I can’t wait to see first results of the smart tailcap.
TK, I had a look at your firmware, but due to my lack of knowledge I have trouble understanding what it does… But I think I understand enough to say it’s cool. May I ask some questions?
That colorful swirl… it does it on every boot. So would it start blinking on every short press?
When is the MCU sent to sleep? If watchdog wakes it up every x seconds, basically all the functions like ADC (and that other stuff on page 32 in the t13A datasheet) could be turned off and the port pins can be set to inputs before going to sleep for power reduction, right?
I think we would need a firmware for calibration, right? Could we just use battcheck for that, or would we need something different here?
Yes it works sometimes, and as ToyKeeper pointed out, is very sensitive to about everything, especially the battery type. So for each combination of battery and driver you will have to figure the values out. Thusfar it never worked for 18650 batteries: I tried the same blue/red tail-board that worked well enough on a 16340 flashlight (blue fades away between 3.7V and 3.8V with red still bright) on a BLF-A6 and the blue led stayed lit brightly until the low voltage protection (2.8V?) kicked in.
Also a zener diode did not shift the voltage at which the leds started dimming: at these very low currents things appear to work different.
My current EDC (Supfire S1 host, 3-mode FET-modded AK-47 driver, sliced Nichia 219C):
16340 IMR battery, red 603 tail-led with some resistor (forgot) + dedomed XM-L2 (6A1 80CRI ) tail-led without resistor, 680 Ohm bleeder resistor on the driver. With a full battery the white led is clearly brighter than the red led, once the two leds appear the same brightness to me, the battery is half empty, between 3,6V and 3.7V, the white led fades further when the voltage is getting lower than that.
As is, it should spin on every button tap. I don’t know if this will be annoying.
The MCU goes to sleep after it completes a voltage readout, then stays asleep until the watchdog wakes it up. There are probably ways to reduce the power more than I did, but I consider that an optimization for later. Those steps would be added to go_to_sleep(), and the driver could be put back into a more normal state in the WDT handler.
This definitely needs to be calibrated before I expect it to work. Battcheck should be fine.
I’m guessing about a lot of things because there’s no actual hardware to test on yet. I just used something vaguely similar in hopes it’ll be close enough. And I intentionally left it pretty simple… it can get fancier later if desired, if the hardware works.
I can not program, I can not flash. I do like to see it happen though, and oh, can it made to play music too? And project the voltage? (aspheric tailcap!) :-) ;-)
I have seen cheap little novelty clocks project the time! I think I disassembled one many years ago and iirc it projected thru a tiny LCD (digits clear, background dark).
For the music, would a limited range midi tune be ok or do we need full range mp3s? :party:
I’m busy redecorating my study at the moment but once that’s done I will be ordering a load of different tailcap board to do some testing. Need to get the tail of my Red S2+ sorted out and upgrade the driver firmware to TK’s latest masterpiece.
I still have an empty S2+ host, so hopefully tonight I’ll have time to try some different ideas on sealing up the tailcap without blocking all the light.
I don’t have the rings yet, but I think the 19mm Rev5.1 will work with some edge trimming because the led’s are so close into the center. I’m just going to try different things to do the waterproofing and do some dunk tests to see how it works. I’ll have to add the led’s later.
The pictures I posted earlier was just of a mock-up with a Rev4 board and zero water resistance.
So, I never really asked… instead I just jotted down the first idea I had. But assuming the smart tail board works…
… what do you (anyone/everyone) want it to actually do?
It has three independent pairs of colored LEDs, probably red/green/blue. The location of each pair is likely to be sort of visible through the tailcap. It can sense voltage. It can measure time. It can make relatively simple calculations. It only runs while the main light is off (I think). So given that, what would you like it to do?
