Reasonable assumptions can sometimes lead to unreasonable expectations.
I LOVE building triples and quads, really, I do! :bigsmile: But while we can reasonably assume much greater brightness and output, it’s not reasonable to assume that it’s a good thing to do. A good triple is going to pull 9-11A. Since we don’t have any 11,000mAh 18650’s, (well, you know) then it SHOULD be obvious it will take a light with a minimum of 3 parallel cells to supply power to a good triple. This means a big light. Most of us don’t want a big light. So we put up with the shortened run times from the little beasties.
I really like how the SS acts as an insulator against the heat, protecting the cell from the truly incredible amounts of heat that can be produced in the pill. The SS/Cu X6 is a perfect candidate for a triple XP-L HI. I’m actually amazed at myself… my SS/Cu X6 is still virtually pristine! (This too, shall come to pass…)
I need to get some higher drain batteries, the laptop pull I’m running in the X6 isn’t cutting it, and neither is the efest red imr I’m using in the X5, I think I’m way under-driving them. They’re still very bright but I’m definitely missing out.
I should walk out to the car and get my meter but it’s snowing and it’s warm inside. What a horrible situation I find myself in.
My SS/CU set are stuck in USPS Purgatory! According to the tracking information I should have received them yesterday, so I got prepared Wednesday evening and charged my cells so I would be ready to try them out as soon as I opened the package. Unfortunately USPS seems to have dropped the ball, the last entry on my tracking number is:
2016-01-30 09:09 ISC LOS ANGELES CA (USPS), Processed Through Sort Facility, Your item has been processed through our sort facility in ISC LOS ANGELES CA (USPS) at 9:09 am on January 30, 2016.
The USPS site said to expect delivery Feb 4th, but it seems my package got stuck / misplaced somewhere. USPS really does a poor job of tracking packages! I hope this is a temporary issue and my package will still arrive in the next few days! It is driving me nuts to see all the posts talking about the lights people have received and mine are still not here!
I got my meter, but the stupid fuse is blown, must have happened at work…. So the question now is, Harbor Freight or Home Depot? I saw in the Home Depot deal alerts thread that somebody found a Klein auto-ranging meter on clearance, I wonder if I might get lucky.
You could just put some diffuser film or tape on the lens if you’re happy with the output. Or you could get an orange peel effect on the reflector with some spray polyurethane. I don’t know how that would work if allowed to get really hot though. I don’t know if replacement reflectors will be available…
Jeeze, might be less work to do a triple, haha. I bet the diffuser tape would work pretty well though.
The problems that occur in flashlights are pretty standard. It would be helpful to have them listed but more important is getting to know how flashlights and drivers work since that basic knowledge can be generalized to diagnose most problems.
The picture you posted shows a copper KX5 — were you starting by hammering on a clip that came on the copper light?
So far, near as I can tell (not very well) it’s the clips on the aluminum KX5s that are too tightly bent; the earlier pictures of the copper light clips were consistently OK, unsquashed.
Just checking before I take out the hammer, since a followup reported breaking a clip by trying that.
Might be the clips on the copper vs. the aluminum lights are consistently differently made — too small a sample yet to know.
Might need to anneal it first then retemper it after to prevent breakage. Forcing it to bend otherwise would weaken it I think. Maybe a non issue, maybe not.
