Cool.
I must say, when I saw it I immediately thought the head design looked a lot like the X6.
Cool.
Does any here have experience with the Olight M3XS‑UT Javelot? If yes… how does the Thorfire compare in these categories:
Throw
Spill
Form Factor
Thx!
LONG LIVE BUDGETLIGHTFORUM!!!
PD is it possible to get a Pic of the driver?
There is one in the OP (click for larger) or are you wanting a different angle or something?
Huh, it wasn’t there when I last looked, don’t know if it’s on my end or BLF’s, but pic’s aren’t loading, or loading slow? Thanks, I see it now!
Sorry I missed this question earlier.
I don’t have the Javelot, but my understanding is that they are totally different lights. The Javelot is more of a dedicated thrower, whereas the S70 is more of a mid-range light with a wide beam profile. I believe the S70 is much bigger than the Javelot as well.
Great, thx for responding pilotdog. Great review, I wish I had your knowledge.
Does this light require button or flat top cells (or either) ?
Also as I will have to buy new cells for this light as I presently don”t own any 26650”s any recommendations on good cells.
Short answer: button tops
Thanks for that pd.
Any recommendations on a cell.
If the Cometa group buy I am in also takes button tops then I will need to buy 4.
As both lights have low voltage warning & cut out features I imagine I don”t need protected cells.
I’m not the best person to suggest a button-top 26650, I’ve never had one.
I plan to buy some of the Basen cells freeme is trying to start a groupbuy on, though I think they are flattops so I’ll add a button to one of them.
The Cometa should take flattops though.
Thanks for the info pd, they will be my first 26650”s also as at present I just have lots of 18650”s but would like to run the S70 & Cometa on 26650”s for the extra capacity (run time).
Unfortunately I am in the UK & think postage will probably kill the deal although I will have a look.
From what I can see good quality 26650”s are quite dear in the UK, probably the equivalent of around 14-18 dollars a cell !
EDIT:
Just checked shipping & the cheapest is over $50 dollars so it is a no go.
Newly shaved LED…
Also, who knows how to do a resistor mod? Just throw on an extra sense resistor, or is there a way to dial it in with less guess-work? This driver has two R091 resistors in parallel and an extra empty slot.
I have not tried that before. Bet it is a nerve-racking process. }
If I did it freehand it would have been more nerve-racking, but I used the centering ring as a guide
An update to the current readings: The first time I measured the highest mode was with my clamp meter on Panasonic BD’s at 4.1v, and I got 5.5amps. I just remeasured with the same meter on fully-charged Samsung 30Q’s, and got a max of 4amps. So something happened.
1. The driver is very inconsistent (unlikely)
2. I somehow mis-read the meter the first time (still pretty unlikely)
3. When I opened it up, re-wired, and shaved the LED, I messed something up (probable)
I just thought I would post this now in case other people start getting 4amp readings instead of 5.5amps.
Isn’t the driver from that kind that pulls those batteries stronger that have higher internal resistence? Just like the Maxtoch BLF thrower.
I’ll need to purchase this light. Where can it be found?
