Some cheap sourcing.
A member earlier posted a thread on This AA/14500 light from eBay which was $2.58 each when I bought 2 last month and contained this driver.
Removable threaded pill so easy to mod and you get what looks like a nanjg 110 and host for not much more than the driver alone. Bought it mainly for swapping into Incan minimags after reducing current for 2xAA to around 150-200mA. Switch doesn’t look worth much but lens and reflector ok to use.
Thanks for the explanation, wight. I think I understand now. And your post didn’t seem mean at all to me.
Thanks to RBD as well. You were trying to tell me. I just couldn’t get it, because I don’t know how driver circuits work.
No problem. Flashlight circuits can be pretty tricky stuff. I often resort to grabbing a sheet of paper and drawing the circuit quickly when my common sense fails me… but to be useful this practice does require a basic knowledge of how the circuits work.
IMO boost circuits are one of the trickier-to-understand circuits we use here. The idea that we could literally short the battery through an inductor thousands/millions of times per second (bypassing the LED entirely!) and still achieve an efficiency >50% is pretty crazy. Boost circuits can actually be very efficient (>90%)… we just won’t achieve that with this driver.
HQB17 v1
17mm boost driver, based on the 15mm version
17.6mm actually, the yellow ring shows 17mm
adapted for larger toroid (5.8 x 5.8 mm)
additional info is to be found in the HQB15v1 post and the HQB15v2 post
Partlist
(see post#26 for more info on the parts)
EDIT: The values below are derived from the successful build of the 15mm board, but my very well vary. It’s all in development at the moment.
Switch: PAM2803, SOT-23-6
L1: min. 2.2yH, 4.7yH recommended, up to 5.8 x 5.8mm, 6x6mm might work
D1: BAT60A, SOD323 (Mouser) (Farnell)
R1: 0.120Ohm, 0805
R2: 150kOhm, 0605
R3: 33kOhm, 0605
MCU: ATTiny13A-SSU, Package 8S1
OTC: [1yF], 0603, X5R or X7R [OTC not tested yet]
FET: (from FastTech driver)
Note on C1-C3 capacitors: The values of the PAM2803 datasheet are in all probability too low for our purpose, as we add modechange and PWM to the circuit. The values below are the ones I successfully used with the 15mm board (post#84). I took the highest capacitor values I could source. Less might work; use carefully.
C1: 10yF, 0805, X5R
C2: 20yF, 0805, X5R
C3: 4.7yF, 0603, X5R
C2 and C3 are by design in parallel (C2 as close to PAM2803 pin5, C3 as close to ATtiny13A pin8). I added C3 to be able to increase capacity with a second capacitor. Smaller values might work, populating only one might work; use carefully.
The board is provided as is and yet untested
Can we not add our normal R1 and R2 and add LVP to the firmware for this board?
Increasing the size to 17.6mm is to make soldering the driver in place easier, is this correct? In reference to the 2oz/0.8mm boards OSH Park says “Castellations are allowed, but not officially supported.” That could be an alternative to oversize boards. We’d probably need to contact OSH Park support to see precisely how castellations should be indicated of course.
Bah humbug. If you want LVP so badly just air-wire it with 1/8w resistors. I don’t see “extra” space on HQ’s board.
Then fix the firmware to not go into LVP with a NiMH/Alkaline/Lithium-primary/etc. I don’t think that this task will be complex, but it must be done.
EDIT: Just in case you are not aware… LVP isn’t needed for operation with AA cells such as Alkaline, NiMH, and Lithium primary. LVP in flashlight drivers is to protect Li-ion cells from overdischarge.
Very nicely done.
As we know Oshpark does not deliver copper to the very edge of the driver. There are 0.3mm missing.
I oversize drivers for 2 reasons:
- making them easier to solder and
- securing contact for drivers I want to press fit.
Castellations as I understand are copper plated half-holes at the edge. I’m afraid these half-holes would simply be deprived of 0.3mm copper as well… I think it’s a manufacturing process/problem.
I had tired several changes in eagle to avoid this: Smaller Dimension(20) circle width down to 0.001; Milling(44) instead of Dimension(20); Oversizing the Top(1) layer so it’s larger than Dimension(20). All to no effect.
So I simply oversize 0.6mm (pay the additional 7 cent per 17mm-board) and file down. With a dremel and this sanding bit it’s done in seconds.
To the Li-Ion issue.
There is a difference between surviving a Li-Ion (4.2V) and being designed for it. The PAM2803 is not designed for 4.2V Li-Ion and I will neither use nor test it. For single Li-Ion a linear driver is a much better option.
