BLF After Dark, CSS theme [not relevant anymore]
The after dark style seems to have removed the ā€˜back to topā€™ and ā€˜homeā€™ buttons at the end of each pageā€¦ (firefox, android)
GREAT !!
thanks
Yes, I removed the ā€˜topā€™ links. Or maybe the file I started with did that, I forget. I havenā€™t missed them though.
If you search the css file for ā€œjump to topā€, thereā€™s an obvious ā€œdisplay: noneā€ line to edit to get the links back.
On Android, after reading through a thread, I usually just pull up my bookmarks and go directly back to the my-subscriptions page to find the next topic. Iā€™m not sure if this works for you or if getting the ā€˜topā€™ links back is better.
in advanced post editor the letters are black on dark :wink:
I donā€™t mind the lack of the top button, but when at the end of a thread, I normally use the home button to get back to the recent posts page, now I have scroll to top to hit the recent posts button. Or do I do something obviously wrong?
My eyes and myself thank you for this :slight_smile:
Cheers David
HA! Nice one TK! :beer:
Thatā€™s odd, since I didnā€™t actually style that. Iā€™m not even sure how to style it, since it renders itself with some fancy javascript. However, it seems that I can at least change the text color by changing the main global document text color.
BTW, did you see the complaint earlier about the interest list in one of your threads?
It seems the list items have explicit background colors set. Iā€™m not sure if thereā€™s an easy way to remove the style though.
Ah, okay. I never noticed those links before. It looks like the file I started with got rid of the entire footer. I added them back though, and itā€™ll be in the next update.
Why not have BLF serve this theme up and let the user decide which theme to use? Put the userā€™s choice in a cookie and voila!
That would require SB to add a theme selection system, and then officially support both. Itā€™s extra work for someone who is already backlogged.
Okay, a new version is published to userstyles.org. In no particular order:
  • Re-added explanation about how email notifications work on ā€œmy subscriptionsā€ page, but made it smaller.
  • Made text readable in the advanced post editor (and as a side effect, changed the default text color everywhere).
  • Moved ā€œWrite new messageā€ link to a nicer spot in private message pages.
  • Made ā€œ(new)ā€ marker stand out more, black on red shadow.
  • Fixed weird junk color on form section titles, like on the ā€œmy accountā€ edit pages.
  • Re-added the poll widget in left menus.
  • Re-added the ā€œJump to topā€ and ā€œHomeā€ links at the bottom of each page.
  • Added styles for input widgets, buttons, text entries, etc.
  • Made a few action links look like form buttons.
  • Removed background colors from links and spans in forum posts. (not sure if this is a good idea, but it makes some posts look better)
  • Made signature text smaller on each post.
  • Hide tables in signatures (should probably not do this, feedback welcome).
Hereā€™s a small preview:
Installed. Thanks for this TK, much better
I didnā€™t know how much I needed this till I saw this. HUGE improvement!
Many Thanks!
This is awesome, thanks TK for everything (including turning me into a linux convert!)
I did what?
Small update:
  • Minor color changes on quotes.
  • Styled <pre> tags, which were missed before.
Separately-installable style published to limit quote nesting depth.
Also, a couple other separately-installable styles added to get rid of other page elements, but not published on userstyles.org (only on tk.net). They remove stuff which shouldnā€™t be removed, like the search widget or some other things, so theyā€™re not included by default or as easy to install.
The day that the forum was down we chatted about which linux distro would work on my netbook, got linux mint installed and flashed my first drivers from linux last nightā€¦i owe you much gratitude (and drinks!)
perhaps i should try this instead of windows on an old laptop, i was going to start a thread asking if there is a legitimate windows 7 iso since i have the sticker on the bottom with the serial number but no install disk
dual boot would probably be best though
finally i use it.its better i have to sayā€¦only one thing i lost,but its after the server upgrade-i lost notifications about my pm and threadsā€¦.cant found how to change it backā€¦
I was mostly teasing, but Iā€™m glad to hear that it worked and youā€™re able to flash drivers. :slight_smile:
