That’s odd, since I didn’t actually style that. I’m not even sure how to style it, since it renders itself with some fancy javascript. However, it seems that I can at least change the text color by changing the main global document text color.
BTW, did you see the complaint earlier about the interest list in one of your threads?
It seems the list items have explicit background colors set. I’m not sure if there’s an easy way to remove the style though.
Ah, okay. I never noticed those links before. It looks like the file I started with got rid of the entire footer. I added them back though, and it’ll be in the next update.
Also, a couple other separately-installable styles added to get rid of other page elements, but not published on userstyles.org (only on tk.net). They remove stuff which shouldn’t be removed, like the search widget or some other things, so they’re not included by default or as easy to install.
The day that the forum was down we chatted about which linux distro would work on my netbook, got linux mint installed and flashed my first drivers from linux last night…i owe you much gratitude (and drinks!)
perhaps i should try this instead of windows on an old laptop, i was going to start a thread asking if there is a legitimate windows 7 iso since i have the sticker on the bottom with the serial number but no install disk
finally i use it.its better i have to say…only one thing i lost,but its after the server upgrade-i lost notifications about my pm and threads….cant found how to change it back…
That is completely unrelated to the dark theme and unrelated to anything you did. The problem is that BLF itself got a major back-end upgrade and the email notification feature doesn’t work yet. Subscribe to this thread for updates about that issue:
