Alex, based on my observations of my lights, the reflector does press on the board. I have 2 semi-circular marks where contact is made. As for one vs. both screws, I would assume it would hold as long as it does not suffer a bad jolt/drop. I am not sure if there are any other concerns with using only one screw.
Got my first of two Al sets today (normal shipping, they are really fast). The X5 is totally fine (except me making some scratches removing the clip), but on the X6, I get a yellow spot in the center of the beam.
You can see here, not the best picture, taken with my phone, but you can see the yellow spot. I do not have that spot on the SS/Cu X6 light.
What can I do, and is this a possible requesting a new light, or something. I can nothing about fixing lights, but maybe there is only a part I can change my self, without any soldering or such thing, since I have no equipment of that sort.
Check the centering of the led as said above, also make sure your reflector is screwed down all the way, it threads on inside the light, mine was a little loose. This is an added feature of the light btw, it allows for better heat transfer and for focusing.
Btw, you can search the thread, and the whole forum…
Stupid question, but how do I open the head of the light. I can open the part with the glass, and then get the reflector? , but I can’t open anything else, so can not center the light.
Edit: On the SS/CU I can screw up the reflector, and get to the led. But on the Al X6, it will not screw open at all. I have tried with all my force. Is this normal?
I paid $188 for a single copper HOST. Which was the cheapest copper host in 18650 cell type I could find....well, the base price of the light was, the extra $88 incurred because I couldn't live without crenelations and tritium slots and a decent clip....
It came to me with two dings on the head, which really are visible and detract from the appearance of the light when the head is screwed onto the battery tube. Then there was a small nick on one of the crenelations, as well as a ding on the corner of the tailcap...and this is the first I've aired that dirty laundry, and only as an example omitting the obvious brand of light, like many many others who I'm sure have had the same issues.
The fact that we get NOT one, but TWO hosts carved from metals much nicer and much more expensive and harder to work with than the cheaper aluminum is astounding!
Then someone wants a discount, free light, or whatever over a barely noticable spot in the middle of the beam that could probably be fixed with a phillips screwdriver in less than 2 minutes.............
I would probably be getting mad at about that point if I were responsible for anything to do with it, but I'm not so I get to laugh!
just to put it out there, and I don't expect anything for it...... (One of) my X5 lens and reflector were fogged up when I opened the box, and on the tailcap threads of one of my X5's, the threads were "gulled" if thats what you would call it. It didn't want to screw back together, had a really rough spot, so I cleaned the leftover metal shavings from machining out of the threads with a Q-Tip and forced it back together, pulled it apart and put some dielectric grease on(don't say it, works just fine) and the threads are smooth as butter.
I have a bad driver in one of my X5's (it's stuck in muggle mode?!). Instead of expecting discounts or a new free copper light, could someone please let me know if and where I can purchase a replacement driver, please!
Unscrew the bezel/head (knurled stainless) from the pill area (finned copper) and you will see a bit of the reflector sticking out. You can twist the reflector in or out at this point and see the change in the beam without reattaching the bezel/head. Pretty nifty, right?
When you get it how you want it screw the head back on, be careful that the reflector stays where you wanted it if it wasn’t bottomed out.
I forgot to mention, just unscrew the reflector and remove it (don’t touch the inside, pain in the but to clean, seriously) to get at the screws holding down the led mcpcb, loosen them a little and center the led, then re tighten the screws and re install your reflector at the focus you want.
Hi Kenneth,
I took a photo of how the Aluminum X6 disassembles(not a great photo, but you can see the seperate parts.
Mine was very easy to open by hand, but if they are stubborn strap wrenches are the easiest solution(mine are Craftsman from Sears). I have also used a thin rubber mat that is sold to help open stubborn jars also. Good luck,
Ed
This should probably be a FAQ somewhere since people keep asking, but… the thermal ceiling needs to be calibrated. Individual attiny25 units vary too much to be able to use one value for every light, so it needs per-unit calibration. Your individual light probably thinks that room temperature is “too hot”.
Tapping the button at config item 7 should put it into a special thermal calibration mode. It starts out on a low-medium level then goes up to maximum and stays there.
You can disable thermal regulation entirely by turning the light off while it’s still in low-medium…
… or you can set a new heat limit by leaving the light on until you think it’s too hot, then shutting the light off. I recommend using a freshly-charged cell for this, and it may need to run for several minutes before it’s hot.
They mention molybdenum, graphite, mica and talc, but it seems that the focus is on fasteners that are installed and left in place, considering that they also talk about reducing rpm during installation. I doubt anyone is installing their tailcap at three thousand rpm
I need to read the rest of it but I thought it might be helpful.
Yeah, humans have a physiological reaction to blue light. Special cells in the eye (ipRGCs, intrinsically photosensitive retinal ganglion cells) respond to sky-blue light and signal the brain to produce serotonin and suppress melatonin. This means that, when people see sunlight or other light sources with the relevant frequencies, they will generally feel more awake. Then when it’s dark, the brain makes more melatonin and less serotonin, which makes people feel sleepy after a few hours according to their individual phase response curve.
Some people don’t have this reaction, about 3 out of 10,000 people according to the studies I’ve seen… and out of those 3, statistically, 2 are legally blind.
I’m that oddball 1-in-10,000 case who lacks this reaction but yet can still see… so I can’t really use light as a way to regulate my circadian rhythms.
Anyway, I think the blue tailcaps are cool. I just want to tone it down a bit to extend standby time and make it a bit less eye-catching in public.
-Box came in perfect conditions
-Lights are heavy and have a premium feel
-Fit and finish are far from perfect but on par with other lights this price.
-Both LEDs are uncentered, will adjust this later.
-Clicky feels solid
-In the X5, copper heatsink is noticeably a different color than the rest of the body.
-A couple small details in the exterior of both lights, not big deal
-Clip for X6 is not enough to hold such a heavy light
It’s this last part I can’t do with my Al X6. It goes fine with SS/Cu X6 and X5 and the Al X5, but on the Al X6 it’s impossible to remove the “shiny” thing. (reflector right?) It will not screw any way, will not move at all.
So this light has the yellow spot in the center of the beam, that’s is annoying, and a reflector that will not move at all.
All I can say, is that this may be the best group buy light out there and they are perfect! LEDs centered, no nicks in the finish, everything works as it should!
Thanks guys and gals for putting this together, much appreciated!
Your problems are beginning to excite my esophageal ganglion.
Btw, I sleep fine bathed in blue light and a haze of various frequencies in the non visual spectrum.
I made a joke to a friend the other day about the possibility of weaving protective coated copper thread into clothing fabric to create a Faraday cage, albeit an incomplete one. Lol.
