It looks like M4D M4X explicitly set a background color on each link in that listā¦ or set it once and copy/pasted it a bunch of times. The first half of the list has styled links, while the second half has styled spans. And a few items are bare.
I can override it, but itās kind of a violation of scope. It would prevent anyone from ever setting a background color in the text of their posts. At least, in links or spans.
So, what do you think? Should it override style mis-uses (and also override normal uses too), or should it allow both (and give us an occasional hard-to-read post like that one)?
Thanks TK! Got it working on my tablet in firefox. Nice for in the evenings, and when I want the classic style I start blf in chrome
It is now even more obvious that the battery is inserted backwards in saypats avatar
Yes, I removed the ātopā links. Or maybe the file I started with did that, I forget. I havenāt missed them though.
If you search the css file for ājump to topā, thereās an obvious ādisplay: noneā line to edit to get the links back.
On Android, after reading through a thread, I usually just pull up my bookmarks and go directly back to the my-subscriptions page to find the next topic. Iām not sure if this works for you or if getting the ātopā links back is better.
I donāt mind the lack of the top button, but when at the end of a thread, I normally use the home button to get back to the recent posts page, now I have scroll to top to hit the recent posts button. Or do I do something obviously wrong?
Thatās odd, since I didnāt actually style that. Iām not even sure how to style it, since it renders itself with some fancy javascript. However, it seems that I can at least change the text color by changing the main global document text color.
BTW, did you see the complaint earlier about the interest list in one of your threads?
It seems the list items have explicit background colors set. Iām not sure if thereās an easy way to remove the style though.
Ah, okay. I never noticed those links before. It looks like the file I started with got rid of the entire footer. I added them back though, and itāll be in the next update.
