ENEDED
436 posts / 0 new
Mitko
Mitko's picture
Well it would be very bad for their econody cause noone can affort to rise prices with those insane low levels of rthe oil and the spendy dollar- yet their own currency devalves regulary compared to USD just to keep the price levels intact- so there is no reason for that- spoken globaly ofc
Yet , 2-3-5$ bigger price wont chill our modding needs anyway :bigsmile:
johny723
Last seen: 10 hours 9 min ago
there will always be some problems. Are there any new updates on the modding of this monster?
Tom E
Tom E's picture
Last seen: 3 days 4 hours ago
No, sorry. The further mods I'm planning weren't probably gonna result in much increase in throw. If I could get a reliable 5+ amps out of a XP-G2, that would be great but all the ones I've reflowed/tested are much lower w/domes or de-domed - didn't matter. Still, I'm pretty pleased with the results of a de-domed XP-L from FastTech, no less... FT is certainly not known to be a reliable source for LED's.
If I had lots of time (I would need it) I'd try a 2S2P cell setup and go with a buck driver I could get 5-6A out of with a de-domed XP-G2.
The other path that Dale, O-L, and others would take is a big emitter and do the 2S2P cell mod. Probably no one could do any better than those two, and O-L has a BOSS1 on the way. Not sure if Dale decided on it yet.
As freeme said earlier, they gave us a big canvas to paint on with this host. It's not a beauty, but sets the bar high for reflector width and cell capacity in a budget level cost. It seems like GearBest is our best option for now, if you can get one of the remaining pieces as O-L mentioned.
I might order one, but after spending $250 on the SS/Cu and alum X6/X5 sets plus a few other buys as of late, I'm a bit tapped out for this month... or two Smile.
KawiBoy1428
KawiBoy1428's picture
Last seen: 10 hours 11 min ago
Tom E wrote:
No, sorry. The further mods I’m planning weren’t probably gonna result in much increase in throw. If I could get a reliable 5+ amps out of a XP-G2, that would be great but all the ones I’ve reflowed/tested are much lower w/domes or de-domed – didn’t matter. Still, I’m pretty pleased with the results of a de-domed XP-L from FastTech, no less… FT is certainly not known to be a reliable source for LED’s.
If I had lots of time (I would need it) I’d try a 2S2P cell setup and go with a buck driver I could get 5-6A out of with a de-domed XP-G2.
As freeme said earlier, they gave us a big canvas to paint on with this host. It’s not a beauty, but sets the bar high for reflector width and cell capacity in a budget level cost. It seems like GearBest is our best option for now, if you can get one of the remaining pieces as O-L mentioned.
I might order one, but after spending $250 on the SS/Cu and alum X6/X5 sets plus a few other buys as of late, I’m a bit tapped out for this month… or two Smile.
I hear ya!!! GB’d out!! XP-G2 performance blues too!!!But I got a TM36 that I’m hesitant to mess with, because it’s just too beautiful, I absolutely love the big beam that throws as far as my modded Couruis’ and lights almost twice the area up? Wink Beside I can’t see 900Kcd away any how? :bigsmile:
KB1428 “Live Life WOT
johny723
which buck driver do you have in mind?
DB Custom
DB Custom's picture
Last seen: 5 days 2 hours ago
Tom, I believe I have a couple of older XP-G2 in 1A tint if you’d like to try those, might get the power level up… don’t know if the output would be any more. Seems I’ve seen some 1100 lumens before from one.
I was hanging in there waiting on the group buy, almost got one from GearBest but went the opposite direction and have a tiny little MecArmy PT16 on the way. Smile
Tom E
Tom E's picture
For buck, probably Richard's - think it's compact enough to fit - didn't measure it out though, but there are options - lots of space - could even cut out a hole in that huge plate if more space is needed.
That PT16 is pretty nice - looked at it... No time right now though for the BOSS1 - other things goin on. Wish I could get some time off from work, but we are under a lot of pressure.
johny723
I have ordered one, cant wait to mod it!
johny723
I have some xml-2 U2 1A that have not been used. Will I see more light and throw from a dedomed xml-2 U2 1A on a direct drive than from a dedomed xml-2 U4 1C or is the resistance to high current at cost of throw and output so the kcd would be the same???
Tom E
Tom E's picture
The U2 1A vs. U4 1C has a lot of variables. Yes - you can probably get ~7A from a U2 1A vs. 5.4A on a U4 1C but there's diminishing returns on the higher amps. I know Richard reported higher output from U4's vs. U2's for DD FET builds, but that was specifically on SupFire M6 lights (SRK style) with the 3 LED's in parallel.
Actually, for my recent Yezl Y3 mods using U4 1C's w/DD FET drivers, I hit 1900 lumens on 3 different lights which I don't think I ever hit on a U2 1A DD FET. 1700 was about the max, I'm pretty sure.
The Miller
The Miller's picture
OK, I choose 18650 as powersources (makes the choice what to buy easier for starters LOL and like lights with 26650 size, since a triple AAA would work there as well (makes them good gifts)
This boss really look like a boss and is tempting, but i am not going to get 26650 cells.
With sleeves 18650s fit and 12 AAA as well. Would the output and user time be any good using decent 18650s?
