Update 15.12.2015.
*Added LD-M2.
*Shipping price is now separated,no minimum orders for EU,25$ minimum for rest of the World(excluding shipping).
Update 15.12.2015.
*Added LD-M2.
Hey folksā brand new to BLF, joined because of this thread actually (awesome work here led4power).
Questionā how do I actually place an order for these drivers? I PMād led4power but Iām not sure if thatās the preferred method here.
Hi skandocious,PM sent.
Iād be in for a pair as well, if there is an Australian group buy going - Iām in NSW.
? You can buy drivers without group buy.
Yeah, I am a dumbarse
Iāll take one LD-M2 6A version. Thatās 22$ shipped to EU, right?
Hi Kazik,thatās correct.
Hi led4power,
Iād like to get one of the LD-M2 boards. I see there is a $25 minimum. Can I just pay extra for the one board? I really donāt need a second.
<25$ is ok,I will remove that from OP.
Awesome. Before I pay I want to make sure I have my ducks in a row. I am going to use this in a skyray king. Its an E switch light running 3 XML2 in parallel off 4x 18650s in parallel.
I am expecting about 9-12 amps of current so the driver I should get is the LD-M2 6Amps - optimized for 4-12Amp range correct?
For this setup all that is needed is to attach the wires correct? No sense resistor change etc?
Matt - if he holds u to the $25 I'll buy the other driver off u buddy.
-Myron
There are two main current sets for LD-M2 :6Amps and 12Amps. by changing current set resistors you can set current in 4-12Amps range for 6Amp version,and 12-20Amps for 12Amps version(actually some members use it for ~35Amps if I remember correctly).Lower current than 4Amps is possible ofc,2.5Amps is used often for xhp35.
Just tell me current you want,and I will set driver for that current,if you want to change current,I can send you different resistors for experimenting.
That would be awesome. If you can set me up so all I have to do is add wires, that would make my dayā¦ With this driver your just setting what the max current on high will be with that resistor right? If so putting it at 12 amp will be fine. My setup will be with an E-switch on a 3.7V pack.
I sent payment earlier for the driver and tracked shipping. If there are any other charges for fiddling just let me know and I will send the rest.
By changing ācurrent setā resistor all modes (except moonlight) will be scaled up or down by same percentage. So if you double current on high,other modes would be 2x higher also.
Ok, that will be fine. I think the 12 amp setup will be about right.
Just paypalād an order :disguised_face:
Iād like to order 2 LD2 driver with 6A both with ML presoldered (single cell). Tracking number is not necessary for me. Can you pm me what to do to set the order?
Hi K,PM sent.
Can you PM me an offer for 1 assembled driver with shipping to MK, with 6V (2s) for XHP70 on 9A, with moonlight and all, so I solder only the wires?
