I’d like to do this too, but don’t know what to buy, especially since they are SMD. What size resistor fits, and what specs do I need ? Also, any idea on the LED size that is used in case I want to add a second one to even out the color? Thanks.
I remember reading that yours were stolen and felt so badly. Really happy that a mistake was made and you received them. Couldn’t imagine selling mine but that’s just me.
My lights have finally arrived and wow, wow, I could not be any more thrilled, these are just beautiful.
A whole lot heavier than I had imagined, S/N: 121
The magnet fasteners on the box lid is a very nice touch.
I am wondering though, with the aluminum set I am able to back the tail switch off maybe 1/10th turn back and the lighted cap will turn off, with these SS/Cu the instant the switch spring touches the negative of the battery the tail light comes on and it won’t turn off at all like the aluminum, that is both the X6 & X5,
I have to completely remove the batteries to turn of the tail light, Sure does look nice and if they don’t go off ever that’s fine with me frankly, just wondering though…
I imagine maybe someone has already seen this and if so can I please have the post # and see what the fix is, or maybe an idea or two?
Thank you TK your UI is absolutely awesome and thank you to everyone else that worked so hard, I don’t think these can ever be out done, the machining is so beautiful, wow. Thank you so much
Edit: Was reading up at #5416 about wife and tail cap light, are these actually meant to be on all the time?
I was thinking I would be able to back it off some like my alum’s and it would turn off…?
Or is that wrong and the alums should stay on all the time also?
Well, ok, if you say so. I never use anything smaller than 22 AWG except for wiring up e-switches or such. I mean, sure it’s a stock light, but one that comes with a FET-driver… But then, 24 AWG seems to work fine for well over 1000 lights purchased in this GB…
The aluminium set turns off when you loosen the tail cap because the threads are anodized, that isn’t an option on the stainless and copper so to turn off the tail cap light you have to remove the battery.
Pilotdog68 designed an oshpark board with a switch inside the spring. It should swap in and add this ability.
[/quote]
So, this new switch will still have the LED , and it will function like the one on the aluminum light, a twist will turn off the light? Are these available now? Anyone know? Link please? Or contact Pilotdog68? Thanks.
The switch fits on the spring pad and only enables/disables the tail cap LEDs. It’s not in production and only an oshpark DIY board. You could probably find someone willing to put one together for you though.
My lights were stuck there from 1/30/2016 - 2/3/2016. I didn’t receive any notification until 2/4 and then it was delivered. Its the Blackhole of the USPS. Prepare to wait a few days. Have patience.
To the GB powers that be: I’ve bought lights in the EE X6 group buy, the A6, and now the Kronos set. It occurs to me, there has been a lot of complaining as well as a lot of love, but I think it’s fair to say each GB has been increasingly successful. The goals have been better reached, and the greatness of each light has escalated as well. At least it seems that way to me. So, I again say thanks, and hope everyone involved is proud, and encouraged. Things are skyrocketing, don’t you think?
I think the lighted tailcap adds a lot to these lights in terms of the ‘excitement factor.’ I was considering them without it, sure, really nice, but not as nice. Great innovation!
