Is there such a thing as Polycarbonate sheet with one side anti-abrasion and the other side anti-reflective? As you might guess I want the AR coating facing in and the anti-abrasion coating facing out. This is for an automotive light bar.
Look to the window manufacturers for ready made coated sheet. Parker “Duralan II” is one example I found: http://www.parker.com/literature/Chomerics/Duralan-II-prnt.pdf
Otherwise, there are many companies who specialize in coatings of this sort but the cost is probably prohibitive for a single order.
Vapor deposited AR coatings will provide you with some 3-5% more output but the cost difference may be significant vs uncoated sheet.
