There’s a small issue with requiring people to post on BLF before they can get help from the retailer. It requires people to have an account. It adds another layer of inconvenience when it’s already too difficult to get good support.
As for the QA ideas, it sounds great. But first there needs to be actual formal QA, and before that there needs to be direct communication with no translators in the middle. That would likely solve most issues.
Have you had success with this on an MTG too? I have a light where the center is very yellow, and my two I just received also have this problem, yellow center surrounded by blue.
my tracking number said my lights were delivered feb 3rd, and i thought they had been stolen, but they came today, the 5th, and i have ss# 225.
they are very nice and i am NOT going to test them, or ever open them or do anything but let them sit there in their box #225 .
i will be open to offers for the set, by PM and i will be busy a lot and will not be checking messages regularly. i ordered NW.
OK, interesting, I havent had this happen except on an MTG light.
I am a bit disappointed in the tint on the two sets I just received just since I wanted WW and got a blue-y ringed beam due to a focus issue, I’ve got to figure how to resolve looks like. However I do like this tint more than any other CW I’ve had, even blue tinged its generally a nice white, not sure I’d call it NW, is it possible the bin is off?
Tint aside, absolutely beautiful lights, beautifully functioning driver, beautiful amount of light too! My wife has already complained about the tailcap glow though, how am I going to keep this next to my bed?
Just get those WW tint selections next time and a warmer NW purdy please
I have a yellow hotspot with blue spill on pretty much every reflector-based light I’ve ever used. Side effect of the “Cree rainbow”. Usually the entire hotspot is yellow though, instead of just part of it. The XP-L HI certainly improves overall beam consistency, but it seems to make the color contrast a bit more noticeable sometimes.
Swap the resistor for something larger. Dale posted a few days ago that he stacked a couple in his for 11K total resistance and had good results. Just this afternoon I pulled the resistor out of mine and swapped in a 12K. Its great, in my opinion. Very dim but still easily seen.
I put in a 10K and it's less bright, but maybe not low enough for my nightstand. Might try a 15K-18K. I did this on a NW Ss/Cu X6, and also tweaked it up:
TK's latest (Jan 16) firmware upgrade
centered the LED
replaced the 24 AWG wires with shortest possible 22 AWG
22 AWG wire bypass in driver spring
pulled out the inside spring in the tail and put in a 22 AWG bypass
all retainer ring/PCB contacts coated with NO-OX-ID,
all threaded body connections w/o-rings (3) treated w/Nyogel
Results are impressive:
the time to hold the button for reverse is much shorter, much improved
beam pattern looks improved, bout perfect to me (I love this 3B tint btw)
tail amps: 5.74A on a clamp meter
lumens: 1540 @start, 1472 @30 secs -- this is for the 3B NW tint
I’d like to do this too, but don’t know what to buy, especially since they are SMD. What size resistor fits, and what specs do I need ? Also, any idea on the LED size that is used in case I want to add a second one to even out the color? Thanks.
I remember reading that yours were stolen and felt so badly. Really happy that a mistake was made and you received them. Couldn’t imagine selling mine but that’s just me.
My lights have finally arrived and wow, wow, I could not be any more thrilled, these are just beautiful.
A whole lot heavier than I had imagined, S/N: 121
The magnet fasteners on the box lid is a very nice touch.
I am wondering though, with the aluminum set I am able to back the tail switch off maybe 1/10th turn back and the lighted cap will turn off, with these SS/Cu the instant the switch spring touches the negative of the battery the tail light comes on and it won’t turn off at all like the aluminum, that is both the X6 & X5,
I have to completely remove the batteries to turn of the tail light, Sure does look nice and if they don’t go off ever that’s fine with me frankly, just wondering though…
I imagine maybe someone has already seen this and if so can I please have the post # and see what the fix is, or maybe an idea or two?
Thank you TK your UI is absolutely awesome and thank you to everyone else that worked so hard, I don’t think these can ever be out done, the machining is so beautiful, wow. Thank you so much
Edit: Was reading up at #5416 about wife and tail cap light, are these actually meant to be on all the time?
I was thinking I would be able to back it off some like my alum’s and it would turn off…?
Or is that wrong and the alums should stay on all the time also?
Well, ok, if you say so. I never use anything smaller than 22 AWG except for wiring up e-switches or such. I mean, sure it’s a stock light, but one that comes with a FET-driver… But then, 24 AWG seems to work fine for well over 1000 lights purchased in this GB…
The aluminium set turns off when you loosen the tail cap because the threads are anodized, that isn’t an option on the stainless and copper so to turn off the tail cap light you have to remove the battery.