What would be the consequence of using 12 AAAs?
Tom E
Tom E's picture
Sure you can use 18650's or AAA triple carriers. AAA's would probably kill high output though, but never seen any attempts to use 4 of them in one light.
The Miller
well IF it comes to ordering this big guy I will surely pop in 12 AAAs just to see how it works
johny723
I am still not certain which emitter is the best choice for this light for a DD without a driver. What should I get if I want to run it without a driver? A dedomed xm-l2 U4 1C or dedomed xp-l V6 2C?
will34
will34's picture
Last seen: 23 min 43 sec ago
A dedomed XP-L V6 0D will give you closest tint to CW
johny723
I have another question. Is the difference between an overdriven xp-g2 vs xm-l2 worth it? Will the throw increase from roughly 700kcd with a dedomed xm-l2 to 900kcd with a dedomed xp-g2 be worth the additional effort and expenses of a buck driver and modding the battery carrier for 2s2p?
Ouchyfoot
Ouchyfoot's picture
Last seen: 11 months 3 weeks ago
Too bad the pill is so shallow or I would buy the Boss just to build a light that has a fail probability of 98% from the get go. I would do this just to satisfy my own curiosity.
I would use a step bit and expand the hole in the bottom of the reflector to 20mm and flush mount a Carlco triple optic in the bottom for no other reason than to see what would happen.
Tom E
Tom E's picture
Not sure what you mean. I measured and posted the pill area is 9.5 mm in height for the cavity - more than enough room to piggyback in a typical FET driver. How much space do you need?
Ouchyfoot
Ouchyfoot's picture
Im not sure. I’m still thinking about the logistics fo heat sinking since the MCPCB would then be hanging inside the pill below the emittier plate. I guess there is a possibility, I’m still chewing on it. I’d have to design a separate platform for the noctigon to sit on and still be able to transfer the heat out through the body. Everything I’ve come up with so far would require thermal epoxy. I’ve experienced many fails with epoxy solutions already.
Tom E
Tom E's picture
The emitter plate is huge, I mean big, and if you stay with a single 3V emitter, there's not a ton of heat there. The shelf is so wide, you might be able to go deep with the a heat sink directly under the MCPCB and still have room for a piggyback driver off to the side. There's a bunch of options. I'd look at securing it better to the body on the side - you have a lot of room there, specially on the top side around the reflector.
Ouchyfoot
Ouchyfoot's picture
Normally I’d jump on it and figure out things as I go, but since mounting an optic inside a reflector might be a bad idea from the get go, I have to think about cost. With the Canadian dollar in the tank, I’d have to calculate close to an extra 40¢ On the US$. Suddenly it’s getting a bit pricey.
johny723
Hi, how do you center emitters in the Boss for the best throw? And how “deep” should a led be in the reflector? thanks!
Tom E
Tom E's picture
We call it “focusing”, and varies quite a bit based on the LED you are using – XM-L2, XP-L, XP-L HI, XP-G2, etc. Then de-domed changes things too. Right now, the BOSS1 I have needs to come out of the reflector a little for the best throw. I’m using a dedomed XP-L.
bushcraft
the cell 26650 are all in parallel right? because the working voltage is between 3v… has anyone measure the runtime? with the standard drive…
Tom E
Tom E's picture
Yes, parallel. No, didn’t measure runtime but you can do the math. If you use four 4500 mAh BASEN’s, 18000 mAh total, and pull 3.5A, as I measured stock, that’s over 5 hours, but actual runtime will be higher, probably 6-7 hours because as the cells deplete, the amps drawn (and output) drops.
It’s a light made for throw and long runtimes.
bushcraft
awesome…..
freeme
freeme's picture
Last seen: 1 hour 30 min ago
Minor update for 2017 version. New version now includes sling strap and tripod mounting hole.
wkhchin81
And also upgraded CaroNite 26650 5600S from one of the sellers. Tempted to buy one more for mod, but I got 2 already.
This light is so heavy with 4 cells loaded; not suitable for EDC, even mid-long hour carrying Big Smile
CWK
The Miller
In this 2017 revamp, did they make the threading better?
alex1234
Vinh sent me a Modded Boss1. It has his programmable driver and does 570 kcd and 1400 lumens otf. Im going to order a UCLp lens for it so maybe ill hit 600kcd. That would be plenty.
I really like this light, Its so obnoxiously heavy its hilarious. I use keeppower 5200mah for this light so 20,800 mah lol. I actually perfer the shallower wider reflector as it makes the spill wide and the hotspot neater and sharper and larger.
These are my measurements taken at 10m. beamshot below is in order of list
1)Deft edc X Enthusiast 510 kcd(my card says 404kcd but I always measure much higher no mater how well I calibrate. I think Michel measures very conservatively
2)M25c2vnT (618kcd)
3)Bossvn 570kcd
4)K50v3vn (has xhp35) 535kcd
Im on cpf more then on here. Im on so many forums some just get more love then others lol. But I just love how far TOM E drives these leds. Never knew 1900 lumens was possible with xlm2 u4.
Im sure Vinh could do the same but I think he tries to strike a balance between power and reliability as he sells a lot of lights so this bossvn is kept to a still respectable 1400 lumens.