LVP would limit the options for those cells, this driver is intended for, which well includes all kinds of primary cells from 1.5V to 3.0V.
EDIT: partlist added to post#113
I don’t know why they’d even bring up castellations if they aren’t going to get plated. See here - OSH Park Docs ~ Services ~ 2 Layer 2oz 0.8mm Service
LVP, if you gotta have it, just glue the voltage divider on top of the mcu. You’ll still need to choose appropriate new values and add the programming. Do that before you glue and air wire.
For these 15mm boards. Do we know how tall they will be?
depends on oshpark pcb and inductor used
I stated heights in post#84
How will the programming need to differ from other 13A controlled drivers? Would it be possible to swap a 105C mcu and leave LVP unconnected? Build one and see?
The only difference is that we’d disable LVP when building the firmware. From HarleyQuin’s work earlier in this thread I think it’s safe to say that standard PWM freqs are OK. Lower PWM freqs could be required to eliminate buzzing/whining. I still don’t have anything built; my donor drivers have not arrived from FT yet.
I can’t remember = build one and see. Worst case scenario, simply tie LVP pin to Vcc. Leaving the pin ‘floating’ could lead to unpredictable results…
I’d be interested to know if there is a better FET that could be used.
Irlm2502 Rdson 40mOhms at 2.5V vs 40 mOhms at 4V. I’ll have another look at the lfpak 33 but it might be too big.
This lfpak33 sold by RMM seems to have good specs too.
The lfpak33 is similar in size to the others but with obviously a different footprint. I don’t know if that’s advantageous or not.
I used the usual 18 kHz. What bothered me most was that at PWM-1 it still gave 16mA. That’s pretty much for a lowest mode.
The FET I used in my first Nanjg110 conversion (Post#24) was a IRLML0030TRPbF, which has (according to datasheet) even a slightly lower Rds than the IRLML2502.
Out of curiosity I made a quick and dirty draft of the LFPAK33 in the 17mm board. It’s a mere finger-exercise just to see the part in the board. The LED pads are not on opposite any more, which could be a severe blow if height is a factor. A smaller inductor would give more space on the board, but we might lose more efficiency with a worse inductor than we gain with the LFPAK33. But I’m only guesstimating here.
Here is another layout which stays closer to the Fasttech driver.
The advantage of this design would be, that most parts could be sourced from the Fasttech driver. Only the ATtiny13A and the OTC are missing. Including R2 and R3 and the SS24 diode I could not fit it resonably onto 15mm, so this is a 17mm design. C2 might be not sufficient, though.
It’s an earlier version where I tried to stick to the supersized SS24 diode. I abandoned the idea as far as I’m concerned, as the BAT60A works so well. But perhaps someone else has use for the design.
17mm layout to source most parts from the Fasttech boost driver
Update:
- I received the FT boards today. Along with the diodes ImA4Wheelr sent me and the v018 PCBs from OSH Park I had everything I needed to start testing.
- First I built the boost circuit on my v018 PCB. This functioned as expected.
- Next I populated the MCU and transistor. Since (as HQ keeps reminding me) I never bothered to hook Gate up to MCU Pin 6 like it’s supposed to be I bridged 5 and 6 together for now. Unfortunately this setup has not worked correctly. The driver lights the LED but I have no modes.
Maybe tomorrow I will troubleshoot the situation. The issue is most likely the lack of pulldown resistors. I forgot or did not realize that the FT board uses 0603 sized components. Maybe I will re-do my board with that size of component.
EDIT: Bad news (for me). I was hoping to “trouble shoot” the driver in the sense of “install those resistors and see if it works”. Unfortunately I got motivated just now and installed the resistors. The behavior remains the same. That means that the next step is real troubleshooting with DMM / scope / loupe etc. That is definitely not going to happen tonight, but might happen tomorrow.
wight, At what current does the LED light? Could it be a firmware issue?
HQ- true, not quite diametrically opposed but if OTC were rotated 90^ clockwise towards the via the LED pads would be closer to opposite on the lfpak33 board. I was looking at the Rdson graphs rather than the rating at 10V. According to the graphs the 2502 drops below 40mOhms at 2.5Vgs vs 4Vgs for the 0030 (look at figures 12 and 11respevtively). In any case the proof would be in the pudding or maybe I’m completely misinterpreting those graphs.
If the driver has a spring on it then it seems to me that it might be ok clearance wise to go ahead and put the odd 0603 resistor on the bottom especially if, as with pull down resistors or caps the part is grounded to one of the pads and only one via per part is needed. 3 or 4 such part placements might clear a fair amount of space for a larger inductor and make soldering the darn things easier to boot.
