Zenbaas, I also find 0.4 lumens useful. Just not with flashlight that big. When, I'm lugging such mace, it means that I need a lot of light with as much throw, as I can get. In low mode it draws about 0.4A from 2x18650 ...so this is still a lot of light. Enough, for illuminatin 150m away targets.
As for the diffuser, both SR50 and 7G5 have similiar head diameter. So I guess it should fit, or at most needs just a little tweak.
7G5 looks like a poor man's catapult and as I am a poor man who - very much - likes catapult, I might get a 7G5 instead
I am a little confused about Crelant compared to Fandyfire STL-V6 / SkyRay STL-V2. Are they any similar? Does one of them throws better? Has more lumens? Better driver? Better regulation?
I was going from this comment - “take into account, that BD-4, while the weakest in throw here, is a dedicated thrower with over 35K lux/1m. It has far more throw than other popular flashlights, that are considered to throw quite well (Fenix TK35, Jetbeam BC40).”
That makes it sound worth the extra, you comment rather makes it not lol
Jeansy, the Balder BD-4 is confirmed a shelf queen. It is the best looking of the lot, and the most solid of the lot i think. 420g of aluminum! Crelant 7G5 is 390g. When you hold it, there is no mistaking it for the STL-V6.
Jeansy, you made a good decision. This light not only has greater built quality in every aspect, that the STL clones. It has also much deeper reflector and it's driven harder. It also lets you to use 2x18500 in short version.
amraspalantir, you are OK to use 2x18500 imr. They won't fry the light, since it has step down converter. Just be careful about over-discharge of the cells, because this light probably hasn't any over-discharge protection and I presume your 18500 imrs are not protected.
Oh... and while talking about robust construction, I think Catapult is more heavy duty than BD-4. It's heavier and made from alloy, that is ~60% stronger.
I know they're based on M31/M3X ...But they're so heavy inspired, even in internal design, that for me, they are clones. Good ones, but clones. Pity, that they couldn't clone non-PWM circuit.
Although, I didn't know about extension and ability to run on 18500. If not that horrible PWM, I'd probably buy one :)
