1. When the website was under construction, you posted a link to a Status Update blog … but you never posted any updates. The next time, could you post a message, especially after the scheduled completion time came and went, something like: “Sorry, guys! Still trying to sort through things (you know the routine, two steps forward – one step back). Don’t know when the site will be up. Thanks for your patience! )”
Sorry I kept you in the dark. I did try to pop in to the shoutbox from time to time, but I got so engrossed in the problem solving I was working through that I just couldn’t manage to break away. I barely got out of my chair during the whole time period, if that’s any explanation of how concentrated I was.
Quote:
4. No subject line on each individual response. Is that permanent or just something that will be worked on later?
I actually disabled that because I never really saw much value in a subject for a forum post, especially since most just left it blank and it got filled with the first ~25 characters of the actual post. I think it looks cleaner and more streamlined without them, but I’d be more than happy to re-enable them if the majority prefers it that way.
Quote:
5. Suggestion: Provide more separation space for “Log out”. Spacing is fine when using a mouse, but I’ve accidentally logged out several times when using touch screens.
Hmm, ok, good idea. I could probably move it to a different “block” region.
Quote:
6. Suggestion: Provide more separation space for “SPAM” button. I’ve accidentally hit the SPAM button (numerous occasions) when using touch screens on my tablet or iPhone.
This is a bit more difficult. I agree that it’s not ideally placed. But even if it does get bumped, it doesn’t register as a spam click unless you also hit the confirmation button.
I’m not sure if this has been mentioned, but I just noticed everyone’s location is gone. Will the locations come back? I doubt it matters much, but just wondering. Thanks again.
Yeah, I was trying to add it back, but it’s very poorly documented and requires an intricate knowledge of several underlying systems to know how to code it properly. Maybe if some expert (cough @ToyKeeper) could give me a few tips I could probably figure it out.
Thanks for getting us back up and running. Its strange that the temporary DNS link does not work for me. The only way I could get to the site was by using my VPN.
Strange. At any rate, everyone should have the new address via DNS by now.
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
I’m not 100% sure, but that might be a side effect of the signatures getting truncated to 255 characters. You may simply need to re-build your signature.
I’m not getting e-mail notifications to Subscribed threads. Is this a work in progress?
It’s the last item on the list, and it sounds like it’s going to be difficult to fix. Probably some old drupal extension which only works on the old version, so it must be more or less rewritten to work on the new version. I’m just guessing, but that’s a pretty common thing during major drupal upgrades.
I haven’t actually used Drupal since 2008 or maybe 2009, so I’m a little out of date on it… I mean, I could look, but I can’t promise much. I’ve been avoiding PHP for over a decade.
I'm not 100% sure, but that might be a side effect of the signatures getting truncated to 255 characters. You may simply need to re-build your signature.
It's not just signatures. Post an image anywhere on BLF, and then try to add a mouseover.
Mouseover images are supported anywhere that the Advanced Post Editor is supported. However, for now the mouseover code needs to be manually added to the posts using the Advanced Posts Editor "Source" button. The source code looks like this:
Worse than that! It’s custom functionality hacked together by yours truly with a combination of Fields/Flags/Rules/Userpoints and custom PHP snippets when absolutely necessary.
Not sure yet how to go about implementing this. Do you think a sticky post with an easy copy/paste block of code for rollover images would suffice?
Quote:
2. Could you make it so that we can choose our default "Text format" on the forum, and in private messages?
(I use "Advanced Post Editor" for both, and have to make that change with every post and PM.)
Sorry about this one. That was also a piece of add-on functionality that I installed a long time ago, and it doesn't seem to be available for this new version. I'll see if I can eventually find a work around or put together something custom. But I'd recommend for now that everyone give the Simple Post Editor a try-- it's much faster and cleaner and more enjoyable (for me) to use, unless it's something highly complex like a review. At any rate, sorry for the reduced functionality at the moment, I guess you gain some and you lose some with technology "upgrades".
Budgetlightforum.com works on my phone (mobile internet) but on my computer at work I still get the page with links to the temp. website and blog. I already erased history and cookies, it does not work on three different browsers. I’ll try again at home.
Hmm, I imagine that they have a DNS caching server at work that hasn’t refreshed yet.
Thanks for the good feedback!
You mean you don’t have that moment burned into your long term memory and celebrate your BLF inscription anniversary?
Correct, that whole system is temporarily disabled for now, except for manually subscribing to threads and seeing updates at My Subscriptions.
Long term memory
I think I lost that back in the ’80s …
What I do
I still haven’t seen anyone else that’s missing a Private Message button . Just me . Not that I get many PMs .
What I do
I see one for you. I assume the system doesn’t show a button to you because you are, well, you.
I also don’t have one for myself.
Oh .
What I do
I lost a lot back in the ’80s .
What I do
The new site looks pretty sweet, sb!
...though I have a couple of requests.
1. Could you bring back mouseovers for images?
Thanks!
Also...
Congrats on 5001 posts, sb56637! *drinks*
How to Post Images on BLF // Many knives for sale (USA only)
How to move a thread // WTS Brand New Timex Expedition Vibe Shock Camo Watch (USA only)
very good update the page number on top and bottom are very good news.
www.flashmylight.com
Reminds me of a line from this old joke
http://unix.cc.wmich.edu/~cooneys/poems/safe.fax.html
I propose that in honour of this accomplishment we create a new ISO 5001 standard related to lumen measurement and CRI
The Journal of Alternative Facts TM
Hey, no mouseover images.
xkcd.com/1603 Li-ion battery safety 101.
don’t know if it’s already been addressed or not. If it has been, don’t yell at me (hey, no Smileys!?)
I’m not getting e-mail notifications to Subscribed threads. Is this a work in progress? Not being pushy here, at all. Just pointing things out.
thanks.
Site's looking fantastic, sb, good job!
Good job with the update SB. I do know what a PITA it is before everything is running smooth again!
Am I the only one who doesnt like the shadows on the buttons? They give me bad 1990 vibes
I’m loving the new look wink
^_~
(Don’t know why there are four winks though, lol)
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself.
<a href="#" ><img src=" URL_IMG-1 " onmouseover="this.src=' URL_IMG-2 '" onmouseout="this.src=' URL_IMG-1 '" /></a>
Very wise choice!
Thanks!!
Back on my feet, after a few days in bed (no thank you: alone
). All I can say is: this looks terrific to me! :THUMBSUP:
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
link to djozz tests
