I was looking into these few days ago. Seams bigger than it needs to be.
If 100 lumens is what you need…
It’s a power bank the gives off light. Low capacity but better than nothing. Changing out the battery would be my first goal, then not breaking it the second. It looks like a handy stocking stuffer but Christmas has already gone.
I just ordered one now.
And yes, the CL25R is the one I really would like to get, but budget is budget… unless I get a good discount for it
//Tank
Seems to be equal to this …
EDIT: Well, looks like we paid more than necessary http://www.banggood.com/Portable-IP68-Waterproof-LED-Tent-Camping-Night-Light-Outdoor-Travel-Power-Bank-Lantern-Lamp-p-997324.html
Most likely the same, I have seen these tube lanterns sell under many brands… Maybe buying blitz wolf might somewhat ensure that the internal
Battery is really 2600mah…
Pandawill used to sell these for cheap but I don’t know why they are so expensive now.
interesting, i wonder if there are any BLF codes that will work for a discount on that one.
This product is supposedly on promo right now and neither coupon or points can be used, I guess they’re getting rid of the old stock to sell their own brand only.
So, I got mine today.
Nifty design, you can pressurize the O-Rings to make this thing even more waterproof (turning the big 16-cornered thingys on both sides).
Light output isn’t that much, but I see this as an emergency-device, and the tint is very nice.
AND I GOT IT OPEN!
It’s very (VERY) easy to open
Will make some photos for you
So, at first I have to apologise - I had the White-Balance set to manual at first
The battery is hold in place with some tape and isn’t directly soldered to the pcb - it uses a plug (plug and jack were glued together, so I had to tip them both off)
2.5Ah instead of 2.6Ah? I want my germoney back!
And that’s how this thing seals up - the big nut presses the conical part onto the O-Ring and therefore press it to the outer tube.
Nice, thank you for these pictures. When did you order yours? Waiting for my 2 units and the tracking code doesn’t work… This is an unprotected cell, right?
The cell is unprotected, yes - but I hope that there is a protection circuit on the pcb
I ordered on Jan 29th 2016 - but with Priority Direct Mail, which is around twice as fast as the standard shipping to germany.
edit: It delivers 1.2 Amps for my 38% full phone at 5.07V
Nice, thanks for the pictures. So to open it you just pull both ends apart?
I thought the heatsink would be a half moon shape containing the battery, because my non waterproof model in extended operation at high modes does get pretty hot.
unscrew the big nuts, so that the O-Rings aren’t pressurized, and then just pull and twist a bit (no lubrification on the rings)
I want one
Just discovered that link is gone from GB now…
It’s not. My link got damaged because of the BLF update. I fixed it.
What’s the run time?
I did a runtime test with my unit. It shut off after 7 hours and 10 minutes at the high setting. You can turn it on again after it shut off automatically. I got another minute at high until it shut off again. You can do this again and again… At the moment I test how long it takes to charge.
Mine is modded with a Panasonic NCRB and I get close to 11 hours on high, and the amp draw at this level is ~300mA.
