I have seen cheap little novelty clocks project the time! I think I disassembled one many years ago and iirc it projected thru a tiny LCD (digits clear, background dark).
For the music, would a limited range midi tune be ok or do we need full range mp3s? :party:
I’m busy redecorating my study at the moment but once that’s done I will be ordering a load of different tailcap board to do some testing. Need to get the tail of my Red S2+ sorted out and upgrade the driver firmware to TK’s latest masterpiece.
I still have an empty S2+ host, so hopefully tonight I’ll have time to try some different ideas on sealing up the tailcap without blocking all the light.
I don’t have the rings yet, but I think the 19mm Rev5.1 will work with some edge trimming because the led’s are so close into the center. I’m just going to try different things to do the waterproofing and do some dunk tests to see how it works. I’ll have to add the led’s later.
The pictures I posted earlier was just of a mock-up with a Rev4 board and zero water resistance.
So, I never really asked… instead I just jotted down the first idea I had. But assuming the smart tail board works…
… what do you (anyone/everyone) want it to actually do?
It has three independent pairs of colored LEDs, probably red/green/blue. The location of each pair is likely to be sort of visible through the tailcap. It can sense voltage. It can measure time. It can make relatively simple calculations. It only runs while the main light is off (I think). So given that, what would you like it to do?
Personally, I can’t speak for the others, slight delay so that I wont flash during mode changes, blink the voltage (volts, pause, tenths) then either constant on or a beacon (can choose in firmware). The beacon could be in the different colours depending on the voltage?
I think do as many different options as you have time to think up! Personally, I like simpler better. Animations are cool, but I think I’d tire of them quickly. I would like just a different color based on voltage/percent of charge. So from 100–50 it’s one color, from 50–25 it’s a different color, from 25–0 it’s the final color, then it shuts off the led’s completely. We could do that with the led’s on all the time, or have an option for just a ‘beacon’ flash every 3-5 seconds.
I think having in the firmware a choice of Animated or not would be useful. We can then turn on Animation to impress friends, and off again for normal use (for those who prefer no animation in normal use). Some of the Animations could be just for showing off, like a continuous spin, and some could be useful, like batt checks and things.
I’d also like to see a beacon flash that breathes (ramp up, then down). Bonus if it ramps up in a rotation (set one, then set two, then set three), and back down in the reverse.
For a simple, quick batt check, among other options, it might be cool to have the option of a “three bars” rough indicator. If all three sets of LED’s are on, you have great capacity left. Two LED’s would mean a middle amount. And one set would mean you need to change cells soon. Kind of like PD’s suggestion, except it wouldn’t rely on different colors of LED’s on the board.
Being able to set a universal “brightness” setting that covers all the modes would be a great feature. Then changing from Animation to plain or from batt check to a regular beacon, or whatever, wouldn’t require any further adjustment in brightness settings.
It would be great to have configuration options like TK’s other firmware, but I don’t see how that’s possible. Once the mcu is flashed and the board is installed in the tailcap we won’t have any way to input changes to the mcu. Everything would have to be decided at the time of build, unless maybe we could have a way to switch something based on grounding an mcu pin? It could be worked into the Rev4 boards with the smd switch on spring-side maybe.
So I like simple, but a “breathing” beacon would be sweet. Although I don’t think that will be possible either. :_( TK, the Attiny will only be able to output ‘high’ or ‘low’, with no steps in between, right?
Would it be possible to make a board with a slot next to the spring, between spring pad and outer ring, where we could insert a smd-switch, that’s soldered on the backside and can be switched from the spring-side? Don’t know if there’s enough space or if it’s a good idea at all, it just came to my mind…
edit: I took a look at the sizes of that smd-switch and the board and it seems that’s quite unmanageable.
Yes, I knew that. I just thought with the slot-idea the spring would stay compressible all the way and maybe it would’ve been easier to solder, but again (see the edit), it was not one of my good ideas, sorry, I’ll just keep calm and let the experts talk, because I can contribute little to nothing anyways.
