Don`t worry be happy.
We are one family.
I am happy to be the owner of the SR 90 shorty,produced by Vinz. :
Manker or some other producer are unable to produce such a light,
The big sized light is a mans world light
lol
Regards Xandre
We are one family.
lol
Regards Xandre
Wow, luminarium iaculator maybe I miss something, what is the diameter of that lens?
Vinz builds some fabulous lights. Have seen some of his work before but those two are spectacular. Both probably way out of what I want to spend on one light.
Great work!! Really, it looks good to me, for the function part of its job. I would carry it any night to my shooting bench for some target illumination. Unless I used goggles for the spill light and a bee keeper’s suit for the swarm of mosquitoes that are coming, I might be done in a hurry, though.
I like that you chose the single copper plate. I also like that you tried it with reflectors, good way to experiment. I too am looking at combinations of reflectors, to use in the group with lenses.
I can say that I would have installed a custom lens arrangement instead, but in some situations—money aside—the reality is that a cluster of reflectors can often be very beneficial over giant lenses in this range—this size of light. Reflectors from a known host also have a known beam profile and capability. If 3 fit, than 3 will work, and it’s get to the next task. Lenses have to do much more than simply fit inside a shell! A single lens will take some effort to tune the optical system to that host, because it would take more than one primary lens to achieve focus near that copper plate, while keeping a “known performance” level. If a 225-250mm aspheric lens was used with even a more shallow 0.40 NA to help lower lens weight, just imagine how much glass would still be at the front. You would feel it alright. A reflector and G2 trio isn’t a bad option in his case.
Special method and “no green”? I always called that proper dedoming, not special. Someone figured out it’s special when you don’t damage the item being used as the centerpiece. Heh! I’ve seen the “green”, and seen it well, but not from my own dedome. (Stock OLight factory dedomes, clean, but greens everywhere. Simple fix with new LED.) You can “spray” LEDs with a lot of things to influence their color, put glues around the die to keep 450nm bouncing around, they don’t really care until you start blocking lots of light to cause a thermal runaway cato failure. Heck, you can color the die with crayola crayons if you want, just use the right color. Don’t hold me accountable for the bond wires, burnt LED, and giving away the $1300 secret. I mean, taking a wild guess. I didn’t do it.
88mm per reflector. Hmm. 3* L-RADWs might fit in there. Kidding, kidding.
Way to go on the throw and the light. Hope to see you keep your imagination working hard.
Not me, but if it’s a good picture, throw some word or username in it like some of us do so we get credit when it’s tossed around the web.
But that is the stock Feilong D80 lens I think, right? The base of the light head looks like a J20 head base, but doesn’t use the same machining cuts as it internally. If it did, you could really up the ante of that light with “the driver”, for the J20 builds. Speaking of that…
That is a very nice looking build, part of why the J20 was picked for the monsters in the making—the cooling head is similar on the FeiLong, but a section of head material (~7 fins) shorter in length than the J20. I know theres a few stock lenses which will smoke that BV lens if you ever consider the upgrade. Those bezel spikes, I wouldn’t want to be in a hurry and have it roll off a table to land on a shoe. Bye bye big toe.
This is not my build. It is Vinz Germany build.
As far as I know juts an aespheric lens………but of very good quality.
Led dedomed, bonding wires strengthened and on top of that a pre-collimating lens, so not light is lost.
Grtz
Nico
HAHA, no, my toe wouldn’t like that much either. Those bezel spikes are mean and even a bit impractical as the light does have some significant “back-throw”.
When you’re out in the dark and the light is on max it can really hurt your sight. A definite improvement point.
I don’t know which head was used and even if the original lens is still in there or whether that has been replaced.
What I like about this light is not only the excellent performance (for an aespheric the spot in insanely large, and therefore very practical) but the pure craftsmanship throughout the entire light. Nothing, really nothing can be compared to the quality of the original Acebeam/Thrunite components.
Extremely tight threads, excellent ano, the selectorring turns with just enough resistance and extremely smooth, nothing scratching, not even remotely, without any play.
Cheers
Nico
What are you thoughts about 3 XHP 35 hi ?
Regards Xandre
Then it´s not longer the “LED LUX MONSTER”, but rather “LED LUX LUMEN MONSTER”.
Now the name is Lumensteins Lux Monster
We did it. :smiling_imp:
Regards Xandre
PS got today a Mjölnir with XPL hi
Some Pictures from the inside
The heatsinkweight is 1475 Gram
that means it is heavy
Store your photos and videos online with Photobucket's secure storage. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
Regards Xandre
Beamshots will follow…
Inside :
LD M2 @8A
Lippo 4s
3 XHP 35 parallel
Ca 5-6000 Lumen
ca 1,6 mio Lux measured at 7 Meter,
we think it is more at more meters,we measure it at Saturday at 30 meters.
Regards Xandre
Pictures from Outside:
What is the diameter of those reflectors?
Those Reflectors are Reflektors from Olight SR90.
That is one Monster light.
The usefull diameter is 88 mm
It is so bright, that if you are use it in the house,
it is recommended to use sunglasses.
Regards Xandre
Lux @ 27,45m: calculate back to 1 meter
Some measurments orginal and mods
Convoy L6 Mod short… 91.913
Convoy L6 Mod… 113.82
TinyMonster 60… 130.612
Acebeam K60 … 160.443
Thrunite TN36 light… 337.818
FireFox4 … 347.493
Acebeam K70 … 445.472
Mjölnir… 459561
Thrunite TN32… 482.942
BOSS1 Mod CW… 486.974
BOSS1 Mod NW… 507.936
X7 Mod Andi … 546.636
Fenix TK61 Mod Sma… 592.592
Lumensteins Lux Monster… 1.894.682
Maxabeam… 6.530.606
a great light for sure!
thanks for showing
