Zoom, I’m not following how a smaller switch with a FET would work, can you elaborate?
I'm not too familiar with electronics, but since we are charging the host with +power to power the leds(connecting batt+to ground through bleeder resistor) maybe that can be used to trigger the gate leg of a mosfet (with a tactile switch) which would then allow power to flow between the source and the drain, turning on the light... Or if there is a way to put a negative trigger on a negative load from drain to source? A mosfet would be able to handle the power with ease so we wouldn't be burning out switches anymore.
I am not real familiar with different types of mosfets, so wether it would need an NPN or PNP or other type of transistor is beyond me. It may just be wishful thinking on my part but hopefully someone that knows more can chime in?
Those are two separate groups.
Some evaporator users consume other than tobacco…
Those people (except in Colorado and Washington) don’t buy from public sources.
You’re a public source. You don’t get patronized by the people I’m thinking of.
Nothing in that description refers to you.
People can tell the difference.
You are overgeneralizing and stereotyping an entire community, and in essence myself being included in that community calling me a stoner. Which I am not. That is ignorant. You are being ignorant. That is not calling you names, that is stating fact.
This is not the place for that discussion, so I digress.
Any way to make the led pulse?
Are resistors needed for MTN’s 17DD FET drivers?
Yes, the 17DD drivers, just like most (all?) common lineair drivers, need a bleeder resistor to leak enough current for the tail circuitry
Full assortment of the smart and latest non-smart boards arrived today… Is there any firmware that anyone has hacked in prep for these boards? If so, where to get it? I may get time to put one together this weekend for testing. I will get one of the new ring boards together as I have a need for one.
You got yours before I got mine! Did Osh cut the middle out of the rings like they were supposed ot?
I got a shipping notification for my oshpark order today, so mine are on the way. I didn’t order the smart boards though. Probably going to regret that when you guys start putting together that new awesomeness and I’m here just building my first “dumb” boards
I’ve got too much on at the moment so I’m going to wait and see if you guys can get the smart boards working then I will jump on the band wagon.
Good Luck
I got some “dumb” boards today, still waiting on the “smart” boards. Moving the LEDs up and getting rid of the spacer/washer brings a huge increase in efficiency.
Notice my meter is on the micro amp scale = 0.0207ma. So theoretically a 2500mah cell would last 13+ years of constant use before being totally empty. I had to completely max-out a 50k pot to get this brightness.
Don’t worry, an attiny will bring that crazy runtime back down to sane levels.
Sorry if this has been mentioned (haven’t read every post), but has anyone tried the multicolor led’s that change colors?
I did buy some to try, but they were too big. I haven’t seen any smaller than 5mm.
Now you’re talkin’ - that’s the kind of number I like.
I got some that are 0805 footprint. Slowly change colors, but stay on red the longest. Looks interesting sitting on a shelf. I think it needs more voltage than the standard LEDs.
On a different note, have you considered putting some more of the consolidated knowledge in the first post?
Typical resistor values that work with different color LED’s, etc? Makes it easier for people who have not been following the thread from the start.
Got most of the smart board built today. But, when I test them onboard with diode check on my meter only the pair 4 will light. Pairs 3 and 5 appear to not be good onboard, if I remove them and diode check them they light fine? I do not have the resistors on the board for any of the LED’s, I plan to solder small wires in place and breadboard it so that I can find the correct resistor values. Not really sure where to start, maybe 2 to 4K. I will also breadboard the power supply to the board so I can get the 560 dropping resistor in-line with out doing weird things to a light.
[quote=jingleberry]
What a GREAT idea!!! I want a pulsing LED on my tailcap! And selectable pulse modulation. Is that the right word, modulation?
