is gonna have a shorter life, Big deal.
Exactly how many years will it take for this supposed Galling to make the threads become unusable?
Probably Long after I am tired of these lights, or dead, which ever comes first.
Sorry, Sharpie but your absolutely wrong about this. Petroleum-based grease will destroy latex. Latex can be solidified into rubber. Silicone grease will make silicone expand and foul its purpose. I respect your electronic knowledge and likely your chemical knowledge is superior to mine as well, but if you’re working from memory, don’t trust it. I suggest you spend 10 minutes on Google researching this to jog your memory. For organic rings, you want synthetic grease. For synthetic rings, you want natural grease. Its not as simple as that, but that’s a good rule for non-experts. I realize we’re talking about o-rings that cost 10 per penny, but when it comes to sealing out water or getting good thread action in spite of the ring, we will spare no expense.
Lubrication really is a science and there are better lubricants for different situations. What I have been using is a teflon based firearm grease and it seems to work fine but I also intend to use some wax based stuff that I can get at work that seems to work also. Considering that I have been going through multiple battery changes every night I can say that any lubricant is better than no lubricant and I have had zero thread failures.
@ Cone - You are correct that some comments are viewed as attacks and although some are not many comments regarding the name Kronos and designated SN's were attacks, and uncalled for at that. It is also true that Neal and Banggood are pretty good at resolving issues but there have been many suggestions (even demands) not even posted here that are just not really feasible but also some that are impossible.
As Dale has said, the Copper lights are a first. There are lessons to be learned....for everybody. That requires a certain level of acceptance of things being the way they are for this go-around and the realization that no matter what this was a hell of an accomplishment for all. Honestly, that is what annoys me and fires me up. Some people are even claiming diminished value of a collector's item....really?
If we are to progress then we cannot make those types of silly claims. As it stands...we may never see a serial number again but even worse is that we may never get Copper lights again because the perceived risk is too great (because there are several hands handling the product IE: Machinists, Assemblers, Packers, Shippers, etc). Sure, better packaging is definitely in the picture for the future but there is no future if a product with slim margins becomes a loss. I hope that does not happen but we will not know until after CNY when it will or will not become a reality.
Added: All I have ever tried to do is protect the integrity of BLF while still getting what many (including myself) have wanted. To do that requires give and take....not just gimme gimme gimme. It just cannot work that way. There must be reason.
Thanks guys! Like PD said its probably all in that thread… but to be honest I didn’t read much of it (sorry!). I probably should have but there’s just sooo much content here that I can’t take it all in. So I did what I often do - wing it! It worked out as you can see but I did make a mistake. I assumed everything in there was 0805-packaged stuff. That’s what the first bit of the lighted tailcap thread discussed so that’s what I ordered, but that’s not what’s actually on these boards. The resistors may be (probably are), but the leds are larger. It worked out though because the 0805s will still work. The sit almost between the two pads, just barely touching on each side, but that honestly made it really easy to solder. I just tinned each led pad, set the 0805-package led between the two tinned solder-blobs, clipped them down firmly so they wouldn’t move and touched my fine-tipped iron to each junction. They joined right up and work great.
As for parts to order, well I went fast cause I have the patience of a small child. I got this assortment from Amazon for 2-day Prime delivery. I’m sure they could be ordered for much cheaper from other sources, but I wanted it now. Plus now I’ve got lots of extras to play around with, on these lights and others.
Maybe someone else could chime in with the actual size of the included leds. I think the next size up is 1206-package so that’s what they probably are, but I don’t know enough about smt components to be sure.
